Help with my 3 piece crank
i have a haro f3 completley custom with nothing stock on it but its crank and i wanna change it but its been on there for 2 years since i got it and its really hard to get the bolts loose i need suggestions on how to get the bolts loose
Bikes: 2004 Dk 4-pack
Muscle Use leverage longer handle. Also try liquid wrench i have never used that bfore so i don't know if that will help your problem.
Your imaginary friend.
Bikes: A sweet Quamen ATL custom, GT Mach 2
Lefty loosey, righty tighty.
Every passing minute is another chance to turn it all around.
Bikes: Specialized fuse 4 bmx
im not reccomending this, but what id do, is get a longer allen key, and a hammer,
im sure you can see where it goes from there.
it worked for me
it worked for me
Yeah. I Race.
Bikes: Custom Race, 2007 GT Bump, 2007 Gt Powerseries Pro, Dyno VFR
I've had to do that, too. It's pretty common. Or you can (not recommended) put the enclosed side of the wrench on the end of the allen key and use it as leverage.
Live To Ride Ride To Live
Bikes: Fit flow
Liquid wrench.... And heat... Use a torch or a lighter. Torch would be better if you have one liquid wrench wont catch fire... The heat will make the crank threads expand enough for the liquid wrench to get down in to the threads.
Yeah. I Race.
I don't think a lighter would heat it up too quick there, skippy. It would take quite awhile.
partly metal, partly real
Bikes: Hummer H2
an good allen key and a four foot bar (1") for leverage. it's what's used in shops.
also, do you really need to say 3 piece crank? it's safe to say that unless you're eight, you're not riding a one piece...
Yeah. I Race.
