how do I figure out what BB crankset i can put in my Salsa Journeyman 650B
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
how do I figure out what BB crankset i can put in my Salsa Journeyman 650B?
it is currently running a vero adventure square taper and i would like to upgrade it.
Bikes: Kona Unit, Kona Kahuna, Kona Dew DL, Scott Big Jon, Trek Checkpoint ALR4, KHS Urban Soul, Haro Team Issue, GT Force Expert Carbon, Bernardi Quadra.
Quoted: 31 Post(s)
Liked 48 Times
Any crankset that uses some form of BSA threaded bottom bracket will work. Shimano's cranks with their Hollowtech II bottom brackets, SRAM with their GXP bottom brackets, FSA with their Mega EXO bottom brackets and so on. And of course other cranksets that use a square taper bottom bracket such as the White Industries cranksets.
Likes For MAGAIVER:
Likes For shoota:
External bearing cranks also resolve the what BB length ? question , since its part of the crank arm assembly..
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
i want to change the bottom bracket and move away from a square taper to a higher end stronger crankset.
Quoted: 1872 Post(s)
Liked 692 Times
So do it. Do you need help deciding? Have any questions? Can you do the work yourself or do you have an LBS that can do the work?
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
I think I can do it with the help from a friend but I am not sure what bottom bracket is in there. I looked on the bike's website and on the cranks and don't know exactly what i am looking for.
Liked 692 Times
thanks.... I need help deciding. It currently is 46/30 I used to ride 50/34 on previous commuter. I cant find one that is 46/30 seems that I can only find cranksets 48/32. I think it will be okay to change to 48/32 but I do like the low gearing for climbing while commuting.
But there are others on eBay with different length crank arms, product levels, different BBs that will work, and different price ranges.
What length crank arm do you want and what is your budget?
2019 Salsa Warbird
2019 Salsa Warbird
Liked 692 Times
If you get this crank I can send you an extra set of 46/30 rings and a bb to fit it. The BB is a little ugly on one of the cups but it works just fine, won't be visible once the cranks are installed, and you can have it all for the price of shipping.
https://www.ebay.com/itm/FSA-Omega-A...cAAOSwjlVb-1d1
2019 Salsa Warbird
2019 Salsa Warbird
Liked 692 Times
Same questions I asked him apply to you. The crank you want is not specific to your Journeyman. Don't let what kind of bike you have make this decision. Answer the questions I asked above and we'll help you find something.
2019 Salsa Warbird
2019 Salsa Warbird
I have decided
To be less impulsive and think that I need external bearings to feel updated. I am keeping the 46\30 and adjusted front derailleur so it wouldn’t rub my chain while cranking down on right pedal stroke. Now all is good. It’s a gravel bike. Not a carbon road unit.
thank u.
thank u.
