Best tire width (and tire) for true mostly-paved "allroad" centuries?
Quoted: 1218 Post(s)
Liked 298 Times
so if the argument was 36 strada bianca 36 TLR vs Panaracer Gravel king slicks 38
Advanced Slacker
Quoted: 2749 Post(s)
Liked 2,516 Times
This weekend, I will be riding a century through an area that (I suspect) will include some smooth pavement, some rough chipseal, a little insanely rough crater-pavement, and some light gravel. I'm accustomed to either doing gravel races or doing centuries on smooth pavement, but I've never done a road century that I knew would have substantial amounts of sketchy surface. I've got my "allroad" tires ready, but I thought I would ask what the forum thinks is the ideal tire width (and tire) for this kind of century. For reference, I'm thinking of running 36mm Challenge Strada Bianca TLR's. But . . . I've also got a set of 25mm Conti 4000SII's (that measure 28mm) if I change my mind.
What do you think? What tire would you use?
38mm Barlow Pass. I never wish I was on a different tire on any surface short of mud.
I was also pretty happy with the 35mm Bon Jon Pass tires I had before this, and they are quite a bit lighter.
I haven't had a problem with the GK slicks in wet weather-they seem grippy enough riding them on pavement in the rain. At least, I haven't felt much slippage through normal riding scenarios.
I commuted through winter on a singlespeed with narrow GK slicks, which was what sold me on getting a wider pair for the Topstone for road riding.
You are basically describing the mix that I ride all the time. A mix of pavement, chip-seal, really crappy pavement, and gravel.
Quoted: 4559 Post(s)
Liked 2,798 Times
I'm gonna stick with Continental Speed Rides. Been happy with 'em for two years in mixed terrain/condition riding, no reason to change. It's more like a balloon tire with a little tread. Cheap too, only around $20-$25 each, wire or folding bead. Got my first set, a pair for half price on special. Made me a believer.
One size only, nominally 700x42 but measure closer to 700x38. Fast and smooth on pavement, comfy on chipseal with the right pressure (I weigh 150, usually keep 'em around 45-50 psi front, 50-60 rear, lower for gravel). Competent on gravel -- as competent as I am, which is oh-kay. Fine for dry grass, not for mud or rain-slick grass.
Durable too. The diamond/file pattern main tread feels soft, like it would wear prematurely, but nope... it's been good for a few thousand miles since autumn 2016. Reasonable flat protection without feeling sluggish.
I keep trying other comparable tires but always go back to the Speed Rides.
Chases Dogs for Sport
Sunshine
Quoted: 10902 Post(s)
Liked 7,393 Times
- Price
- Brand Loyalty
- Availability
- Looks
Recently was in same boat, looking at Strada Bianca, ended up with 32GK slicks because:
- They offered a red color
- I can get them for under $25 ea.
- I have 38GK SK for more adventurous endeavors
- Less likely to be blown over by cross wind.
- Faster? Well they feel faster
Likes For tpower:
Wspsux
16
04-26-16 09:01 PM
Barrettscv
21
10-26-11 12:34 PM
