SILCA Super Pista Question.
Bikes: Too, too many....
Quoted: 125 Post(s)
Liked 130 Times
A couple of years ago I was given this scathingly brilliant old SILCA pump by a woman who was cleaning out her garage.
The SILCA air pressure gauge goes up to 16 bar (250 P.S.I.).
Can anyone tell me the approximate age of this pump ?
I read on the internet that the older Super Pista pumps ( before the 1950s ) had wooden handles and Columbus tubing.
Is it really possibly that old ??
Any idea of the approximate value ?
Bink.
Bink.
Industry guy
That graphic was available in the late 1980's for sure. Whether is is any older?
My personal Silca floor pump(orange in color) has a foil decal. It is from the late 1970's.
The parts to rebuild and maintain this are all available.
New, this pump sold for almost $100.00
Quoted: 4722 Post(s)
Liked 3,036 Times
I've seen Silca with date codes on the bottom of the gauge. However, I believe the gauges were procured items and not manufactured by Silca. So, if they used multiple sources, not all gauges may have date codes. Also, depending on how strict they were about rotating stock, the gauge could be older than the pump. However, it is likely quite close.
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 335 Times
Mid 80's likely. I had that pump from the later 80's and the design and gauge was all the same except how that handle looked. Take good pictures and email people at silca.cc, they are super knowledgeable of their product. I had to call them for parts for mine and were able to let me know more about it. American owned now instead of Italian (I think).
I lost my pump though on the Leadville 100 back in 2000, lovely pump.
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
It's a mid 80s pump, hard to get any better granularity on date than that.
this model in my opinion is the best ever.
As for value ? Well, these things go for between $20 and $100 on ebay. It's one of those things whose utility value (as a pump) far exceeds its market price.
Put a rebuild kit in it and will last a lifetime ! Parts are available from Silca.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Quoted: 125 Post(s)
Liked 130 Times
Mark Petry
Mark Petry
Thanks, guys. I just sent off a note to SILCA (with a couple of pictures) asking for information about the pump and information about getting a seal kit in case it ever needs to be repaired or rebuilt.
Bink
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times
I have that same pump, believe I bought it in 1988. Other than replacing the valve head gasket a couple times, has never required a bit of maintenance.
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
Here's a link to the rebuild kit. You may not need the guage, but definitely replace the chuck gasket and the leather washer (piston) inside the pump barrel. The new Silca hose is FAR better than the old one, well worth the upgrade. I also at least inspect or if necessary replace the check valve, and replace the O-ring at the base of the barrel (this part is not sold by Silca.)
https://silca.cc/collections/replace...kit-242-gasket
Mark Petry
Mark Petry
Bikes: 1986 Cannondale SR600
Quoted: 20 Post(s)
Liked 7 Times
Earlier Columbus tubed pumps had a Columbus decal on them. I don't know whether later pumps without the decal still had Columbus tubing or not, but suspect they didn't.
Quoted: 380 Post(s)
Liked 541 Times
There is nothing special about Columbus tubing. Columbus steels were used for everything under the sun in Italy. It it didn't have a Columbus steel tube that would be notable!
