Very informative article on Vitus 979
Quoted: 1639 Post(s)
Liked 829 Times
Never saw this one before, but it seems to be a good article on the Vitus 979.
So in case you are a 979 fan, or just want to know more about the frameset's history/design, here's the link:
ipernity: The Peugeot PX-10DU (Vitus 979) by Peter Kohler
Thanks Chombi, what a great read! I wish there was this much info on all bicycle models! Curious to hear what others think of the ride of these frames. I've ridden an old 979, a newer Alan with the larger tubes and an old Alan with small tubes and so far I like the old Alan best, it was "just right".
Bikes: '73 Flandria 3 speed, '84 Lotus Legend Compe, '87 Merckx Corsa Extra, '94 Kona Kilauea
Quoted: 5 Post(s)
Thanks for the link! I agree with devinfan, I wish there were in-depth articles like that on more bikes. I rode/raced a Vitus for several years in the early '90s, even at a svelte 135lbs back then on a 54cm frame I could get the rear rim to rub on the brake pads on steep climbs. Of course at that time I was climbing in a 42x21 gear so not exactly "souplesse". Now that I'm older, and slower, and live in a flatter area I think the Vitus could be a good ride for me. I've thought about buying one several times over the past years but there's so much nice steel out there it's hard to make the commitment of funds and garage space. That article has me thinking again though....
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
Cool article. I remember the excitement these frames stirred up in the early days. Oldschool steel riders said they would be too noodly to be successful but it looks like they did ok, and I suppose paved the way for carbon.
I always wondered if anyone had tried gluing together a cromoly frame, since even silver soldering a frame must change the tubes slightly from the heat. Seems like a glued cromo frame would be pretty stiff.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Thanks for sharing the link with us Chombi, great article. Once again I learned something useful here.
Bill
Bill
Semper Fi, USMC, 1975-1977
Quoted: 5888 Post(s)
Liked 3,471 Times
Great article. These were (and are) beautiful bikes.
NOS is still available:
https://adrenalinebikes.com/store.cf...ategoryID=5798
-Bandera
Bikes: 1981 Bianchi Limited 650B conversion (sold), 1985(?) Guerciotti retro-roadie, 2018 Specialized Allez Sprint, 2012 Specialized Crux, mid 80's Focus MB-400
Quoted: 67 Post(s)
Since 979 production involved bespoke frameset components & Aerospace bonding tech in a dedicated clean facility w/ proper ventilation for toxic products knocking up a ride-able frameset in the garage w/ do-it yourself epoxy seems unlikely at best.
-Bandera
-Bandera
Very cool that some new frames are still available. I noticed they offer to build them up with modern components. I'm thinking that with a Vitus, since one can't cold-set the rear to 130mm, the best option for going modern is to just squeeze a 130mm road hub between the dropouts. Can anyone report success stories/warnings about using a modern rear hub paired to a 9/10/11 speed drivetrain with a 979?
Pic of it converted to 10 cog Shimano a few seasons ago, 53X39 13-25.
-Bandera
Quoted: 67 Post(s)
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
Thanks for the link, @Chombi1. Great stuff.
I have a 992 hanging somewhere in the rafters. Always considered it too small, but after reading this I think it might not be such a bad idea to build it up and give it a try.
Quoted: 569 Post(s)
Liked 581 Times
The Sheldon Brown solution is to drop a 8,9,10 freehub onto a 126 body and it worked perfectly on my 600 6 spd hub. Built the wheel up with H Plus Son rim and running a DA 9 spd drivetrain and all is well.
I am so impressed with the ride it is now in my daily ride rotation and I have a spoke order on the way to build a matching front wheel with DA hub. My only past experience with a aluminum road bike was a Raleigh 500(?) and I rattled a few fillings loose in the short time I had it.
One caution here is that being well into my 60's I don't generate much bottom bracket flex.
Quoted: 4722 Post(s)
Liked 3,036 Times
I've always been puzzled by the fact that the Peugeot branded version of the Vitus 979 was never officially imported into Canada and the USA, though we got the Peugeot versions of the carbon fibre frames. I've always wondered if this was part of the licensing agreement between Peugeot and Vitus, yet we got rebranded Vitus 979 from the likes of Cilo and Motobecane, among others.
As for the ride quality, I've always had issues with the flex of steel, metric tubed frames, let alone a 979.
Liked 829 Times
Liked 3,036 Times
You have to consider that the Peugeot PY10FC CF bike was a proprietary design (different from the Vitus Carbone 3, which it is often mistaken to be) done by Peugeot and Vitus engineers, with different/larger diameter, CF main tubes with different (from Vitus Carbones) CF fiber layup patterns, for additional stiffness. The frameset was not sold as a Vitus nor re-branded and sold by any other company. Unlike the 979 Peugeot which was a rebranded 979.
Bikes: 1980 Koga-Miyata Gentsluxe-S, 1998 Eddy Merckx Corsa 01, 1983 Tommasini Racing, 2012 Gulf Western CAAD10, 1980 Univega Gran Premio
Quoted: 600 Post(s)
Liked 11 Times
Liked 3,036 Times
Metric tubesets were used primarily by French and Spanish builders, up until the mid-1980s when most started converting to imperial tubing. Some Swiss and Belgium based brands also used metric tubing. Most tubing manufacturers offered their higher grade tubesets in both metric and imperial versions until the mid-1980s. Notable exceptions were Reynolds 531SL and first generation Reynolds 753, which were only offered in metric sizes.
Edit: Corrected typo in metric top tube diameter, per following post.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
he meant to write 26mm, not 28mm...even T-Mar makes a typo now and then!
And BTW, great article from P. Kohler, who I thought of as "Mr. Raleigh" due to his CR list contributions, but now see he has a greater range of knowledge and interests.
Thanks to Chombi1 for sharing!
Liked 3,036 Times
Quoted: 600 Post(s)
Liked 11 Times
Thanks for the very clear explanation. Wow, that seems like such a tiny difference -- I'm sure I wouldn't be able to tell. By my calculations, the imperial downtube has about 2.2% more material in a 0.5mm thick section, compared to the metric downtube. I guess that's enough to matter.
Death fork? Naaaah!!
There are two metric 531 bikers in the barn, a third in process, and a 979, and I've never flexed any of them pedaling. I HAVE experienced the unique Vitus twitchiness on fast decents.
Granted, I am a relatively light, recreational rider. I DO love riding all three.
Top
Top
