Is there supposed to be a cap on the inside of the fork?
I checked a bicycle of mine and the front fork has a lot of rust in the area at the very center. Is there supposed to be a weather sealant cap of some sort there?
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 168 Post(s)
Liked 153 Times
Doubtful that any sort of cap would prevent rust, in fact more likely to contribute to it owing to lack of ventilation.
If you don't want rust forming you want to protect the metal in some fashion. Paint, powder coat, even a healthy coating of wax or grease up in there will help once extant rust has been cleaned out.
Or be diligent in preventing / removing moisture from remaining in place once it finds its way in there. Low humidity storage helps a lot as does a layer of physical protection that doesn't trap moisture against the metal underneath.
In the Periodic Table of Elements, oxygen (O) and iron (Fe) are just made to come together whenever and wherever they possibly can.
Quoted: 4227 Post(s)
Liked 2,491 Times
I have full fenders on my bikes so it helps to prevent most of the road spray from getting inside...but even if you don't have fenders don't worry about it.
Quoted: 2393 Post(s)
Liked 2,947 Times
have never seen on in over 60 years of fiddling with bikes
Life is too short not to ride the best bike you have, as much as you can.
Quoted: 6351 Post(s)
Liked 4,953 Times
Might have been better to show us the fork on the bike that has the rust. That looks almost pristine.
Rust is not the big issue many think it is. Usually it's just surface rust on the unpainted parts of steel tubing. And leaving that hole open will let moisture out and keep if from pitting the steel which would be a bad thing. If you look around on steel bikes, you might find some small holes on the bottom of the stays, BB, inside near the fork ends and elsewhere. Those are weep holes. Again, so moisture can get out and not cause issues other than surface rust which is no dander at all. Surface rusting on some things is actually desired and considered a preservative.
Likes For Iride01:
Super Moderator
Quoted: 1174 Post(s)
Liked 936 Times
