Can I put mountain bike tires on my hybrid and get a hybrid mountain bike?
View Poll Results: Can I turn my hybrid into a mountain bike?
Yes.
15
55.56%
No.
12
44.44%
Voters: 27. You may not vote on this poll
Old 02-05-12, 03:03 PM
Imperton
Hello!
I want to get into mountain biking, but I don't have a proper mountain bike. What I do have is a hybrid bike with 700c wheels. Can I put some 29" knobby tires on my hybrid and make it into some sort of mountain bike on the cheap? This is my suspension fork, but how much MTB tire can I fit in it? And will it work turning a hybrid into a MTB with better tires, or should I just quit being dumb and fork out the money and get a real MTB?
Imperton is offline
Old 02-05-12, 03:07 PM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,243 Times in 621 Posts
Can you post a link to your bike?
Fred "The Real Fred"
10 Wheels is offline
Old 02-05-12, 03:17 PM
Imperton
It's a norwegian sporting goods store bike, so I can't find it online. I do have the list of the specifications though, if that's any help.
Imperton is offline
Old 02-05-12, 03:21 PM
jimc101
Quoted: 453 Post(s)
Liked 104 Times in 87 Posts
You've really got 2 questions, first, can an MTB (29er) tire fit on Hybrid rims, the answer for this is probably, both are 700c, and dependant on the bike spec. the hybrid rims may be wide enough, all depends on what you have, if they will fit in the frame, that depends on your frame and how close th clearances are.
the second question, can you use a hybrid as an MTB, the realistic answer for this is no, the fork & frame you have will be fine for smooth tracks, but go off road properly, and it will show it's limitatons / start to fall apart quickly. If you want to get off road, get a purpose built MTB, but getting one which will do the job properly won't be a budget option.
jimc101 is offline
Old 02-05-12, 03:24 PM
3speed
Quoted: 363 Post(s)
Liked 28 Times in 22 Posts
What's the name/model of it? And specs would help. Especially the kind of fork. Long story short, I expect if you plan riding rough trails then 700c hybrid wheels wouldn't hold up to the abuse. I would think you'd be truing them constantly until you finally folded them in half.
3speed is offline
Old 02-05-12, 03:33 PM
Imperton
The fork is a Suntour SF10-NEX4610 V2 MLO 700C and the rims are Weinmann XTB26. I will probably buy a proper(and expensive) mountain bike then and keep the hybrid as a cheap road and transport bike.
Imperton is offline
Old 02-05-12, 03:37 PM
stevel610
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times in 240 Posts
Yes you can. Just make sure the width will fit, a local bike shop should be able to tell you. What you are doing is what they did to make the first Cyclocross bikes. I like the idea (in a way) of riding it hard until the fork needs rebuild/replace. By that time you will have a good idea whether or not it is for you. Particularly if its a dept store bike. Just be aware that if you put really wide tires on narrow rims, you will need to keep the pressure down so you wont crack the rim. Yes, I've learned the hard way. Good luck.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
stevel610 is offline
Old 02-07-12, 11:01 AM
ColinL
Two-Wheeled Aficionado
ColinL's Avatar
Bikes: Santa Cruz Blur TR, Cannondale Quick CX dropbar conversion & others
Liked 5 Times in 5 Posts
I have done this. It was relatively hard to find a rear tire that cleared, which in my case I settled on the Bontrager 29-3 29x2.0" tire. It is well-known to run narrow, about 1.8", and doesn't have knobs that stick out to the sides.
The front was far worse because my bike has a 80mm Magura/Cannondale headshok fork that I believe was meant for a 26" MTB, not a hybrid or 29er at all. There is plenty of width, but hardly any room in the crown. I have a 19mm wide rim, which could be a factor as well. One would expect a tire to bulge upward slightly, increasing diameter, when mounting a tire on a narrow rim compared to a wider one.
I couldn't even fit tires with a low profile knob, like a WTB Nano(raptor) 29x2.1, Kenda Slant Six 29x2.0, or Specialized Fast Track LK 29x2.0.
Eventually I solved this with an oversized cyclocross tire: Schwalbe Smart Sam 700x45. The casing has less volume and even though it's pretty wide, the sidewall and tire diameter is less than any 29er tire. Having gone through a lot of hassle with the front tire, I would just buy a pair of the 45mm Smart Sam and call it good enough. They should fit most hybrids with a suspension fork. (If you have hybrid that's more like a flatbar road bike, like a Trek FX, they usually can't do more than 35mm cyclocross tires.)
Now I'm saving up for a full suspension 29er. Salsa Spearfish, Giant Anthem X 29er, something like that.
ColinL is offline
Old 02-07-12, 11:04 AM
dminor
Moar cowbell
dminor's Avatar
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times in 5 Posts
Originally Posted by Imperton
. . . or should I just quit being dumb and fork out the money and get a real MTB?
This.
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
dminor is offline
Old 02-07-12, 11:19 AM
ColinL
ColinL's Avatar
Originally Posted by dminor
This.
Tires are much cheaper than a 29er. If you can buy a 29er right now, do it. If you can't and the tires are what is keeping you off singletrack, get the tires and save up.
But I do agree a hybrid with small 29er tires is not a long-term solution, or anywhere near as effective as a real MTB.
ColinL is offline
Old 02-07-12, 11:41 AM
Burton
Certified Bike Brat
Burton's Avatar
Quoted: 5 Post(s)
Liked 6 Times in 6 Posts
Yes and no. The tire size would be limited by frame clearance but you could at least install cyclocross tires. The real issue is frame strength. Assuming you have clearance to fit 29er tires on your frame, a hybrid still isn't designed to take the kind of abuse that a full scale MTB bike is usually subjected to. So how well it stands up to use depends on how hard you use it.
Burton is offline
Old 08-23-17, 12:13 AM
Marion0222
Suntour NEX 700c
Hi just want to ask if I can use my 29 x 2.1 tyre on Suntour NEX 700c suspension fork.
Marion0222 is offline
Old 08-23-17, 03:52 PM
Squeeze
High Plains Luddite
Bikes: 3x8 & 3x9
Quoted: 215 Post(s)
Liked 92 Times in 54 Posts
I googled "Suntour NEX 700c maximum tire size" and found this: Bikeman SR Suntour NEX Suspension Fork: 700c, 1-1/8" Threadless Steerer, 63mm Travel, Linear Pull, Black
If those specs are correct, you can run a tire that's 79 mm wide. 79 millimeters = 3.1 inches.
Based on that quick google search only and no personal experience, it looks like a 29 x 2.1 will fit just fine.
Squeeze is offline
Old 08-23-17, 05:01 PM
NYMXer
NYMXer's Avatar
Bikes: Cannondale SuperSix EVO w Hi-Mod frame, Raleigh Tamland 1 and Giant Anthem X
Quoted: 352 Post(s)
Liked 8 Times in 6 Posts
While it will never be a serious off road Mtb, it can be capable of some beginner trails with better tires. Your suspension will then limit you more than the tire choice.
NYMXer is offline
Old 04-24-19, 03:23 AM
safire
Similar question - here's the exact bike
Here's my bike: cube nature 2015 hybrid (can't post the URL cos i'm new, need 10 posts according to admin). can I put mtb tyres on it to make it trail ready and ride it (almost) like an MTB? and if so which tyres would you recommend. Currently riding stock:
Specifications
  • frame Aluminium Superlite Trekking Cross Double Butted
  • color black white red
  • size 46, 50, 54, 58, 62; Trapeze: 46, 50, 54
  • fork SR Suntour NEX HLO
  • headset CUBE No. 10 semi-integrated
  • stem CUBE Performance, 31.8mm
  • handlebar CUBE Rise Trail Bar, 660mm
  • grips CUBE Performance Grips
  • rear derailleur Shimano XT RD-M772, Shadow, 9-Speed
  • front derailleur Shimano Deore FD-M590, Top Swing, 31.8mm
  • shifters Shimano Alivio SL-M4000, Rapidfire-Plus
  • brake system Shimano BR-M355, Hydr. Disc Brake (160/160)
  • crankset Shimano Acera FC-M391, 48x36x26T, BB-UN26, 175mm, Chainguard
  • cassette Shimano CS-HG200, 11-34
  • chain KMC X9
  • rims CUBE SX, Disc
  • front hub Shimano HB-RM33
  • rear hub Shimano FH-RM33
  • tires Schwalbe Smart Sam, Active 44x622
  • pedals CUBE Aluminium MTB
  • saddle Selle Royal Viper
  • seat post CUBE Performance Post, 27.2mm
  • seatclamp RFR Varioclose 31.8mm
  • weight 13,9 kg
safire is offline
Old 04-25-19, 08:11 AM
prj71
Quoted: 2975 Post(s)
Liked 1,181 Times in 771 Posts
Geometry for mountain biking will be a little wonky. If you wanted a mountain bike...should have bought a mountain bike in the first place.
prj71 is offline
Old 04-25-19, 08:27 AM
Riveting
Quoted: 590 Post(s)
Liked 445 Times in 260 Posts
Can I put 28mm tires on my mtb and tell my friends I'm riding a hybrid?
Riveting is offline
Old 04-25-19, 08:43 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
my favorite topic (but I'm not an experienced MTB'er)
I tried using my hybrid for unpaved trails w/ beefier tires but kept pushing the envelope so eventually got mountain bike ( cheap one, used). much happier now. the hybrid was fine for most of the trails I wanted to ride, like unpaved rail trails, but some of the more rugged & unimproved, non-maintained trails were pushing my luck. once I got the mountain bike I discovered single track (the easy ones) which would have been even more of a stretch for the hybrid, even one w a front spring fork. so for me the immediate advantage was that front fork & even wider tires
I would say if you know you want a mountain bike, just shop for one you can afford. if you're on the fence, then experiment with your hybrid. experimenting w diff. tires is fun!
one can find trails that suit the bike or one can find a bike that suits the trails. I kinda mucked around w a little of both!
my hybrid w rigid front fork was fine on this stuff w 45mm Riddlers
but for this I'm much happier w 2.25" Riddlers & a cheap spring front fork
rode this trail twice, once w each bike. both were fine, but the MTB was better
this is a nice example of a wide tire hybrid trail
this is borderline but your front shock would help. my hybrid did not have that, so it was kinda brutal
got thru this softer sand section w the hybrid by airing down considerably, but the MTB handled it much more easily thanks to the wider tires
hybrid is fine for this kinda thing
rumrunn6 is offline
Old 04-27-19, 08:13 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
This thread is 7 years old.
Kapusta is offline
Old 05-05-19, 04:35 PM
grubetown
grubetown's Avatar
Quoted: 110 Post(s)
Liked 24 Times in 21 Posts
@safire resurrected it!
grubetown is offline
highrpm
General Cycling Discussion
4
06-06-16 06:59 PM
nitinverma71
Hybrid Bicycles
0
07-17-15 03:33 PM
GordoTrek
Hybrid Bicycles
8
03-09-12 12:02 PM
mikeschn
Hybrid Bicycles
51
03-05-11 04:30 PM
LatinoHeat
Hybrid Bicycles
8
05-28-10 10:32 AM
