Look for advice on 700c wheelset for 70/30% road/gravel
Bikes: 1972 Raleigh Professional, 1980 Raleigh Gran Sport (frame only), 1989 Diamondback Apex, 1997 LeMond Zurich, 2018 Specialized Diverge running R8020 Ultegra.
Quoted: 46 Post(s)
Looking for advice on 700c wheelset for 70/30% road/gravel
I'm just about finished with my 2018 Diverge Sport upgrade. I want to replace those heavy OEM Axis Sport wheels with something nicer. I'd like to set up a wheelset that will be used 75% of the time on pavement and then venture out 30% of the time on gravel fire roads, etc. I'm looking @ DT-350 CL Disc hubs laced to HED Belgium or Belgium Plus rims. I desire to be able to run tires in the 32 - 38mm range and want to know if which rim choice will work better for that. I'd like the wheelset to be around 1650 - 1700 grams give or take. For more dedicated gravel work later down the road I'm going to have some 650b wheels built with the same hubs and wider rim for 45-47mm tires. Thanks for any and all suggestions.
Quoted: 286 Post(s)
Liked 262 Times
Because of what you said above, why don’t you make this first wheelset more like a road wheelset (narrower rim, narrower and lighter tires). You can get deals on wheels w/QR hubs for wheels meant with with road disc bikes. Then go beefy when you’re ready with the second set.
Quoted: 46 Post(s)
I just may use the OEM wheels for awhile as they come shod with 38mm Trigger Pro tires so I can try out more varied routes. Maybe after that initial use I'll have a better idea of my needs going forward.
Ultimately I intend to do some light bike camping and/or credit card camping on bike trails in the US (after retirement). At that point, I can see having purpose built road wheels and 650b wheels for the more demanding stuff.
Also where I live, I can easily ride to some trails that would use the 650b wheels and/or ride just pavement so I see myself swapping out the sets often.
Quoted: 167 Post(s)
Liked 11 Times
I had a set of wheels made with DT Swiss 240 hubs and Pacenti Forza rims which I am running 43 front and 38 back. I believe the these will fit your weight requirements.
I've gotten over 1,000 gravel miles on these so far and I'm pleased.
These are a tad heavier, but cheaper - DT Swiss ER 1600 SPLINE . DT Swiss rates them for a 286 taking 6" drops. I've been using
(the R32 version) them for a year now and they've stayed tighter than any wheel I've owned - bladed spokes are even straight.
https://www.bike-components.de/en/DT-...adsatz-p61855/ These are going for $500, though you should be able to find them for $100 cheaper. You can also sell the extra hub end caps for $25/ea (that's about $100 recovered).
ANother option
https://www.bike-discount.de/en/buy/f...heelset-673362
You Diverge is SCS rear, right? Have fun with that.
ANother option
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
biketampa
29
06-14-19 06:14 PM
RockiesDad
23
05-21-17 07:12 AM
Spoonrobot
8
08-16-15 09:57 AM
