Removing Cassette on 1980 Raleigh
Old 01-07-21, 05:43 PM
tjfastback66
tjfastback66's Avatar
Bikes: 1983 Raleigh Prestige Grand Sport / 1983 Raleigh Competition / Specialized Hard Rock
Liked 7 Times in 5 Posts
Hello All,
New to the forum here with a question about removing the rear cassette off of my newly acquired 1983 Raleigh Competition.
I have the correct Suntour tool and a bench vice to place it into, but cannot get the thing to move.
Any hot tips on helping a guy out here?
Thank you!
TJ
tjfastback66 is offline
Old 01-07-21, 05:51 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1244 Post(s)
Liked 431 Times in 336 Posts
If you mean the 2 or 4 prong tool, make sure it's retained with a QR skewer or axle nut.
You need more force to remove. Simple. Bigger wrench or piece of pipe added for leverage.
You have a FREE WHEEL, not a cassette.
It simply screws on and then gets super tightened by simply pedaling.
Add years of not being removed, it may likely have corrosion wanting to bond the parts together.
You might try applying some Penetrating Oil. (WD-40 is ineffective. Get the "real" stuff) and letting soak for a few hours and hope some wicks in.
These OFTEN break the tool when removing.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 01-07-21, 06:03 PM
tjfastback66
Hi Bill,
Thank you so much for the quick reply I will try the soaking method.
Much appreciated!
​​​​​​​TJ
Old 01-07-21, 06:26 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1474 Post(s)
Liked 967 Times in 657 Posts
dedhed is offline
Bill Kapaun
For further education while it's soaking-
https://www.sheldonbrown.com/free-k7.html
These prevent a bit of a dilemma for first timers.
You NEED something to retain the tool well.
However, when the FW starts to unthread it tightens against the retainer. Unbelievably tight if not careful.
Once the FW starts to unthread, stop. Readjust your "retainer". You'll have to back it off a little bit.
The thread pitch is so fine on a FW, it acts like a strong screw jack. Add the force of a long wrench....
You may need to repeat a time of 2 before things start to loosen up.
I use a 1" box wrench for the tool. It's less likely to slip then an adjustable or open end wrench. You really don't want to use a "cheater"pipe on an adjustable wrench. They are designed for convenience, not strength.
I had to take a small triangular file and "open up" the box a bit. It seems the flat "junctions" on the PARK removal tool are a bit too "peaky" to slide in the tool.
It was a matter of opening up the wrench or grind down 6 "points" on each of the 5 or 6 removal tools I have. They're too hard to file without a disproportionate amount of work and I didn't have a grinder at the time.
Old 01-07-21, 06:49 PM
bikeaddiction1
bikeaddiction1's Avatar
Bikes: Many
Quoted: 103 Post(s)
Liked 61 Times in 42 Posts
I just had to do this today, with a Suntour 7 speed freewheel. The above advice is good, in that you need to loosely install an axle or QR (with springs removed) to stop the tool from stripping out the freewheel notches. I put the tool in my vice, which is a good sized vice bolted to my heavy work bench top, which is attached to the wall. It took a hard turn with my hands at 3 and 9 o'clock positions on the wheel. Suddenly it broke loose and I stopped turning immediately and backed the QR off as mentioned above. I was then able to turn it off fairly easily.
Spraying some WD40 in is not a bad suggestion.
bikeaddiction1 is offline
Old 01-07-21, 08:52 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1266 Post(s)
Liked 700 Times in 492 Posts
The real stuff is Kano Kroil, with PB Blaster second best. Apply penetrant, give a few sharp raps with a hammer, let sit overnight or longer, repeat if necessary.
dsbrantjr is online now
Likes For dsbrantjr:
Old 01-07-21, 09:09 PM
tjfastback66
Hey thank you to all your responses - this is awesome!
I do not have any Kano Kroil, nor have I ever heard of the "real stuff" but I will check it out to source locally. Is this bike shop related or automotive?
Thanks again!
TJ
Old 01-07-21, 10:02 PM
Bill Kapaun
And just where is he supposed to hit it?
The idea is to "ring it" like a bell. Not mash the hell out of it.
A box end wrench reaching through the spokes and tapping the hub in the area of interest is more sensible.
The "real stuff" is Penetrating Oil. Pick your favorite. Available in home Improvement, hardware & auto parts stores. Some are considered better than others. I might not use the best, but multiple applications & time are not a problem for me. It hasn't failed as of yet.
I use Liquid Wrench because it comes in a screw top can that I can draw some off with a hypodermic and apply where needed only.
The stuff sprayed on the floor & paint doesn't do much except make a mess.
Old 01-07-21, 11:57 PM
SurferRosa
Señor Member
SurferRosa's Avatar
Quoted: 1551 Post(s)
Liked 1,508 Times in 868 Posts
I place an adjustable wrench on the tool and whack the wrench end with a sledgehammer a couple times.
SurferRosa is online now
Likes For SurferRosa:
Old 01-08-21, 01:11 AM
Geepig
Geepig's Avatar
Bikes: Romet Jubilat x 5
Quoted: 97 Post(s)
Liked 90 Times in 72 Posts
I have 24 inch wheels, so less torque available...
Geepig is offline
Old 01-08-21, 06:41 AM
dedhed
SE Wis
dedhed's Avatar
still more than a 10" wrench and grabbing the wheel you are applying it more equally than a single wrench
dedhed is offline
Old 01-08-21, 12:46 PM
ClydeClydeson
Quoted: 127 Post(s)
Liked 137 Times in 102 Posts
My experience with old freewheels is that they are seldom seized, but it is very likely that they are tight enough that you can easily damage the prongs on the freewheel or remover if not very careful.
1. Install the remover on the freewheel and hold in place with the QR skewer. Ensure the prongs on the freewheel and remover are perfectly aligned and engaged.
2. Clamp the freewheel remover in the bench vise so the wheel is above it and parallel to the ground
3. Put your hands on the wheel at 9 and 3 oclock
4. (a)Pretend you are a bus driver turning left.
(b)It may be extremely tight, so you might have to pretend to be a bus driver whose bus has no power steering.
5. As soon as the freewheel breaks free, loosen the QR skewer
6. Buy a replacement freewheel with full internal splines like a Shimano
ClydeClydeson is offline
Likes For ClydeClydeson:
Old 01-09-21, 04:55 AM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 147 Post(s)
Liked 69 Times in 50 Posts
Thanks again!
TJ
PB Blaster, available in Home Depot and other stores in all size containers. We buy it by the gallon and pour into old spray bottles.
JoeTBM is offline
Old 01-09-21, 05:37 AM
Moisture
Quoted: 515 Post(s)
Liked 87 Times in 71 Posts
You gotta smack the end of the freewheel remover wrench using a rubber mallet or hammer etc. to break it loose
Moisture is offline
Old 01-09-21, 05:23 PM
Bill Kapaun
You can probably do that with a splined type tool, but I wouldn't recommend it with prong type removal tools. Whacking it tends to want to move things sideways a bit. You need to keep the tool/force concentric.
Bench vise is best. Else a longer wrench and one hand trying to support the tool.
I run the tire/wheel into my garage door jamb on one side, I get on the other, then try to turn it into the jamb. You get more traction to keep the wheel from spinning.
Old 01-11-21, 03:37 AM
Geepig
Geepig's Avatar
Quoted: 97 Post(s)
Very true, but I still ask my wife to leave the garage first
Geepig is offline
Old 01-11-21, 06:37 AM
tjfastback66
Hello All,
Well problem is now solved as I was able to get some PB Blaster and soaked it for a good 6 hours. Attached the QR skewer along with the Suntour tool and loaded up the bench vice. No need to even give it a few sharp raps, It came off without too much effort.
I appreciate all that have contributed to this message.
Thanks!
TJ
Likes For tjfastback66:
Old 01-11-21, 11:07 AM
dedhed
SE Wis
dedhed's Avatar
Hello All,
Thanks!
TJ
Grease the threads on the replacement FW before installation.
dedhed is offline
Old 01-12-21, 12:27 AM
tjfastback66
Hey great advice, thank you so much!
TJ
