Desperately seeking 10x1x130mm axle for 80's Sunshine/Sansin road hub
Desperately seeking 10x1x130mm axle for 80's Sunshine/Sansin 5 speed road hub
Would buy complete hub just for axle, but cannot find exact replacement, 36H, 120mm OLD.
I'm at the point of fantasizing about welding/or brazing the broken axle back together.
Quoted: 5840 Post(s)
Liked 2,673 Times
I don't know how you measured, so I suspect you want either a 131mm axle for a 120 hub spacing, or a 141mm axle for 130mm spacing. The general rule is axles are 11mm (5.5per side) longer than the hub spacing measured lock nut to lock nut.
FWIW - 131 and 141mm axles are very common so once you use the right search criteria you'll be in like Flint.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 520 Post(s)
Liked 461 Times
Likes For grumpus:
It's near impossible to log on this site, the computer generated passwords are deemed invalid, over and over and over again.
Trying to post in response sent me back down the same rabbit hole of password resets again.
Yes, 131mm axle for 120mm ODL, near unobtainium.
Our local Co-op has a tray with several dozen 10 x 1 x 145mm threaded rear hub axles. When I require something shorter, I take one of these ($2) parts and with a (metal) hacksaw blade cut them down to size. Takes less than 5 minutes.
Make sure you thread one of the cones onto the side you want to cut before the cutting. Immobilize the axle with a bench vice, and cut away. Then file the end of the axle smooth. Next, unwind the cone, which serves to chase the mangled threads on the cut side. Then do a light filing to finish. Make sure the side you cut has enough threads for the cones, spacers, locknuts etc.
Likes For Dave Mayer:
Quoted: 520 Post(s)
Liked 461 Times
Good axles are quite hard. I have an angle grinder holder that turns the grinder into a mini chop saw for a square cut. I use a slitting disc to slice the end off, then chamfer it on the bench grinder.
Likes For grumpus:
Liked 2,673 Times
Some things make me feel so old. Stuff I bought new and still ride is now apparently "vintage" and commanding outrageous prices.
Apparently 10mm steel axles are now in that category.
As suggested, consider buying a longer one and cutting it down. I suggest double checking the thread length by assembling into the hub as if installing it before deciding which end (or both) to cut.
Otherwise, if there's a long established shop or co-op in your community, go there first. They might not have an axle, but likely have an old wheel or hub collecting dust that they can sell for less than the price of an axle
Likes For FBinNY:
Quoted: 1950 Post(s)
Liked 2,187 Times
Here you go...
https://www.loosescrews.com/product/...le-10x1x131mm/
John
Edit added: Or if you prefer ebay..
https://www.ebay.com/itm/22510271159...Bk9SR4Toz_mDYQ
John
Likes For 70sSanO:
The problem I have with the aftermarket axle is lack of keyways for the slotted washers.
I'd prefer to use keyed washers, but the likelihood of slotting an axle seems iffy.
The aftermarket axle I have here has very short slots, just on the outside and my races seat quite far in, narrow hubs.
My old races don't jive with the threads on the new axle, if only I have a tap/die in this size, maybe I could make it work by rethreading the cones.
Weirdly enough, the locknuts spin on just fine, but the races/cones no go.
Murphy was an optimist.
Liked 2,187 Times
Likes For 70sSanO:
Liked 2,187 Times
John
Likes For 70sSanO:
Half way there
Quoted: 990 Post(s)
Liked 884 Times
I think I have a Sunshine high-flange rear 5 sp hub in one of my parts boxes. I'll look.
Likes For Moe Zhoost:
Liked 2,187 Times
I remembered that Loose Screws also sells on ebay. After you determine if it is 10mm or 3/8", here is the listing...
https://www.ebay.com/itm/26462897655...3ABFBMwMaegIRh
John
John
Likes For 70sSanO:
Quoted: 3560 Post(s)
Liked 2,976 Times
Likes For smd4:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 741 Times
Likes For maddog34:
Clark W. Griswold
Quoted: 4415 Post(s)
Liked 4,060 Times
I doubt there is any conspiracy however tech issues are very real.
Likes For veganbikes:
Likes For dsbrantjr:
Really Old Senior Member
10mm is .394" vs .375" for 3/8".
ISTR that cones from one will screw on to the other, but not the opposite way?
A 3/8"x 24 (SAE) bolt screws into a 10mm x1mm nut no problem, but not the other way.
Likes For Bill Kapaun:
Quoted: 18399 Post(s)
Liked 4,526 Times
Note, for the first 2 days you can only do 5 posts a day.
I usually only have to log in once every few months. The system is pretty good at remembering me on my PC, or phone.
As mentioned above, I always click "Remember Me" when logging in.
Be careful of the caps-lock, and be careful of how you enter your password. Write it down if necessary.
Likes For CliffordK:
Liked 4,526 Times
I have a little diamond disc from a chainsaw sharpener at Harbor Freight. I find it handy to polish the ends of cuts like I would get on an axle, or cutting cable housing.
Or polishing tips of tools. It has been quite handy. Unfortunately I don't have a tool rest with it, but may make one sometime.
It's been rough living with the imposed 5 posts in 24 hours but the info here makes it worth it.
I did find out that the axle the bike shop sold me is 3/8" x 26TPI, courtesy of my thread gauge.
I have the Shimano one on the way from LooseScrews off eBay.
Quoted: 303 Post(s)
Liked 137 Times
submit reply and then wipes out your post. If the back arrow doesn't recover (usually not) you can take the simple precaution of
highlighting your post and doing a copy with Control C and paste when you log back in. This happens to me when I google something
to check a fact or info mid post.
Likes For sch:
FWIW: the 5 post daily limit for new members (and 10 post limit for posting links/photos, send/receive PMs, probably a few other things) isn't there to "harass new members" - it's there to keep spammers at bay. You're most of the way towards being able to do those things.
Please do let us know how things turn out with your issue. One thing many people who solicit advice don't do is "close the loop" after fixing their problem. It helps to know what did and didn't work - posting that may help someone else solve the same or a similar problem.
Likes For Hondo6:
