Dynamo hub
Bikes: Surly LHT
Dynamo hub
Has anyone used one of these on a tour for the purpose of charging lights, iPhone (and maybe handlebar speakers?)??
Just wondering if any brands are recommended?
Do they cause any drag?
Do they keep said electrical items charged easily?
Would a solar charger be a better idea?
thanks
thanks
Gone.
https://www.peterwhitecycles.com/pedalpowerplus.asp
I would also be interested to hear from anybody with experience with these.
With respect to the hubs themselves, the gold standard is the Schmidt. Mine does not cause noticeable drag, and puts out plenty of power for a bright LED headlamp. A wonderful device.
Formerly Known as Newbie
There is also the new Supernova dynohub that can be mechanically switched off when you don't need it, reducing the drag.
In addition to the Pedalpower linked above Busch & Mueller have a couple of charging devices, the E-Werk and the USB-Werk. https://www.bumm.de/produkte.html
--J
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
There is good DIY project for an USB interface/loader based on a simple but quite effective cirquit:
https://www.forumslader.de/12V-Versio...USB.209.0.html
It's in german, but at least the schematic is international:
https://www.forumslader.de/fileadmin/...an_Z-Diode.jpg
If you'll need a translation of a dedicated part, just send me a message...
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I have used them to power lights and nothing else...yet. The drag will vary with the load and the quality of the hub. However even on the less expensive hubs on the market now the drag is not that noticeable. IMHO a dyno hub is going to be a better choice than solar, it will put out power as long as it is moving. With solar you have to have a certain angle and no clouds to get maximum output. The other option is to use the rechargeable battery packs. I know a couple of people that have used these with good results. They only have to recharge them once a week or so.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Randomhead
Liked 3,686 Times
intellectually, I know there is drag, but I can't really see any evidence of drag. I ride a dyno hub all the time now, I'd rather have lights available to me than worry about a minuscule amount of extra work. B&M is coming out with a light that has a usb port on it, but AFAIK, it isn't released yet and I haven't seen any tests of it.
The dynohub with a clutch is available under a number of brands, it's made by Shutter Precision and Velo Orange sold it for a while. It weighs quite a bit more than their other hub, and I don't see the advantage of the clutch.
Quoted: 33 Post(s)
It is funny when you get a new set of uber hubs with cartridges in them and you turn the axle, they are sticky. But build them out, and you don't feel them when they are being turned by a big wheel, is that the kind of drag we are feeling here, or are we talking feeling it in the pedals? if slightly.
I don't care about light for touring. It is never enough for my potential uses, like driving at night. I get by with the simplest of LED lights for what I do get up to. I don't use a lot of electronics, but if I could recharge my stuff I would think about using more, so a USB hub of the rolling kind would be cool. Since they are fat anyway, a USB dyno hub with the same spoke length as a Rohloff would be pretty neat.
Quoted: 33 Post(s)
An OT question, but I think the people who know the answer may be here. Pre-LED the hubs developed X potential to drive those lights. Now people want to charge their USB stuff, so I doubt there will be a desire to drop the potential much. But if you just ran the generator system for lights, you could get the same amount of output we had with incandescent lights out of LEDs, for maybe 1/10th the electrical load. So the question is, what are the new LED generator light systems like. Do they just blow the old incandescent systems out of the water, or are they the same general light level, and the same general resistance on the pedals?
I used to have a fancy German system on a recumbent bike, and it ran off the tire. That would be a perfect technology to run at normal light levels, but with LEDs and with very much reduced drag, because those systems do let you know they are there, and they can badly wear your tire. But if they had near zero drag, they would be a real option for someone who just wanted to run lights.
My approach is to use mine in combination with my SON 28 on my Surly Long Haul Trucker to power my Garmin Edge 800 during the day and in camp to boost charge my iPod Shuffle/Samsung Galaxy S2 phone/iPad as necessary. This was working okay on my last tour until the PedalPower+ Super-i-Cable starting playing up.
If you are interested my review of the PedalPower+ Super-i-Cable can be found at Aushiker.com and my approach to touring with an iPad at the same blog.
On the question of drag. Well my SON 28 is built into the front wheel of my touring bike. If there is any drag I am not noticing it given the bike weight etc. I also have a Shimano dynamo waiting to played with in anger on my mountain bike. That hopefully happens next week.
Regards
Andrew
Quoted: 70 Post(s)
Liked 15 Times
Another huge advantage to the LED lights is no burned out bulbs, or blown bulbs because you over powered them on a downhill. On my city bike the light actually powers up enough at a walking pace to provide lighting to see by.
Aaron
Bikes: Colnago C50, Specialized TriCross Carbon
[QUOTE=MassiveD;14812113]It is funny when you get a new set of uber hubs with cartridges in them and you turn the axle, they are sticky. But build them out, and you don't feel them when they are being turned by a big wheel, is that the kind of drag we are feeling here, or are we talking feeling it in the pedals? if slightly.
I just had a SON 28 rim built by Peter White. When you spin the wheel it will barely spin a complete circle and you can feel the grabbyness of the magnets in the hub.. The hub has numerous magnets inside the hub that have opposing polarity magnets and as you spin the wheel unloaded you can feel the drag very easily.. but once the wheel is on the ground and spinning I cannot feel any difference over a standard non-generator wheel.
Gone.
Did a short tour along the Danube on the Serbian/Romanian border last year, and didn't figure I would need a light, as I was planning on short days, all in daylight. I brought my Edeluxe anyway, and I was glad I did: the route is punctuated by half-kilometer long, curving highway tunnels with no lighting. Scary enough with the light, but it would have been really dangerous without. And there was no alternate route.
Quoted: 22 Post(s)
If going for convenience, and charging at low speed, best I've found is the Plug 2+:
https://www.sjscycles.co.uk/tout-terr...ice-prod27695/
Get a USB socket on the headset, charges at low (though not mountain-climbing-low) speeds.
I used a hub generator coupled with an E-Werk and a small storage battery for all of my power requirements while riding the Northern Tier in 2010 -- I never plugged in. This included my camera batteries, an iPad from which I wrote a daily blog entry and my cell phone (in addition to some headlight and tail light use).
Here's the blog, if interested, which includes a complete parts list and a description of how I did the power management: https://hpscott.wordpress.com
I did this at least partly just to see if I could, and there were many times for which things would have been far easier had I just plugged in while eating at restaurants and staying in campgrounds. That said, it did indeed work.
Were I to do this over again, I'd probably use the charging equipment again, but I wouldn't be so strict about never plugging in.
Quoted: 27 Post(s)
About to go with Front Rear B+M CYO T Senso Plus headlight, B+M Secula Plus taillight and B+M USB Werk to a smallish cache battery. I have a Shimano Alfine Hub.
I'm struggling with the wiring set up. I understand I should use a switch but my tiny brain can't sort out what wires go to what and where the switch goes. I have these pictures but I find them confusing as there seems to be extra wiring.
Anyone have advice, a simplified wire diagram or description? Much appreciated!
Quoted: 92 Post(s)
Had a Rivendell Bleriot 650b that I built a set of wheels for. It was a SON 28 hub and it is/was as "notch(ity)" as described above as well as smooth as glass once rolling. I already knew this going in as I researched ahead of time and spoke to Peter White about it. I paired that with a Schmidt E6 Halogen and at the time was quite fine. Am building up a new "Enduro" bike albeit am ditching the Schmidt hub in favor of a SP Dynamo PV-8. Reviews and a couple of decades of Chinese product use clinched my decision to have a quality Dynohub at a minuscule cost. LEDs are the way and I have a Schmidt Edelux ready to be paired with this after I build the wheels. In any case, Dyno's are fantastic. You most definitely can pair a light and charger to the Dynohub. Busch and Muller makes the Luxos U which has a USB port to charge your phone. Technology is wonderful.
Quoted: 9 Post(s)
Here are some links I found helpful when researching this matter recently.
https://www.cyclingabout.com/best-hub-dynamo-system/
https://www.cyclingabout.com/best-dy...fer-batteries/
https://www.cyclingabout.com/list-of...r-usb-devices/
https://www.cyclingabout.com/best-dy...g-bikepacking/
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 9 Times
In addition to the information provided here, I would suggest that you use the search function. Tthe subject of powering batteries and other devices from a dynamo hub has been discussed quite a bit in these forums.
Lots more here: https://www.bikeforums.net/electroni...hting-gadgets/
Bikes: Trek 520 total custom build, Cannondale Mountain Tandem, Oryx Mountain Bike
Quoted: 61 Post(s)
Liked 6 Times
dynamo
thanks
thanks
IMO, a solar charger is a no go. Auxiliary Battery power is so easy to come by and charges items several times before they themselves need to be recharged. A dynamo needs to be constantly going at 12-14 mph. That is why it is not good at charging in the mountains. You'll charge going downhill, maybe but there is a lag before charging actually starts. Great for powering lights, maybe not the best choice for charging electronics.
I have for the last 4 years a Schmidt Dynamo Hub, from Peter White actually. And a Toplink Brake pro plus. You won't feel any drag. Do they keep electrical items charged easily-depends on where you're cycling: prairies or mountains. In the mountains forgetaboutit. On the prairies, no problem.
Practically speaking though, I've done some really hilly tours and my setup kept my phone at least topped off on the hilly days, that is with the phone in airplane mode, no music. On flat to moderate terrain I could rock out with music and still get a charge.
My setup is as follows:
SP front hub
B&M Luxos U front light w/USB
Tail light...I think it's a B&M, not 100% sure.
Works great, get a charge on my phone to listen to music OR can use the light but it doesn't seem to want to do both. Hilly terrain will keep phone topped off but not charge it up. Flat to moderate terrain it works great. Front and rear lights work great over hilly terrain, although they do dim a bit when going up steep hills.
SP front hub
Bikes: Two. One daily rider. One with detachment issues.
Quoted: 53 Post(s)
Between a 10,000 mAh battery and what my dynamo can add, I can go a week between outlets. Strongly suggest pass-through battery packs as they can charge devices while charging themselves.
I use a Son 28 dynohub, paired with a Cycle2Charge unit on my handlebars, feeding an (external) battery pack.
I use the hub to either power a front light or charge the battery, never both at the same time.
I prefer not to charge electronics directly from the hub.
A day's riding will generally recharge my gps & phone with enough left over to top up my kindle or recharge some aa/aaa batteries.
I find that once I'm over 13 kph I'm generating power.
One factor to consider when considering a dynohub is wheelsize! I don't often see it mentioned in discussing the merits of 26 vs 700, but a 26 inch wheel produces more power than a larger wheel at the same speed, or produces power at a lower speed in comparison to a larger wheel, if you prefer.
I also carry a fold out solar panel on longer trips (from before I got the dynohub). Strapped on the back of the bike is not the most effective, but once still it does a reasonable job, excellent in direct sunshine. Since I like to stop often it supplements the dynohub nicely
What pass-through battery packs do you use?
Frank
Frank
