Creaking and squeaking
Old 06-25-19, 07:57 PM
rousseau
rousseau's Avatar
Quoted: 111 Post(s)
Liked 38 Times in 21 Posts
Just started in the last day or two. It happens when I move the bike side to side, either in the saddle or out of it, pedalling or not. It's even creaking when I'm standing still. The bolts at both ends of the stem and seatpost are good. I'm fairly confident this isn't an issue with the saddle or handlebar. Any ideas?
Stationary:
While riding:
rousseau is offline
Old 06-25-19, 10:46 PM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
Just a guess, but check your headset, or skewers.
noodle soup is offline
Likes For noodle soup:
Old 06-26-19, 02:29 AM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
Check the spoke crossings, especially on the rear wheel. Pinch them together where they cross. If you hear any squeak or feel unusual friction or stiction, that's probably the source.
I get that with only one wheelset, the black spokes on my hybrid. I moosh some wax between the spoke crossings every month or so. Soft wax from scented candles works better than oil or grease for me. Maybe those wheels have a delicate romantic side, I dunno.
A few months ago I chased down persistent squeaks for weeks on that bike, eventually overhauling the hubs, BB, and checking everything else. But it was just the spokes.
canklecat is offline
Likes For canklecat:
Old 06-26-19, 07:40 AM
Nachoman
well hello there
Nachoman's Avatar
Quoted: 503 Post(s)
Liked 336 Times in 206 Posts
Originally Posted by canklecat
check the spoke crossings, especially on the rear wheel. Pinch them together where they cross. If you hear any squeak or feel unusual friction or stiction, that's probably the source.
i get that with only one wheelset, the black spokes on my hybrid. I moosh some wax between the spoke crossings every month or so. Soft wax from scented candles works better than oil or grease for me. Maybe those wheels have a delicate romantic side, i dunno.
A few months ago i chased down persistent squeaks for weeks on that bike, eventually overhauling the hubs, bb, and checking everything else. But it was just the spokes.
+1
Nachoman is offline
Old 06-26-19, 08:22 AM
Jon T
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times in 39 Posts
Take out the wheel qr's. Thoroughly saturate them with oil. Wipe off the excess oil. Reinstall. Make sure they're tight. Go ride. I'd bet heavily the noise will be gone.
Jon
Jon T is offline
Likes For Jon T:
Old 06-26-19, 09:20 AM
Dan333SP
Serious Cyclist
Dan333SP's Avatar
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times in 99 Posts
Jon
I had the most annoying creak recently that was similar to the OP's. Was convinced it was my headset bearings so I took them out and cleaned/regreased them multiple times without success. Turns out my front skewer was just a little loose and dry. Facepalm moment.
Dan333SP is offline
Likes For Dan333SP:
Old 06-26-19, 11:21 AM
rousseau
rousseau's Avatar
Quoted: 111 Post(s)
Check the spoke crossings...
They're Sciroccos with radial on the front and the G3 pattern on the rear, so that's not it, unfortunately.
Jon
I will definitely try this!
rousseau is offline
Old 06-26-19, 12:26 PM
cycledogg
Quoted: 344 Post(s)
Liked 20 Times in 18 Posts
Stationary: https://www.youtube.com/watch?v=gSBixdYq0zk
While riding: https://www.youtube.com/watch?v=WXNLefYrdEQ
Do you have any spacers under the stem? If so, take the stem off and try putting a light coat of grease between each one then reassemble.
cycledogg is offline
Old 06-26-19, 01:13 PM
rousseau
rousseau's Avatar
Quoted: 111 Post(s)
Spacers? Is this not the road forum, where slamming the stem is de rigueur?
Heh heh, wouldn't want to contravene regulations, so no, no spacers under the stem on the bike.
rousseau is offline
Old 06-26-19, 01:35 PM
Dan333SP
Serious Cyclist
Dan333SP's Avatar
Bikes: Emonda SL6
One more thing that's given me creak headaches in the past... If you have external cabling, check where the barrel adjusters/cable housing stops are mounted on the frame and spray a little triflow onto those points, sometimes they can click or creak.
Dan333SP is offline
Old 06-26-19, 02:59 PM
Wilmingtech
Bikes: 2013 Ridley Helium, 2017 Blue Pro-Secco EX, 1987 Schwinn Super Sport
Quoted: 211 Post(s)
Liked 101 Times in 73 Posts
Tighten up your wheel skewers.
Wilmingtech is offline
Old 06-26-19, 05:39 PM
canklecat
canklecat's Avatar
Ah, in that case, another vote for the QR.
My early '90s Trek 5900 has Salsa aluminum QRs with the external cam. Nice and light and tight and squeaky. I use the same stuff on the mating surfaces -- scented candle wax. Or chocolate. Chocolate would probably work too. Maybe a bubble bath and a romcom.
Dang lightweight bikes. It's like dating again. Always a new squeak or creak or whine to track down and fix.
Old 06-26-19, 08:00 PM
rousseau
rousseau's Avatar
Quoted: 111 Post(s)
Success!! I threw some lube on the skewers and that did the trick. I'm now squeak-free.
Thanks!
rousseau is offline
Likes For rousseau:
Old 06-28-19, 04:21 AM
Stravacyclist79
Quoted: 13 Post(s)
Liked 3 Times in 3 Posts
Put some lube oil on the ferrule cable on the frame. Check you rear sprockets on the cog if they're loose.
Stravacyclist79 is offline
Old 06-28-19, 10:32 AM
noodle soup
look at post #13 . His problem was solved.
Tandem Tom
Bicycle Mechanics
23
01-27-22 10:27 AM
gearbasher
Classic & Vintage
10
07-18-18 08:33 AM
PdalPowr
Bicycle Mechanics
57
12-26-17 02:35 AM
bram06
Bicycle Mechanics
20
08-11-16 02:18 AM
ducati hyp
Road Cycling
16
05-04-12 04:48 PM
