Tufo or Stanīs sealant for tubulars as preventive measure?
Hi
I already used the "search" but just found bits of information.
Did anyone tried BOTH of the named products and can tell which one works better as preventive measure?
I mean with road tubulars (Tufo AND Conti)
For "afterwards" there is the tufo extreme.
Questions on questions...
How long do they stay effective? What to do then?
Should they fail, is it still possible to use (successfully) the extreme or they interfere in some way?
Thanks in advance!
Thanks in advance!
Registered User
Bikes: Cervelo S5 SRAM Red -
i use both and they both work the same for me.
once it seals you can ride it for a very long time. on occasion it may lose some air overnight but just pump and go.
but yeah, usually it fixes it well enough to keep riding and not worry about it. Unless its a significant cut that is.
Vic
Vic
I use the Stan`s , a little less than ounce in each tire.
No flats in over a 1000 mile but the back Vittoria Corsa CX tire is about shot.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
Can the sealant be put into a tubular that does not have a removable valve core? If so, how?
Itīs explained in the instructions that itīs not the preferable way to introduce the "milk" though.
Probably it works but Iīd expect it to be a little messier.
