Today I (v2):
Old 09-12-16, 09:45 AM
  #19251
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Originally Posted by AristoNYC
Definitely. The shop was cool enough to offer me a bike to use in the interim, though I didn't need it.
The problem is that I don't even know. I was riding and the bike felt a little flexy so i got off and noticed the crack on the top tube. It is about 2-3 inches from where it meets the seat tube. Its odd that it not at a joint.
Point this out for interest..
https://www.bikeforums.net/general-cy...bon-frame.html
The thread gets derailed after a page or two but is the same sort of deal.
Guy had a "small crash' and found his frame cracked when he got up. He assumed that the crack was caused by the crash but could not explain the crash, said he "lost his balance." I believe that the crack was the cause rather than the result, that it cracked first and caused him to loose his balance as it flexed.
I'm glad you didn't go down or get hurt. Could have been much worse.
-Tim-
TimothyH is offline
Old 09-12-16, 10:18 AM
  #19252
klhada
Quoted: 17 Post(s)
Liked 9 Times in 2 Posts
today I bought some new levers, to mount front AND rear brakes on my FG. I like to ride long distance with hills and don't give a damn about "street cred" or some BS like that.
klhada is offline
Old 09-12-16, 12:23 PM
  #19253
TimothyH
- Soli Deo Gloria -
Originally Posted by Leukybear
Just get another set and you'll have all the spares you need
They're pretty cheap nowadays considering how popular and mass produced they were back in their prime.
It definitely helps to let wd-40 or triflow to soak in before truing though. The common park tool mavic nipple wrench for it makes too much torque doesnt help either.
Help me out here. I'm asking out of ignorance.
I think more of these Ksyrium SL spokes are going to go. I could hear them making the same noise as the one that broke while soft pedaling home.
So I've been dabbing TriFlow on the spoke nipples for a few days under the assumption that more are frozen. I have a replacement for the broken NDS spoke have a source for more should I need them.
How long should I soak these things? A day or a week or a month? How likely is it that these will free up? Or is it a lost cause? Wont know until they are tried?
I realize you can't predict the future but what are your thoughts? I'd like to try to salvage these wheels rather than turn them into a coffee table.
-Tim-
TimothyH is offline
Old 09-12-16, 01:02 PM
  #19254
AristoNYC
AristoNYC's Avatar
Bikes: AristoNYC's PedalRoom
Quoted: 130 Post(s)
Liked 6 Times in 6 Posts
-Tim-
Thanks, I'm happy it didnt snap while I was riding. I actually rode it 10 miles to the shop to drop off but I wasn't bombing any hills or bunny hopping stuff.
Originally Posted by SquidPuppet
Weird. Probably just a defective piece of tubing. Does it run parallel with the tube or around the circumference?
Yeah, I'm hoping that I don't get any issues from Giant for a replacement. It was around the the tubing left to right, rather than front to back.
AristoNYC is offline
Old 09-12-16, 01:56 PM
  #19255
TimothyH
- Soli Deo Gloria -
FWIW, Bianchi did the right thing in the other thread and sent a replacement.
Hope Giant does the same. Your case seems pretty straight forward.
TimothyH is offline
Old 09-12-16, 05:53 PM
  #19256
Broctoon
Super-duper Genius
Broctoon's Avatar
Quoted: 768 Post(s)
Liked 984 Times in 508 Posts
Today I am getting ready to take an easy to moderate ride on level ground...
Saturday a friend and I did LoToJa as a two-man relay team. I rode legs 1, 3, and 5; he did 2 and 4. It took us just a few minutes over 12 hours to finish the whole 206 miles. I ended up with about 126 miles, including 3100+ feet of climbing. The highest point on the course, near the end of leg 3, is 7630 feet.
It was fun! Tough but fun, and worth the effort.
Broctoon is offline
Old 09-12-16, 06:11 PM
  #19257
Leukybear
THE STUFFED
Leukybear's Avatar
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times in 17 Posts
-Tim-
Is that sound being produced when the nipple is rotated in either direction?
Seized spokes on SSC ksyriums can be dicey as the corrosion created bond between the spoke/ nipple interface needs to be broken first. It is here when the spoke usually breaks. You're going to have be very patient and slow going with the following process for every problem spoke.
You do not want the spoke to twist. At first it is going to be inevitable when you're attempting to break the spoke loose from the nipple but you have to minimize it. While attempting to rotate the nipple, use a pair of pliers (if they're needle nose, use the inner wider portion) with a small rag in its jaw to clamp the bottommost fully bladed portion of the spoke closest to the nipple.
With the spoke held firmly in place by the pliers with one hand, in very small increments twist the nipple back and forth with the spoke wrench in the other hand. You will feel torsion on the spoke through the pliers for as long as the spoke is seized within the nipple. You will know if the spoke has broken loose when you no longer feel this torsion.
Seeing that triflow has not done much, you should try using something that is more geared toward unseizing things. A penetrating oil should give you the best shot at breaking free the spokes without breaking themselves. Try PB blaster, it is my go to.
Truth be told, mavic did a poor job in corrosion proofing the nipple and spokes of those wheels.
¿pɐǝɹ oʇ sᴉ sᴉɥʇ ƃuᴉʎouuɐ ʍoɥ ǝǝs
Originally Posted by veganbikes
Pound sign: Kilo TT
Leukybear is offline
Old 09-12-16, 07:22 PM
  #19258
TimothyH
- Soli Deo Gloria -
Thanks for this. I have not tried to twist anything yet. Not in a rush.
The red/bold makes absolute sense. If it is corrosion then the two pieces are bonded and there may not be much that can be done.
I purchased a few spokes just in case. If not then it will make a really nice coffee table.
TimothyH is offline
Old 09-12-16, 08:48 PM
  #19259
Broctoon
Super-duper Genius
Broctoon's Avatar
Quoted: 768 Post(s)
Not so! I don't have much experience with bicycle spokes, but I've a lot dealing with corrosion. Take Leukybear's advice to use PB Blaster. That and a little physical force--very judiciously applied--can work wonders for un-bonding stuff.
Broctoon is offline
Old 09-13-16, 05:53 AM
  #19260
TimothyH
- Soli Deo Gloria -
I decided to go for it last night.
Two nipples gave a slight pop as they broke loose but everything is like butter.
I Appreciate the advice.
TimothyH is offline
Old 09-13-16, 02:04 PM
  #19261
AristoNYC
AristoNYC's Avatar
Quoted: 130 Post(s)
Thanks. Got an email from the shop, Giant is going to be sending a replacement frame. Its going to take a few weeks and will be a different color, but still a replacement. I actually like the replacement color better.
Old 09-13-16, 04:31 PM
  #19262
TimothyH
- Soli Deo Gloria -
Same as the guy with the Bianchi. They are sending him a different color which he likes better.
TimothyH is offline
Old 09-13-16, 08:02 PM
  #19263
Mumonkan
Brown Jersey Winner
Mumonkan's Avatar
Quoted: 243 Post(s)
Liked 13 Times in 13 Posts
today im home from coloRADo
pretty much the greatest place ever.
Mumonkan is offline
Old 09-13-16, 09:04 PM
  #19264
SCK
Gold chains on everything
SCK's Avatar
Bikes: Heavy Pedal Zephyr, '16 Mash Work, '14 Cinelli Parallax, C-Dale Synapse Disc
Quoted: 17 Post(s)
I like it. It makes me wish I had considered a Giant over the C-Dale Synapse.
SCK is offline
Old 09-14-16, 08:03 AM
  #19265
Unkle Rico
Unkle Rico's Avatar
Bikes: CENTURION / LOOK / Bianchi
Quoted: 214 Post(s)
Liked 10 Times in 10 Posts
Sorry I didn't try to hang out with you good sir
Unkle Rico is offline
Old 09-14-16, 09:23 AM
  #19266
Mumonkan
Brown Jersey Winner
Mumonkan's Avatar
Quoted: 243 Post(s)
its quite alright, i had plenty of mountains to play with, lots of beers to drink, and pots to eat
Mumonkan is offline
Old 09-14-16, 09:53 AM
  #19267
SpeshulEd
SpeshulEd's Avatar
Quoted: 686 Post(s)
Liked 5 Times in 5 Posts
Agreed.
Also, did I lose you from instagram or have you not been posting much, I swear I never see your stuff anymore.
Hey guys, lets go play bikes! Strava
SpeshulEd is offline
Old 09-14-16, 11:42 AM
  #19268
Mumonkan
Brown Jersey Winner
Mumonkan's Avatar
Quoted: 243 Post(s)
Originally Posted by SpeshulEd
Agreed.
nah still there, i just really havent been computering that much in general. i got into some deep funk middle of summer that kept me off the bike, blog postage, internetmachines etc.
that and another pic i posted this afternoon are on the instantmachine
Mumonkan is offline
Old 09-14-16, 01:34 PM
  #19269
50voltphantom
50voltphantom's Avatar
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times in 47 Posts
Gave up beer for the two weeks prior to Jingle Cross and feel fitter than I have in the last 8 years. Go figure.
50voltphantom is offline
Old 09-14-16, 02:06 PM
  #19270
Carcosa
Carcosa's Avatar
Quoted: 332 Post(s)
Liked 4 Times in 3 Posts
How dare you suggest that beer is bad.
Carcosa is offline
Old 09-14-16, 04:02 PM
  #19271
seau grateau
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
seau grateau is offline
Old 09-15-16, 07:46 AM
  #19272
50voltphantom
Quoted: 481 Post(s)
Beer is awesome, but not when you want ride a bike whilst completely in the red for 40 minutes.
Old 09-15-16, 08:39 AM
  #19273
50voltphantom
Quoted: 481 Post(s)
I picked up a HED seatpost off eBay because I convinced myself I should use a aluminum seatpost instead of the generic carbon one I've been using. It arrived yesterday and it's totally cool, but now I'm not sure I want to use it because carbon. Suddenly I'm thinking about grams while riding a Surly.
Old 09-15-16, 04:28 PM
  #19274
cali_axela
Señor Member
cali_axela's Avatar
Bikes: All of them
Quoted: 31 Post(s)
The only grams you should be counting while riding a Surly are of the herbal variety
cali_axela is offline
Old 09-15-16, 06:40 PM
  #19275
seau grateau
Did 25 miles on some new roads today, good stuff. Going through Strava afterward I see that I got 26th fastest time on this one hill and the guy who owns the KOM on it apparently climbed a 10% grade at 30mph.
