Genesis Folding Bike
Old 04-05-15, 08:34 PM
  #326
kurtp13
Bikes: Trek 820, Cannondale F500 with Trekking bars and road tires, Bianchi Alfana, Panasonic PCI "Les Maillots", Cannondale M1000 Tandem, Schwinn Johnny, Trek Lime, 1964 Armstrong, 1962 Raleigh Gazelle, 1964 AMF Hercules, Brooklyn Cruiser Driggs
Westgl. Do you know what gear inch range you have with thr flyby?
kurtp13 is offline
Old 04-09-15, 02:23 PM
  #327
icedmocha
There's time now
icedmocha's Avatar
Quoted: 4069 Post(s)
Liked 135 Times in 101 Posts
Are there any effective steering tube bottle holders? I tried the one in the OP and the fit was too tight.
icedmocha is offline
Old 04-09-15, 03:49 PM
  #328
kurtp13
I am using the Bell Clinch 600 which has a rubber contact to the tube and velcro straps to tighten it to the tube. I wanted something that could be taken off quickly if I need to move it when packing. At first I was disappointed in the retention of the bottle. It fell off a few times on bumps. I had it positioned on the back side of the steering tube. Since then I moved it to the side of the tube which seems to work much better. After moving it I lost the bottle one time on a severe bump. Because the opening is now on the side, the bottle stays in much better. I even bought another cage since then. Walmart now carries them in the store. I initially saw it at Target.
kurtp13 is offline
Old 04-09-15, 05:50 PM
  #329
osco53
Old Fart In Training
osco53's Avatar
Quoted: 12 Post(s)
Liked 22 Times in 16 Posts
That's a good looking folder for $200,,
It looks to have the exact same folding pedals as my $600 Dahon
I can say now that a 14-28 cog cassette would not be enough for me even with a 52T up front.
My Cassette is an 11-30,,52 chaining,, So far on my very few short rides I don't use the 30t much but I do use the 7th gear often,
and have dipped into the 11T a few times... 7th gear is a 13 T
osco53 is offline
Old 04-11-15, 09:19 AM
  #330
gardner041
I recently bought the Genesis Folding Bike a couple of weeks ago and I am looking to do some upgrades on the bike. I am undecided if I should switch to some bullhorn handlebars or get bar ends and an aero bar setup so I can be in a more aerodynamic position when riding. So far I am really enjoying the ride and have went on a couple 5 mile rides and average 14.2 miles an hour and I am also thinking of replacing the freewheel to DNP 7 speed 11t-30t to get some more speed. Any thoughts and recommendations is appreciated.
Thanks,
Cory G
gardner041 is offline
Old 04-11-15, 10:45 AM
  #331
kurtp13
Thanks,
Cory G
I installed bar ends and this stem extender. I like the reach. I was having some trouble with the fold at first but then I discovered that if I extended the handlebar past a safe riding position that I could fold it somewhat below the frame. That was easy and helped me keep the extender. Just one simple thing to add to the fold and unfold sequence. I think the OP mentioned wishing he had just put on bar ends due to the fold complication.
I am running a DNS Epoch 11-32 freewheel with a 53 T Chain ring. I like this combo so far and have done some long rides on it. No complaints. I live in a hilly area and wanted as low a gear as I could squeeze out. The 46 T original chain ring was not cutting it on the high end though.
File Type: jpg
kurtp13 is offline
Old 04-11-15, 01:04 PM
  #332
gardner041
Thanks a lot for the info. I think the stem extender would help out a lot. Can you tell me where you ordered it from? Also I will soon be upgrading the freewheel and chain ring to a similar setup as yours.
Old 04-11-15, 01:16 PM
  #333
kurtp13
I ordered the stem extender from Ebay.
https://www.ebay.com/itm/161072913336...%3AMEBIDX%3AIT
Item:
gobike88 SATORI Adjustable Stem ABERHALLO 50mm, 198g, HBA-02N, free shipping 056 $23.53 FS.
There are some cheaper versions out there but I like the finish on this one and the four unique bolts. I wasn't crazy about the ones I saw with only two bolts. It seemed like a lack of redundancy. I was very happy with the item as received.
Regarding the freewheel, I forgot to mention that I upgraded to a 7 speed from the original 6 speed which I think you could do with only a freewheel and shifter change. You had already planned to do a freewheel so the shifter is ~$15 additionally. I changed the chain for length also.
kurtp13 is offline
Old 04-13-15, 05:37 AM
  #334
icedmocha
There's time now
icedmocha's Avatar
Thanks I'll pick one up.
Old 04-15-15, 09:57 AM
  #335
gardner041
How do you stop the handlebar stem from squeaking?
Old 04-17-15, 05:53 PM
  #336
kurtp13
Oil it but don't go crazy with it like i did. I think I'm paying for my generous application of lube. I have had to re tighten some fasteners and the button just popped off at the handlebar joint. I found it but the spring was gone. It replaced it with a ball point pen spring which seems to be a perfect fit. The button has a friction fit to the rod with moves the latch pawl. My super deluxe lube appears to have crept into that area.
It was a bit of a panic at firat whenI couldn't find the spring. I was hoping to use the bike tomorrow morning. Now I can.
kurtp13 is offline
Old 04-17-15, 07:49 PM
  #337
atombikes
atombikes's Avatar
Bikes: homebuilt FWD recumbents, Genesis 20" folding bike, 1986 Schwinn Tempo, Cannondale Beast of the East, 70's Peugeot
See post #146
atombikes is offline
Old 04-18-15, 04:19 PM
  #338
osco53
osco53's Avatar
Quoted: 12 Post(s)
How about the Tern Andros Stem a quick release stem on the ThorUSA site ?
osco53 is offline
Old 04-29-15, 12:17 PM
  #339
Bikeman58
Bikes: Giant Defy, 1977 LeJeune #1 French Team Bike, Geoffrey Butler custom, Specialized Stumpjumper, Gary Fisher SuperCaliber, Bianchi Volpe, Melon Slice folding bike, Genesis folding bike, etc.
So I went Genesis... and a couple of weeks in have no regrets. Solidly built frame and okay parts. Came with a bent rear axle, but Kent sent me out a new rear wheel and I had it in less than a week. Awesome customer service.
Added grease and adjusted hubs, headset and BB... all were very tight and binding. Now everything feels pretty good.
Went to my local bike co-op / non-profit and scored with an older STX RC rear derailleur which shifts much, much nicer than the Tourney the Genesis came with -- and it is all metal.
Took the Hookworm tires, Ergo seat and Planet Bike rack off my broken down Downtube and put those on the Genesis -- saved around $140 bucks there.
Changed out the uncomfortable grips, added bar ends for some additional reach, an IncrediBell, and I am in business.
Still want to change the Fleaby freewheel -- that is definitely the weak link on this bike. It knocks and occasionally slips... I just have to figure out if I want to change to a 7-speed configuration... but then I will need a new shifter, and I suspect a new chain.
What drivetrain upgrades are folks recommending?
Anyway, since I had most of these parts already, I have added a whopping $15. to my purchase price... so I am pretty pleased so far.
Thanks to everyone on this thread whose posts encouraged me to go this route. I think the Genesis is definitely a category killer... and the best value in the sub $500 price range.
Bikeman58 is offline
Old 04-29-15, 12:28 PM
  #340
Bikeman58
Originally Posted by atombikes View Post
The stem seems stiff enough. Lengthening your reach does place more strain on the riser, but the stresses are working on the hinge, not the locking pins (see pic).
Since this is a quill-style riser, it's easily replaced with something else.
Thanks for the info and encouragement. I am enjoying this bike way more than I expected. Was thinking it was a stop gap measure, but suspect I will keep it around. My only concern is the folding mechanisms. Anyone had any issues with these failing, breaking, etc. They seem a bit more complicated than necessary, so I wonder about the durability / longevity.
Old 04-29-15, 06:12 PM
  #341
Joe Remi
Bikes: Haibike Sduro Trekking SL, Rivendell Appaloosa, Concinnity singlespeed, KHS mini velo (Japan market), Trident Spike trike
Quoted: 572 Post(s)
Liked 13 Times in 13 Posts
I'm not sure I would agree with that. For your $200 you're getting a lot of cheap, heavy parts that people seem to spend a lot of time fixing/replacing. It seems to me most buyers would be better off starting with an Origami, Downtube, or the lower-end Dahons and Terns. Or buy used.
Joe Remi is offline
Old 04-30-15, 12:21 PM
  #342
Bikeman58
I stand by what I said with a caveat: you have to be a bike mechanic, technically proficient, or willing to learn, to really get the value out of the Genesis. I can pick up better parts and replace bit by bit... it is a hobby. Also, this is not necessarily the best bike for someone who is not familiar with bikes and just wants to take it out of the box and ride, though if your budget is $200. and you can't find something decent used...
For the record, it is as light as my Downtube was / and my friends Downtube. Though heavier than the Nova, it feels sturdier and has a less upright riding position that I prefer. It is about the same weight as my Melon Slice -- though the Slice did hot come with rear rack braze-ons, which limits the functionality for me. Most of the sub $500. bikes make compromises and use a number of cheap parts... my wife's Nova and the Genesis both came with low end Shimano Derailleurs... the one on the Nova broke and I replaced it -- on the Genesis, I replaced proactively.
Where I think the Genesis shines is the frame (consensus of my "folding bike" friends is that it is nicer than my Melon frame or Downtube frames)... though only time will tell about its durability.
I also like that the Genesis is a rigid frame. I just don't get most of the suspension folders -- too heavy and clunky and you lose efficiency. Maybe if you are going to use it a lot off road... but then I want a real Mountain Bike.
I liked Melon, but they appear to be out of business. Hasa impresses me, as does Origami... but no one else can touch $200.
Old 04-30-15, 01:27 PM
  #343
Bikeman58
Picture of work in progress
File Type: jpg
Old 04-30-15, 02:01 PM
  #344
Bikeman58
More pics
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 04-30-15, 02:37 PM
  #345
Bikeman58
I am a big fan of the Planet Bike rack I have been using the past several years. It can require minor modification to make it fit and be level, but it is a true functional rack... unlike so many provided by most folding bike manufactures . Most OEM racks on folding bikes cannot take panniers or for that matter, trunk bags/baskets that have a footprint nominally wider than the rack because it results in heel strike. The Planet Bike rack is positioned up from the rear wheel and back from the seat post minimizing the likelihood of heel strike. It is worth trying for riders frustrated by the low, flimsy racks that come stock on so many bikes.
Old 04-30-15, 06:29 PM
  #346
JosephLMonti
JosephLMonti's Avatar
Quoted: 11 Post(s)
Liked 3 Times in 1 Post
JosephLMonti is offline
Old 04-30-15, 09:05 PM
  #347
Joe Remi
Quoted: 572 Post(s)
If you act now, you can have one with apehangers for twice the price!
Custom Genesis Folding Bike $400 obo
Joe Remi is offline
Old 05-01-15, 03:37 AM
  #348
kurtp13
And doesn't come with the front pouch or rear rack. Wow, what a bargain. He even mentions the original price of $200.
kurtp13 is offline
Old 05-04-15, 11:23 PM
  #349
icedmocha
There's time now
icedmocha's Avatar
Perhaps. I have been using mine for about a year now without replacing any parts save the seat with a brooks I had laying around. I may add bar ends and new grips as well. It's been a great bike.
Old 05-04-15, 11:26 PM
  #350
icedmocha
There's time now
icedmocha's Avatar
More pics
What's the deal with that seat?
