Galmozzi Super Competizione frame
Quoted: 36 Post(s)
Liked 13 Times
Does anyone know how to interpret the embossed number and dot]s] on the underside of the bottom bracket, which is also repeated on the fork steerer-tube please ?
Could the number refer to the last digit of the year it was built and the number of dots referring to the actual person who built the frame ?
My frame and steerer-tube has a either a 6 or 9 and four dots.
Thanks.
Thanks.
Quoted: 835 Post(s)
Liked 2,135 Times
I’m not sure about the decoding, but I sure would like to see pictures of your Galmozzi! I’m also curious about this dot pattern you mention.
Quoted: 4513 Post(s)
Liked 6,388 Times
Thanks.
Thanks.
Liked 6,388 Times
Quoted: 36 Post(s)
Liked 13 Times
This frame is currently being refinished and I will post photos when finished.
I am now 99% certain, having seen an unrestored 1960's frame with provenance, that the number refers to the 6 = 1960's, 7 = 1970's etc.
From this I presume that the number of dots equal the month, 1 = January, 4 = April etc. or that the number of dots might refer to the quarter of the year, 1 = January to April and 4 = September to December etc.
Unless you know differently !
Liked 6,388 Times
So far it seems no one knows any more than you so not sure where it goes from here, we have seen very few Galmozzi's here and even less discussion of serial numbers.
I would like nothing better than someone to chime in and explain this in great detail as normally happens with many other marques.
Quoted: 1079 Post(s)
Liked 1,899 Times
GALMOZZI - FRAMETELLER
This one has four dots in a square configuration without a number (as far as I can see): https://www.bikesretro.com/wp/produc...ne-60/?lang=en
This one has the frame size (52) but no dots (as far as I can see): https://steel-vintage.com/galmozzi-c...le-1970-detail
This one doesn't appear to have anything: https://steel-vintage.com/galmozzi-c...me-1960-detail
This one has the number 1 and six dots up at the front of the lug: https://www.ebay.com/itm/12508092235...=true&siteid=0 Seller seems to think it has something to do with the racing team numbering (if my translation is accurate. Perhaps 'Squadra Corse' is just referring to the model.)
Quoted: 116 Post(s)
Liked 376 Times
I can't help you but a neighbor of mine quite a while back had three Galmozzi race bikes in his stable. He was originally from upstate New York but had traveled and worked many years in Europe, so not sure where or when he acquired them. I can clearly remember he has a deep metallic red one, a silver one, and one that was a color very similar to Bianchi's celeste green.
Quoted: 1858 Post(s)
Liked 606 Times
My Galmozzi has no markings at all on the BB. I have only seen a few but none had anything on the BB.
As others have said more pics of the naked frame would be helpful.
