How often do you recharge your blinking lights?
Got a cheap set. Do you recharge them after every ride?
Might get more spares
https://www.ebay.com/itm/125807072450
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Yup. If I can remember to.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Likes For Mtracer:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
As often as needed. Cheap lights are generally not worth it except for a child's bike not being ridden at night. You want something bright with a good beam pattern and ideally a good long battery life (unless really good about charging) I also recommend more simple setting light too many front lights these day have unneeded flash modes and strobe modes for your discotheque parties which are just not needed while riding a bicycle amongst others. Ideally the rear would be solid as well but red light is a bit less damaging to the eyes at night but I would rather have light all the time and something like the Lezyne or Krypto lights that have an accelerometer so they do get brighter when you stop like other vehicular traffic.
However if you get a dynamo system there is no charging needed, all you have to do is ride your bike and you generate the power for the light and many of the dynamo lights out there have excellent beam patterns usually to STvZO standards (which are irrelevant as law in the U.S. but really useful for what that law requires of the lights for being around other road or trail users) plus you can even get some with those brake lights as well and now Supernova has one with a high beam. It is more costly yes but never having to worry about charging and always having light day or night without worrying about turning things on or off is pretty nice.
Likes For veganbikes:
Liked 3,443 Times
If the bike lights are cheap, why not simply throw them away when the batteries are drained, and then buy new ones?
Another option is to get solar-rechargeable ones, and use each light to recharge the other one, perpetually.
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
One charge gets me through my 3-4 midweek rides of up to 1 1/2 hours, then I charge them again for my 3 1/2- 4 1/2 hr Sunday ride. So basically I guess I always charge them before and after my Sunday ride.
Likes For genejockey:
Liked 2,979 Times
After every ride.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 4227 Post(s)
Liked 2,488 Times
Rear blinker is PB superflash which uses regular batteries, they last a long time as I only use it when necessary. For the front light I use a Fenix tactical flashlight which I always top up by re-charging after each use.
Liked 11,912 Times
Are there also strategic flashlights?
Liked 2,488 Times
Likes For wolfchild:
Liked 11,912 Times
Liked 2,488 Times
Liked 11,912 Times
(It's a joke. See the first line of my signature)
Liked 2,979 Times
Are there even any affordable compact rear led rechargeable lights that are 350+ that will last 8+ hours on max?
-Oh Hey!
-Oh Hey!
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
4 Cell 18650 Battrey Packs.
Run Time 6.5 Hours on Strobe
Day Time Dinotte on Top with 8 LEDS
Fred "The Real Fred"
Likes For 10 Wheels:
Quoted: 800 Post(s)
Liked 512 Times
I charge both the Garmin Varia and the Bontrager Ion 200 RT after every second ride.
Quoted: 3952 Post(s)
Liked 7,299 Times
As long as my light is flashing On-Off-On it's good, but when it starts flashing Off-On-Off then it's time to charge it.
Quoted: 18420 Post(s)
Liked 15,564 Times
Likes For indyfabz:
Liked 15,564 Times
When I think it needs charging?
Liked 11,912 Times
I just finished up charging all my lights, my Varia, and my Garmin Edge. Mounted them on the Ritchey Now I'm itching for tomorrow's long ride. Only 20 hours to wait!!!
Liked 15,564 Times
Liked 15,564 Times
The frequency with which you need to recharge your blinking lights will depend on the specific model of light you have and how often you use it. However, as a general rule, it's a good idea to recharge your blinking lights after every use or at least once a week if you use them regularly.
If you have a rechargeable battery-powered blinking light, you should follow the manufacturer's instructions on how to recharge it. Many lights come with a USB charging cable that can be plugged into a computer or wall adapter.
It's also a good idea to check the battery level of your blinking lights regularly, especially if you plan to use them for an extended period of time. Some lights have a low battery indicator that will alert you when it's time to recharge.
Overall, keeping your blinking lights fully charged and in good working condition is important for your safety and visibility when cycling or engaging in other outdoor activities.
Likes For indyfabz:
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
I use Dinotte Quad lights, and I recharge after 4 hours of use. The batteries in these lights will last more than 4 hours but less than 5 on the brightest setting, which is what I use for daytime riding. You could charge your lights up fully, then run them down over several rides (or on the kitchen table) until the lights stop working, and note the time that takes. Then charge accordingly.
