Do you pack tools and a spare on your SS or Fixed?
Not lost wanderer.
Quoted: 885 Post(s)
Liked 989 Times
Yes, a 4mm, 5mm, and 6 mm allen wrench, 8mm, 9mm, and 10mm box and open end wrenches, a 14/15mm combo open wrench
a small screw driver.and a rag
a tube that fits the bike.
ABQ
OP's real question is "Are you self-reliant when riding your bike?" Well, I am, and I don't stop for people who aren't. I only offer help when I see that the rider appears to have everything they need, AND knows what they're doing. If you're standing there looking lost , or pushing your bike along, I will pretend you're not there.
What the hell kind of question is this? Do you just ride the sidewalks around your block?
Likes For Onfixiate:
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,985 Times
Quoted: 722 Post(s)
Liked 353 Times
i do.
i pack my waterbottle storage gizmo with everything i may need as i ride it in nyc..big city few shops.
Quoted: 3357 Post(s)
Liked 3,636 Times
Like pretty much everyone I carry the usual tire repair stuff. As has been alluded to, the benefit of riding nice supple tires is absolutely worth the increased flat risk. As an added benefit, in my experience nicer tires are actually easier to get on and off the rim than some super tough commuter tires, so even if you do get a flat it's just a minor inconvenience that takes just a few minutes to fix, sometimes even without tire levers!
An additional item I have started carrying is a small length of chain - like 2 or 3 links. If you don't have much flexibility in chain length given your wheel position in the track ends and tire clearance, having a spare few links and a chain tool could mean the difference between fixing a chain failure and riding home or being totally out of luck. Granted, with a properly set up and maintained drivetrain a chain failure is very unlikely, but I've had it happen before...
Liked 3,636 Times
I've seen some people do some wild things with hybrid gearing before but that's on a whole other level!
Clark W. Griswold
Liked 3,985 Times
Lets see, the Pinion is an 18 speed gearbox with a 636% range and the Rohloff is a 14 speed 526% hub...I don't even want to imagine what the shifting pattern on that would be
Likes For veganbikes:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
I think tools and a pump and reasonable tires weigh a helluva lot less that Schwalbe Marathon Pluses.
I have two Yellow Line Rule tool rolls. I don't think they are in business any more though, unfortunately. Really excellent tool roll that look retro but carry any tools you need. I carry a chain breaker, spoke wrench, PB Swiss multi-tool, Park patches and a spare tube. If I'm on a long ride I ditch the tool roll and carry just a spare tube, patches and the multi-tool in my jersey pocket.
Likes For drlogik:
Liked 3,636 Times
Likes For abshipp:
Clark W. Griswold
Liked 3,985 Times
I love it and hope to see more like it.
Liked 3,636 Times
I mean I had been thinking about that for a long time. It is kind of sad that is just an April Fools joke. If someone with some serious machining and design skills could take internals of the Rohloff and mate it to a 12 speed free hub and add a front derailleur for at least a double you could really have a few extra gears (a little over 6k to be fair)
Plus you may need to use fat bike rear spacing to get it all to fit and chainline might end up being a mess
Likes For abshipp:
Clark W. Griswold
Liked 3,985 Times
I don't think it would actually be terribly difficult to do - at least physically making the parts. The Rohloff uses a carrier for the cog and freehub body geometry is well defined so you'd just have to combine the two, plus a longer axle and you'd be pretty much there. I think the biggest concern would be axle strength since if you just made the axle longer you'd have a long unsupported length outboard of the bearings.
Phil Wood track hubs so I only need a hex key to remove wheels. Wouldn't be adverse to pulling out a tube while leaving the wheel in place if I had to. Spare tube, patch kit, small pump, and one tire lever in a under saddle bag.
Likes For Lakerat:
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Since I live in a very steep area, my ss (running tubes) is generally for my shorter "fun" rides, while the geared (tubeless) bike gets the long hauls. So on the ss I rarely take anything other than a multitool. If I think I'll be out longer then I grab one spare tube, lever, and a mini pump.
One thing I did recently as en experiment, is I added some sealant to my tubes on this bike. I ride this thing off-road 70-80% of the time--fire roads, singletrack....have not flatted since. Either it's working or I've just been lucky (and I've now totally jinxed myself).
Likes For pbass:
Quoted: 2432 Post(s)
Liked 638 Times
FYI, on my bike that has track nuts I carry a Park DCW-4 13/15 double ended cone wrench. They're used to adjust hubs. It's super thin and takes up almost no space in the bottom of my saddle bag. They're just long enough to get good leverage and they're really stiff. You can get them for less than $10.
