Left hand drive internally geared hubs...
I have been searching for these online for some time and have come up dry. At this point, I can care less about brand, although I would like it to be free-hub style, no drum brake non-sense. 3speed is what I am shooting for, but for some reason, I can seem to find any production models that accommodate a left hand drive train.
In the case that no manufacturer makes a left hand drive internally geared hub, is there a way I can modify one? This seems ridiculous I know, but it is necessary for an upcoming build of mine. Suggestions anyone?
Thanks a ton!
-Mal
Thanks a ton!
-Mal
Bikes: Mobiky, PBW, Jim Redcay, old Chicago Schwinns
Sheldon Brown adapted a Sturmey Archer ASC 3-speed fixed hub to left hand drive:
https://sheldonbrown.org/gunnar/
I have no ideas about how to come up with a freewheeling version. Good luck.
No company makes a LH-drive 3-sp hub.
Hrm, well in that case, I wonder if it's possible to modify one to do the job...
Maybe I could reverse the ratcheting mechanism inside an old shimano hub. I don't know at this point.
I suppose I could get a splined cassette hub, and flip the cassette around. Destroy my idea please!
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
This is the reason standards exist. If you're going to use a nonstandard part, you have to get all the other parts it interfaces with to work with your jimcrackery.
That said, I'm really, really curious what this project is.
Sturmey ASC is the only way to go for LHD. Schlumff might be another way to go, if you can figure out how to pair it with a tandem left crankarm.
Insane Bicycle Mechanic
Quoted: 816 Post(s)
Liked 759 Times
https://www.recumbents.com/mars/pages...handdrive.html
If you want a multi-cog cassette, well, I'd be interested to see how you're going to shift it. There's no left-handed derailleurs AFAIK.
I, too, am interested in what you're creating.
Jeff Wills
Jeff Wills
The project I will be working on shouldn't even be mentioned here at bikeforums because it involves a two stroke gasoline/oil engine. If that hasn't put you off, you might want to take a look at this guys website. He hand builds small human/engine powered cruisers that are pretty cool and actually rather practical IMO. You can crank it when you want, or just jam with the engine.
https://xisletattoo.com/mmm_about.htm
Whatever you think about it, I was toying with the idea of mounting an internally geared hub to this machine since this bike only has one gear. However, as it turns out the engine is LHD and the rear cog the engine transmits power to is bolted to a very custom hub, so any tinkering with a traditional internally geared hub would be useless. I am going to call the guy who manufactures these to see if there would be any way to alter the drive train to be right handed so that I could use a shimano 8spd or a more robust equivalent.
If not, I plan on making one myself with an old 24cc weed whacker engine i will update this thread if I ever get it going.
Why not run the engine to a tandem crank?
That way, you can power the left side with the engine and the right side can power your traditional internal gear hub.
BTW, for the power output that engine will produce, it will definitely be a good idea to consider the Nuvinci CVT hub, which is actually designed for those kinds of loads.
Why on earth are you using a 2-stroke?
You can get a 5HP R/C airplane motor for under $200, and Mars Electric has a 15HP unit for a little over $400.
And LiFeP04 batteries are cheaper than ever.
Quoted: 2026 Post(s)
Liked 1,097 Times
Your link doesn't work
It might be just as easy to modify the motor to turn the other way and reverse it in the frame. 2-strokes have no valves or cams so only the ignition would have to be modified to fire at the correct time.
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
The power levels you mention would likely tear up any IGH available and I personally would not trust the brakes on any bicycle to deal with such power and potential speed levels.
Also in most states a moped, electric bike or similar vehicle is restricted to 30 MPH maximum speed. Otherwise it requires registration, insurance etc. In Nevada mopeds below 50cc and 30 MPH require no driver's license, insurance or registration. I would have to check on electric bike rules.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
You can attach a sprocket to one of the flanges of the hub, then have one chain going from engine to hub and one chain going from the other sprocket bolted to the flange of the hub to the rear wheel. Look at how 3 speed hubs for tricycles are arranged.
Also, if you have a manual clutch, then slipping the clutch provides a sort of low gear....
Liked 1,097 Times
Model airplane engines were exclusively two-strokes and glow-plug ignition when I was a kid but these days 4-strokes have taken over for the larger ones. A local hobby shop has a two cylinder, 4-valve, 4-stroke, electronic ignition model engine. It looks like some one washed a motorcycle engine in hot water and left it in the dryer too long. I didn't even ask how much it cost.
Bikes: Jamis Dakar XC bike 26", GMC walmart 10speed with touring stem and Power Grips, various low-buck treking and fishing bikes
I found this thread thinking about the same thing! I am on motoredbikes.com and running a 2stroke grubee kit on a beach bike.
So far the only thing I've found that might be relevant is this modification on Sheldon Brown's page. It would only give 2 fixed gears with a neutral gear in between, though. IF the clutch wasn't used lightly, it might blow up. But if you mostly tooled around in 1 gear and just shifted for the hilly areas, it might work.
https://sheldonbrown.com/bichain-fixed-free.html
The product you are looking for if you have a grubee or flying horse 2 stroke, is called a Shift Kit. For $150, you can get a bolt on kit and parts which includes a jackshaft, front freewheel kit, and necessary hardware. Then the motor turns the bike's RH gears, and the bike still pedals RH whenever you want.
It might be possible, with rear rack mount of the engine, and a custom electric starter or pirated pull starter. The problem then would be starting the motor. The bike can't be pop-started without a non-freewheeling gear, and can't be pull-started with standard stuff if you run it backwards.
This could work using the front freewheel kits made for the shift kits, on some bikes, but might bind up on others or jump the chain.
If you don't have a front freewheel, the motor could engage and spin the cranks from underneath the rider unexpectedly, causing injury. 2hp is enough to hurt you!
Theres this section too:https://www.bikeforums.net/showthread...wered-Bicycles
Electric motor on stoke-monkey's drives the left side of a cross over tandem crank,
by flipping over a RH thread drive on the motor to be on the left , it works fine .
there is also the Jackshaft mechanism drive the hub then have a sprocket attached to the hubshell
Rohloff hubs have a 4 bolt spider for their disc braking, its the same as 4 bolt mountain chainrings.. those will work as a frame mounted hub ,
then the final drive is on the left side
some custom threaded hubs and freewheels are made LH Thread.
Sturmey has a hub for driving trikes , you can drive a wheel with the chain attached to that hub shell
mounted sprocket.
and there is the new fixed gear 3 speed hub, you can buy one of those and see if it works, NB:
you will be unscrewing the cog into the lock ring, under power.
the lock ring on track/fixed gear bikes is left hand threaded.
mounted sprocket.
Oh and if it will go without pedaling it , it is a motor vehicle,
and subject to all the licensing and insurance requirements of any other motor vehicle mopeds scooters motorcycles..
if you have to turn the pedals but the power is available to assist your pedaling, but will cease if you dont pedal
then its an assisted bicycle.
Senior member
Quoted: 947 Post(s)
Liked 665 Times
mounted sprocket.
mounted sprocket.
re: SA 3spd fixed hub
Thanks for the info!
Senior member
Quoted: 947 Post(s)
Liked 665 Times
Sure. The only thing you can't do with it is install a left threaded left drive freewheel because of the right hand mounting threads, so to use it in a left drive configuration, you're pretty much stuck with fixed gear.
I have one of these, and I'm loving it. I've actually thought about flipping it around to the left side just to have something really different. If I do so, and I just might, I'll either secure the pedal threads with red loctite, or put helicoils in the crank arms to make the threads side appropriate. (I just included this bit to head off all those that were going to tell me why this won't work.)
