Should I buy this vintage Trek carbon frame?
Hi everyone, I've been a lurker for a while but just made an account to ask for advice.
Im new so I'm not allowed to post links or photos apparently but here's the title of the listing if you could look it up on eBay: TREK CARBON FRAME FRAMESET 59cm ROAD BIKE VINTAGE FIXIE RETRO CINELLI QUILL STEM
the listing is based in Southend on sea in the uk
Does anyone know what model it is?
It looks to be in good shape. Buyer accepts returns so if it's no good after inspection I could send it back. Would hate to do that cause it's always a pain when people return items - but it's the only way under social distancing guidelines as I don't live in the same city.
I've not owned a carbon frame before.. which makes me a bit nervous. But the larger tubing would really compliment a paintjob I've been wanting to do for a while.
If the general opinion is a no, perhaps I could get some suggestions on frames with similar shapes? The paintjob I want to do is a replication so I could send photos of the original here if that would help.
Thank you so much for any help you're able to give 😊
Quoted: 1088 Post(s)
Liked 1,025 Times
There's nothing of any use there to determine what year or model it might happen to be. They've had carbon bikes for over 30 years and have had multiple types. Without pics or a link no one will be able to give an opinion.
Quoted: 811 Post(s)
Liked 1,024 Times
Quoted: 1610 Post(s)
Liked 2,593 Times
Is that the ad? How do they know it's a Trek? I'm not seeing that style seat tube with that style brake cable routing anywhere.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Looks like a carbon Trek to me. Looks clean, too, minus those few marks (top tube). Nothing that gives me pause. My 210 lb self has bought and ridden near-30 year old carbon (Specialized) and it was in similar condition. Excellent bike, and I wasn't afraid of it. You could ask the owner some more history on it and make your decision from that point.
If you're looking for large-tube bikes, I will gladly suggest any and all vintage Cannondales. I've owned plenty, as have a few of our members, and they are proven in durability and in speed. 1983-1988 for traditional frames ('84/85 for the intro of road frames), 1989-mid '90s for the cantilevered-chain stays of the 3.0 frames, then the refining of the 3.0 into the 2.8, and finally a return to the traditional diamond frame with the CAADs in 1997.
Quoted: 1627 Post(s)
Liked 630 Times
Maybe a OCLV Trek from about 20 years ago? 5500 or something? Like any vintage CF bike, I'd want to take real close look at it in person and in good light before buying. But I admit, I'm not really a CF kinda guy.
Someone on ****** r/vintage_bicycles said it might be an oclv as well. Ideally of course I'd really like to inspect in person before committing to buy (and then possibly having to go through the hassle of sending it back) but not possible at the moment.
Seller wasn't able to give any more history other than that it's a mid 90s model..
Thanks for that Suggestion I'll look into those Cannondales
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
I'm not a carbon fiber guy either, but it is seemingly in nice shape. However, it depends on what you wish to do with it component wise.
Liked 1,025 Times
I'm not certain its a trek either. The front and most of it looks very trek like but 5000 series treks that I can ever recall seeing had straight tubes and didn't have shaping, that didn't show up till the Madone and it had cooler shaping. A quick google image search of trek 5500 produces 100s of images and not a single one that shows that seat tube. I find it dubious that its a real trek.
Liked 2,593 Times
You shouldn't have any problem with the monocoque frame. Sometimes the mounta for cables corrode.
Quoted: 331 Post(s)
Liked 332 Times
Second hand CF frame
I would strongly advise caution. A used CF frame for a 230 lb rider seems an odd choice. It will not have rigidity coz it's old and delaminated and even if you don't have Chris Hoy legs you'll bend it. It will be light but the 10 lbs you are saving for accelehration benefits/reasons over a steel frame is meaningless when the total weight you are trying to accelerate away from is say 50 - 100 lbs lighter.
The frame looks like a Chicom knock-off , not a Trek.
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
Dean
Roll Me Up and Smoke Me When I Die
Quoted: 226 Post(s)
Liked 309 Times
I would strongly advise caution. A used CF frame for a 230 lb rider seems an odd choice. It will not have rigidity coz it's old and delaminated and if you have Chris Hoy legs you'll bend it. It will be light but the 10 lbs you are saving for acceleration benefits/reasons over a steel frame is meaningless when the total weight you are trying to accelerate away from is say 50 - 100 lbs lighter.
Dean
IMG_3935
Liked 2,024 Times
2004+ Trek Madones had the scallop, which is what I had in mind (along with the DT/HT/TT instersection), but they also came with integrated headsets and not 1" threaded. The earlier Trek 5X00s did indeed have straight tubes.
At 230 lb, I'd skip the risk of an old carbon frame and get on a steel or aluminum. Modern aluminum frames can be pretty darn light (Trek Emonda ALR, like I've had) and modern Treks all carry a rider limit of 275 lb, so they're safe for non TdF flyweight climbers. Though for your budget (start smaller and work up, like pretty much all of us), older frames will be plenty good while still being able to hang modern parts on.
Liked 2,024 Times
Habitual User
Quoted: 4955 Post(s)
Liked 8,097 Times
I'm not convinced it's a Kestrel because of the dropped seat stays, as ROS noted above.
Habitual User
Liked 8,097 Times
The dropouts on the "Trek" don't match the dropouts on the 5000-series OCLV frames I'm seeing. The carbon weave pattern doesn't look right to me, either. Something just ain't right.
Quoted: 331 Post(s)
Liked 332 Times
Old CF BB shells
If you choose to go the plastic path for an old CF frame the part of the frame to check throughly is the BB shell. This is where any attritional damage (that is not obviously crash/neglect related) occurs. It is difficult to ascertain even if you are astride the bike. It is only under full gas that a weakened BB shell will illustrate whether or not a CF frame has delaminated to a the extent making it a wall decoration.
Quoted: 4560 Post(s)
Liked 2,802 Times
I'd say no. That doesn't look like any 1990s Trek carbon frame I've seen -- that bulge in the seat tube resembles a frame by another manufacturer, but I can't recall the brand at the moment.
And it appears to have been repainted, with some odd discrepancies. The carbon weave is visible in some areas, but the paint is opaque elsewhere. Hard to tell from the photos.
The bottle cage mounts appear to be the conventional internally threaded inserts. That was started in 1994 Trek OCLVs. Before then they mounted protruding bolts, which made it tricky to mount cages. I had to find cages with clearance for retaining nuts and a wrench to hold the nut, and use shims to set off the cage enough that the bolt wouldn't scrape the water bottle. PITA. Trek fixed that in '94, but that's not a 1994 Trek OCLV frame from the 5200, 5500 and 5900 models.
Without inspecting it and having a shop do an ultrasound or other scan, I'd be concerned that it's been damaged, repaired with a homebrewed carbon fiber patch kit, and painted to cover up the repair.
There were some early 1990s Trek OCLV frames that came with threaded headsets, so that alone isn't necessarily a problem. And I like my 1993 Trek 5900.
But I wouldn't pay more than maybe $50 for that frame, gambling that it might be a lost cause if it turns out to have been damaged and repaired.
Liked 2,593 Times
Kestrel would have thru frame brake cables. Not sure who makes that frame, but it looks early.
Ebay picture from ad...
