Genesis Folding Bike
Old 09-21-14, 03:21 PM
  #226
trrubicon06
Originally Posted by atombikes View Post
I cheat by pulling the stem out and hanging it by the bottle cage:
If I rotate the handlebars I can leave them in the stem. But it's not a quick fold because the handlebar clamp is not quick release.
I think using ergo bar ends would yield the same type of hand position as the bullhorns, without the interference. I will probably swap out the bullhorns this winter.
Thanks for the picture. I was curious with the non QR stem. When I had my Dahon Speed Uno, I could fold the handle post over the frame after folding the frame. Hopefully I can work on a solution when mine arrives. Thanks again
trrubicon06 is offline
Old 09-21-14, 03:50 PM
  #227
atombikes
atombikes's Avatar
Bikes: homebuilt FWD recumbents, Genesis 20" folding bike, 1986 Schwinn Tempo, Cannondale Beast of the East, 70's Peugeot
Yeah, it would be great if we could source a cheap QR stem that would work with this bike.
atombikes is offline
Old 09-21-14, 05:03 PM
  #228
trrubicon06
Do you by any chance know the diameter of the upper portion of the handlepost? Thorusa sells the Dahon Revolve upper portion with quick release for $27. It says 1-1/4 on their site.
Old 09-21-14, 08:39 PM
  #229
roving70
roving70's Avatar
Bikes: genesis 20' folder, giant 27.5 atx ebike
Originally Posted by derekpte View Post
is the fork spacing 74mm front and 120mm back?
i think it's 130mm back.
roving70 is offline
Old 09-22-14, 05:28 AM
  #230
atombikes
atombikes's Avatar
I measure 1.13".
Old 09-26-14, 03:55 PM
  #231
mobilesuit1988
I am a newbie to a bike and this site and have a question. Is this bike good for newbie? It seems it requires some adjustment after assembly. I don't think I have any tools in my hand if repair needed.
mobilesuit1988 is offline
Old 09-26-14, 05:13 PM
  #232
trrubicon06
Originally Posted by roving70 View Post
more pics...
the image with a close up on the hinge are the ones that i would like to give a heads up for genesis owner. the lock ring is not permanent and will possibly pops out during a long period of folding and unfolding. what i did is soldering it from the outside to permanently hold it, only from the outside portion so that the spring will still function. that way the lock ring will not pop out from the bolt. also the bolt from the handlepost, make sure you protect the base that holds it. any small dent will deformed the base and stop the bolt from moving and you can't close the handlepost anymore.
I was having some problems with one of those spring latches and had to file a small burr off inside the hole. After that, I decided to upgrade the clip with some e-clips from Lowes. They are 5/32" in size and fit perfect add tight once installed.
Here she is ready for upgrades. Great bike though.
Old 09-27-14, 05:23 AM
  #233
atombikes
atombikes's Avatar
This is really good information, thank you for sharing. It's a good example of a simple, inexpensive fix for a problem that could potentially cause someone to have to replace the entire folding stem.
Old 09-28-14, 06:29 AM
  #234
roving70
roving70's Avatar
yeah it looks better than what i did...
roving70 is offline
Old 09-28-14, 06:34 AM
  #235
roving70
roving70's Avatar
mobilesuit1988,
it's good for a newbie...i would suggest to bring it to lbs before riding it for tune up.
roving70 is offline
Old 09-30-14, 09:01 PM
  #236
trrubicon06
I found a possible solution for anyone wanting to switch to a Dahon handlepost.
I'm in the process of upgrading a bunch of things to the Genesis and removed the handlepost to adjust the headset. Once off I realized that the fork is 1-1/8" and threaded. The big black ring is actually the nut for adjusting the headset. I was able to loosen and adjust this with a rubber strap wrench by the way.
I had come across this similar solution in Thorusa's technical section. Basically use a threadless stem adapter and the newer 1-1/8" Dahon handleposts.
Handlepost conversion
older Boardwalk Conversion
1-1/8" quill to 1-1/8" threadless stem adapter
https://www.amazon.com/Profile-Design...ds=ACTHRCONKT8
The added cost is the bad part, but could be useful to the right person.
Old 10-05-14, 03:46 PM
  #237
mobilesuit1988
roving 70,
my English is bad, not sure what you mean about "bring it to lbs".
anyway, I order the bike and it will be deliver sometime this week
Old 10-05-14, 04:35 PM
  #238
dynaryder
PatronSaintOfDiscBrakes
dynaryder's Avatar
Originally Posted by mobilesuit1988 View Post
roving 70,
LBS = Local Bike Shop
He's suggesting you have a shop go over it to make sure everything's set up properly. Many mail-order bikes have machine built wheels that still need to be gone over by a human to prevent future spoke breakage,plus a mechanic can make sure your shifting and brakes are working right.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
dynaryder is offline
Old 10-06-14, 05:46 PM
  #239
mobilesuit1988
I see, do you have any idea how much it usually cost for checking the bike?
Old 10-07-14, 04:29 AM
  #240
trrubicon06
Each shop is different, just like an auto mechanic. Expect it to be over $40 at least, but probably more. Walmart bikes can be a pain for shops when the bike was assembled by a Walmart "assembler". Lucky us, this bike is received boxed and basically how all bikes are received. Just expect them to have to do more tuning on a part made to lesser standards.
Old 10-07-14, 07:56 AM
  #241
trrubicon06
Updated pics for mine...
Upgraded it to a shimano 7sp freewheel, shimano 7sp trigger shifter, foam grips, new saddle, rear rack, spare tektro v-brakes, and cut 2" off handlepost.
Old 10-07-14, 08:17 AM
  #242
SHBR
C*pt*i* Obvious
SHBR's Avatar
Quoted: 593 Post(s)
Liked 49 Times in 40 Posts
This style of bike is a dime a dozen in China.
I could get the same thing here for around $150USD new.
I'd prefer to get something secondhand like this (1600RMB=260USD), rather than have to replace most of the low quality parts.
SHBR is offline
Old 10-07-14, 08:31 AM
  #243
cplager
The Recumbent Quant
cplager's Avatar
Bikes: 2012 Cruzbike Sofrider, 2013 Cruzigami Mantis, 2016 Folding CruziTandem
Quoted: 23 Post(s)
And my favorite color is red.
And both of our comments are not relevant to this thread...
cplager is offline
Old 10-11-14, 07:42 PM
  #244
atombikes
atombikes's Avatar
Bike looks really nice. Did you have to do anything special to allow the use of the 7 spd freewheel (other than the shifter)?
Old 10-12-14, 12:29 AM
  #245
1398567
Bikes: Dahon Speed UNO, Schwinn Hybrid, MTB
Hello All,
I just registered to post on these forums. I was wondering whether anyone thought of converting the genesis to a single speed or double speed bike w/ front brake and coaster? On a different topic, I am currently in S. Korea. Walmart wont ship over here. So,a is there a similar priced alternative I can buy. I really like the frame design.
Thanks!!!
1398567 is offline
Old 10-12-14, 08:03 AM
  #246
icedmocha
There's time now
icedmocha's Avatar
Quoted: 4069 Post(s)
Liked 135 Times in 101 Posts
I like that. Are you willing to ship it over to the states for me?
icedmocha is offline
Old 10-12-14, 08:34 PM
  #247
trrubicon06
Nope, just the shifter and the limit screws on the derailleur. I'm using the stock derailleur at the moment, but plan to upgrade. I'm on the search for a new crankset as well, but trying to keep everything budget and not high end for this build.
Old 10-12-14, 11:21 PM
  #248
DoubleDiamonDog
Quoted: 14 Post(s)
Absolutely - I'll ship a bike over for you. I'll ask you to pay for the shipping in advance. Let me know what bike you would like and I will purchase it and send it to you. I will also ask you to advance funds for the purchase of the bike. I am reliable but we can use Paypal as an intermediary if that makes you more comfortable. My services will only add 20% to the bike cost and you cover all expense at cost plus 10%.
This is not a blanket ad / solicitation, just and attempt to facilitate a buyer getting what he wants.
DoubleDiamonDog is offline
Old 10-13-14, 06:47 AM
  #249
atombikes
atombikes's Avatar
...and, with the stroke of a few keys, the Genesis starts looking real good again.
Old 10-13-14, 12:38 PM
  #250
jur
Quoted: 318 Post(s)
Liked 3 Times in 2 Posts
The Genesis has a forwards-angled stempost, something which I have not seen on China bikes. So just check that before saying they are the same. (This is a Dahon Biologic design feature.)
jur is offline
