Replacement for Weinmann 605
Bikes: 1979 Motobecane C5, 1998 Cinelli Aliante, 1984 Banani Columbus SL, 2003 Banani Columbus EL-OS
Quoted: 9 Post(s)
Liked 28 Times
Okay, after a couple of tours on my newly aquired Motobecane C5 it becomes more and more obvious that I just have to abandon the thought of keeping the bike in original condition if I want to use it to more that a museum piece.
First of all, I need a wider set of handlebars. Anyone that knows the diameter of the handlebar and stem on this bike?
Secondly I need better brakes. As far as I understand a set of aero levers would make a difference, and as far as I understand there are better options out there than the Weinmann 605. But wich to choose without completely destroying the bikes look...
I have looked at the Weinmann Carrera 400 that the La Retoute bike team used on their Motobecane team bikes. But it seems to me that they are quite expensive. Are they worth it or wouldn't I gain that much when it comes to improved braking power?
Other options would be the Mavic SSC 430 or 440 - or maybe the original modolos instead?
I have also considered Dura Ace 7401, Suntour Superbe Pro's, Dia Compe Gran Compe or Royal Gran.
What would give me the best braking power? Wich brake levers would be a good choise? I don't want to destroy the look, the brakes should be from the late 70's og early 80's. Dual pivots or centerpulls are not an option.
For your handlebar question...
...I've found that my purchase of a digital caliper has paid for itself in vastly reduced frustration, and more effective eBay and CL rummaging while feeding my C&V habit.
As for brakes...if you want side pull brakes + actual stopping power, I'd head for the dual pivots aisle,
and ignore any excessive purist feedback.
Quoted: 9 Post(s)
Liked 28 Times
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
As far as braking power... any of those mentioned can be made to lock up your wheels... except perhaps Modolo "Speedy"s. I think Modolos, as long as they are models above the "Speedy" are fine. Many found the speedy arms not rigid enough.
Personally, I like Modolo levers, but also have Dura-Ace, and Dia-Compe(with suntour gpx hidden spring brakes). They all work fine, in my opinion.
The total combined weight of bike, rider, and gear would become a factor at some point, but I have no experience or knowledge in that regard.
My experience is relevant for total loads under 200 lbs.
Quoted: 9 Post(s)
Liked 28 Times
Alså a pair of NOS Modolo Q-even is up for sale locally - I've never heard about them before.
Quoted: 1143 Post(s)
Liked 1,740 Times
Of what you mentioned I would think the Carrera would be keeping in flavor with what you have, but have no experience with those. From there the Suntour is great. I would not go with the Gran Compe, they work ok if you can get the cables clamped. I've had the Gran Compe on a couple of bikes, they have fine line of loose-right-broken.
Campy always works good, Universal has some has some product that would look good on your ride.
Quoted: 9 Post(s)
Liked 28 Times
Campy - I think they would look out of place on a french bike. The Carreras are soo expensive...
Quoted: 5888 Post(s)
Liked 3,471 Times
snip . . .
snip . . .
Likes For bikemig:
Liked 3,471 Times
French bikes have 22.0 stem and 25.0 handlebars. Here is a useful crib sheet on French dimensions:
https://www.sheldonbrown.com/velos.html
Older bikes came with narrower handlebars. Wide 25.0 bars won't be easy to find. Sometimes a Nitto quill stem (22.2) drops right in to a French bike; sometimes it doesn't. Still you can sand that .2 mm off (and there are youtube videos) and then run the stem and handlebar combo you like.
It is easy to make those brakes work a lot better. Aero levers help. But the first thing to swap out are the brake pads. Those pads are probably crusty. Try some kool stops and new cables and housing. You will be happy with the braking once you do.
https://www.amazon.com/Kool-Stop-Bic...NsaWNrPXRydWU=
Quoted: 9 Post(s)
Liked 28 Times
Quoted: 3015 Post(s)
Liked 3,802 Times
Liked 3,802 Times
Likes For iab:
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Thanks, I'm looking at the Dia Compe Gran Aero at the moment,, A Guy has a pair of NOS up for sale not to far from me. Without the levers. Anyone Who have tried Them? Another option would be af set of Mavics - I know that they really Are Modolos, but it Will keep the bike french.
Liked 3,471 Times
Likes For bikemig:
Quoted: 767 Post(s)
Liked 1,898 Times
I have these
...on my '79 Motobecane Grand Sprint. Calipers and levers are stock. Cables and housing are new, and the shoes are Ultegra from a few years ago.
They are excellent. Cables and shoes made all the difference.
Bikes: 1985 Roberts SLX, Mercian 531, 1984 Torpado SLX,1981/82 Peugeot PSV-10, 1978 Charlie Roberts full touring, 1970 Charlie Roberts 531 road.
Quoted: 79 Post(s)
Liked 164 Times
On my PSV-10, the Weinman 105 with good pads work fine, cables and brake pads that are new make a big difference.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
There's nothing inherently wrong about the 605's other than that they're a bit unconventional to service with their recessed Allen key. You have NOS pads and that's your problem.
Another vote for "put Kool-Stops on it."
What handlebar width are we working out from? 40cm? 42cm? Do you already have a preferable bar width? Better get that caliper too for the clamp diameter - Harbor Freight it if you don't want to invest anything but the minimal in a caliper, but please do get one.
-Kurt
-Kurt
Quoted: 823 Post(s)
Liked 1,395 Times
First of all - that is a beautiful bike!
The least expensive route that would probably yield immediate results would be to go with good stainless brake cables, teflon-lined housings and Kool-Stop pads. I have done the first two with my 1976 Puch, running its stock non-aero Weinmann levers and a pair of Weinmann Carrera sidepulls. I will note that I have the original black pads. I also took a file to them to get down past the dried-out crust. But seriously, after cables and teflon-lined housing, the Kool-Stop salmon colored pads.
Weinmann Carreras are excellent brakes with delrin buffers between all moving parts - including the points where the springs press against the arms. They're just smoother and easier to operate with less friction involved. I'm running two sets of them, a 1st generation set on the aforementioned Puch with stock levers and a second set from when they changed the cable fixing bolt arrangement, operated by an ancient set of cheap Dia-Compe aero levers. Both are running sanded original issue black Weinmann pads and they both work beautifully.
I would second chainwhip's recommendation of acquiring a good cheap set of digital calipers. I scored mine from Harbor Freight for $10 and they have been awesome and have dramatically reduced the frustration in my bike repair life.
If after measuring your bars you find you need a new stem, I would highly recommend Nitto. If at first you can't fit a Nitto stem into a French bike, remove the headset locknut and try without it. If that works, then file or dremel out the interior top of the locknut until it permits the stem to pass through. I've read suggestions of running a brake cylinder hone down the inside of the steerer to remove any crud or corrosion, but looking at your Motobecane, I suspect it has been well cared for and that shouldn't be an issue. I've been running Nitto stems on my Gitane and my Allegro, both with metric-gauge Nervor steerers, and Nitto stems fit nicely into them.
Liked 3,471 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
