Post pictures of your Hybrid
#7376
Bikes: 1990 Trek 970, 95 Schwinn Searcher, 2012 Trek Wasabi cruiser
Quoted: 13 Post(s)
Liked 23 Times
Here's my Cheap Little Hybrid
Almost embarrassed to post my bike with all of the gorgeous rides shown here; I've had this for 4 years now and mostly ride a 10 mile paved trail route from my home 3 or 4 times a week for fun and exercise. My top speed is around 25 mph. Although I haven't ridden many hybrids this one fits the bill for speed and comfort. Anyone care to guess the model year of this Schwinn Searcher? So far all I've done to it is replace the rear shifter and brake pads. It had been restored nicely when I bought it.
Likes For Greg C.:
#7377
Quoted: 76 Post(s)
Liked 76 Times
either way, they are great! highly recommended. they are completely serviceable too, not that it's that big of a deal to replace them when they go at $25 a pair.
#7379
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
Those $25 Fookers look like a great option!
To be sure, Race Face doesn't actually manufacture the Chester pedals -- they're very likely produced for them under contract. It seems that their contract either doesn't prevent the manufacturer from also selling/labeling to other brands, or they're going outside the contract to do it. The fact that the same little stamps and tooling marks are visible means it's very likely they're produced using the same molds.
I did observe that the axles themselves are different. It looks like the Race Face ones used a smaller hex key size than the Fookers.
#7380
Quoted: 576 Post(s)
Liked 1,001 Times
Those era Schwinns were very high quality, the high end MTBs were handmade in CO at the Yeti factory. Yours was probably built by Giant in Taiwan
Likes For DorkDisk:
#7381
Quoted: 13 Post(s)
Liked 23 Times
It has the "epicenter" seatstays and graphics of the mid 90s when Schwinn was still US owned and tried one last time to compete. Nothing says 90's like GripShift and AceraX came out in 95, and that is what I would guess for vintage. The cranks look like they got swapped out some time ago.
#7382
Liked 759 Times
You may find a date stamp with a leading "G" in one of the rear dropouts. That would bring near certainty to the notion that it was produced by Giant.
#7383
Quoted: 13 Post(s)
Liked 23 Times
Thanks hokiefyd. I'll check. ................. Checked. Nothing anywhere except the Schwinn emblem stamped into the frame.
#7384
Quoted: 576 Post(s)
Liked 1,001 Times
I think you're correct on all accounts DorkDisk. It is a '95 and not one of the upgraded models. It came from a bicycle shop in Ohio judging by the sticker on the frame. I hadn't noticed the crank as not being original but I think you're right. And it was likely an improvement. Nice to know it was built by Giant. Thanks for the added information.
Here are a few relevant pages:
IIRC that crankset was recalled by Shimano. It was a close ratio'd triple for urban riding
Edit: crank recall
Likes For DorkDisk:
#7385
Quoted: 13 Post(s)
Liked 23 Times
Found the 95 catalog here.
Edit: crank recall
Edit: crank recall
Edit: Those listed in the PDF show aluminum frame. My Schwinn Searcher is actually more to the description of this from BikePedia. 95 Searcher BikePedia which still shows a round tube tig-welded steel.
#7386
Quoted: 576 Post(s)
Liked 1,001 Times
Thanks DorkDisk. I'll save the link to that PDF. Looks like they were really pushing the Searcher in the mid 1990s. The original crank listed is a Sugino Impel 300. BikePedia has it listed as a "SR alloy". The replacement Shimano crank presently on mine is a FCTY30 which, thank goodness, was not one of those recalled. I'm enjoying this ride for now and will likely try to keep it going for a few more years. Thanks again for the helpful information.
I also wasn't clear, I was referring to the original crank the bike came with-which explains the swapped crank. Sorry for that.
Impel 300 was a high quality crankset that was OEM for several years at various price points because with nice Al rings, it was as good as XT, a hair lighter, and much cheaper.
Likes For DorkDisk:
#7387
Quoted: 13 Post(s)
Liked 23 Times
I think you are confused, the relevant pages are posted above. They show a steel frame with crank specs contradicting some photos
#7388
Quoted: 576 Post(s)
Liked 1,001 Times
You are correct DorkDisk. I was looking at the wrong page in the pdf. My specs were on page 34 under Searcher Transit. Apparently it has a high tensile steel frame. As the models go higher end it looks like more chrome/moly was added. I'm learning that there's a whole lot to learn about bicycles. Between you and my local bike shop I've learned a lot this week. They did a great job replacing a spoke and truing the rear wheel. I installed the new brake pads. It took a while but I finally got them adjusted correctly. Funny the replacement pads were made by Giant. They worked fine though. Thanks again for the helpful information.
#7389
Quoted: 13 Post(s)
Liked 23 Times
After a closer look DorkDisk, it does seem to be the '95 Searcher Range. Acera deraillers, Shimano brakes, grip shift, rack mount eyelets and the emerald green color are the details that line up with the Range rather than the lower-cost Transit model. Good info. Thanks again .......... Greg
#7390
1996 Trek 7900 Composite Multi Track
1993 Univega Via De Oro
Been digging 90s Hybrids recently. These two are some of what I recently got. The Trek was a full build from the bare frame up.
As for the Univega, it was a curious buy after reading much about the brand and its hybrids in this forum.
Likes For concordino:
#7391
Bikes: 2014 Avanti Cadent ERII 2, 2013 Trek DS 8.4, 2008 Norco Wolverine
Quoted: 16 Post(s)
Liked 5 Times
After losing my 2013 Trek DS 8.4 in Vietnam....
Finally ended up replacing it back in Oz with a second hand 2017 Giant ATX. Frame was a bit big but shortened the cockpit as much as I could becuase it was too good a deal to pass up.
Found a better fitting frame and have swapped everything (plus some donations from other bikes) across. Meet Frankenbike, a nice start for upgrading 😊. First upgrade a new set of Kenda Small Block 8 2.1". New shoes for my baby. 😂
#7392
Liked 759 Times
I've been riding my late-'60s "hybrid" lately, Peugeot UO-18 mixte. I've converted it to 622mm wheels (700c) with 35mm tires and have more modern drivetrain components on it that still match the style ('90s Shimano 105) with a Sugino crankset. The main thing I need to find still is a chain guard to replace the largest ring. I'm using it as a 26-38 double. The cassette is an 11-26 7-speed using 8-speed Dura-Ace sprockets with 7-speed spacers. It's a bit cobbled together, and all parts were used or on-hand, but it makes for a really fun ride. Riding this bike just brings you back to the basic elements of riding somehow. It's essentially the late-'60s version of what something like the Specialized Roll is today.
IMG_20190629_092029483_HDR by jnjadcock, on Flickr
Likes For hokiefyd:
Likes For vader957:
#7396
Quoted: 1218 Post(s)
Liked 298 Times
I picked a 1991 Schwinn Crosscut up for $75 and it was beat to heck. Too many years in a high school bike rack. I had it Powder coated , and then I uhh got carried away. So basically shimano XT 10s , hydraulic rim brakes.
It is a super fun geometry though,
and Giant manufactured.
Likes For Metieval:
#7397
Quoted: 576 Post(s)
Liked 1,001 Times
I dig it!
Nice build.
#7399
Quoted: 13 Post(s)
Liked 23 Times
Looks great Metieval. I think what I like the most about my Searcher is the frame. Your build gives me some good ideas for future improvements.
