Campy seatpost binder bolt
Bikes: 2020 bridge club, 2014 MARINONI sl, surly 1x1, 91 GT Tachyon
Quoted: 7 Post(s)
Liked 16 Times
I have a Marinoni SL with a Campy style seatpost binder bolt (non-tabbed, knurled) that is spinning in the frame. Does anyone have any experience with grinding a tab off a tabbed binder bolt and using two Allen wrenches to tighten the post? Are there any companies that make non-tabbed bolts without a Campagnolo price? I'm looking for a 20-22mm. Thanks.
Quoted: 1199 Post(s)
Liked 1,355 Times
I think the most important thing is making sure the bolt is the correct length when using a non keyed bolt. It will play inside if one side isn't knurled to catch metal.
I've cut off a few notches with no issues. But like you mentioned sometimes 2 allens are needed to tighten the bolt.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
I used a tiny, tiny bit of JB Weld in my Miyata for a spinning nut. Pretty sure I could hammer it out if need be.
Quoted: 472 Post(s)
Liked 1,028 Times
I consider the tab or knurling on a nut a mere convince, never enough to really hold the nut in place for tightening. I ALWAYS use two keys for loosening or tightening a binder bolt. It is way to easy not to.
Likes For Prowler:
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
Dean
Roll Me Up and Smoke Me When I Die
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
^^^^ 2 is better than 1!
Best, Ben
Best, Ben
Voltaire
Voltaire
Quoted: 1106 Post(s)
Liked 1,328 Times
Likes For oneclick:
Quoted: 7 Post(s)
Liked 16 Times
Thanks for all the advice. I'm putting in an order for a tabbed bolt right now (LBS doesn't stock, Bike Co-op shut down for winter and COVID...). I've kluged a solution using a QR binder bolt and two chainring spacers (8mm hole, 10mm OD) to prevent damaging the frame. Good enough for the fluid trainer.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
I'll second using a file, doesn't take long. Easy-peasy.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Is this a case where the seat lug has no notch for the anti-rotation tab on the nut portion of the binder bolt?
I had such a situation recently, so I sculpted a sufficient notch within the bore of the seat lug ear on the left side using a Dremel tool with a suitably-small carbide cutting wheel.
It's easier though to just file away the tab and then apply a fat drop of Loctite to the interface between the lug bore and the nut. Let it sit over night (or accelerate the cure time with a hair drier) and the nut will never turn without a hex wrench put onto the nut itself. I always clean the surfaces where the Loctite will settle against, which improves the consistency of the bond.
Be sure to grease the threads inside and out. And make sure that the bolt's shoulder doesn't bottom against the end of the nut (add a washer or grind down the end of the nut if it does bottom out).
Quoted: 7 Post(s)
Liked 16 Times
FYI: Received a message back from Marinoni Cycles: "...the only binder bolt we have with allen key on both end is this: https://store.marinonicycles.com/product/1180 Campy bolts are discontinued."
Likes For caribou22:
