Disc brakes and quick releases – what's the deal?
Hello all. Long time reader, first time caller, etc. I have a 2019 Rockhopper 29, which has quick releases and disc brakes. Recently came across the discussions about the safety issues with disc brakes and quick releases. The physics makes sense to me, but most of the bikes I'm seeing on the market (I've been looking at upgrading) still have disc brakes and QRs, so I'm a bit confused. (Also wondering about the safety of my Rockhopper.). Are manufacturers just ignoring the issue, or has the disc brake/QR issue been eliminated somehow? Cheers all.
Quoted: 1821 Post(s)
Liked 1,696 Times
I have 1 15 year old mountain bike with disc brakes and quick releases. The only modification I have made was to buy a pair of Shimano closed cam skewers which are much more secure than the open cam ones that came with the bike. Nowadays the majority of disc brake equipped bikes use thru axles that may look like quick releases, but are more secure
ignominious poltroon
Quoted: 2242 Post(s)
Liked 3,443 Times
If the dropouts on the fork face forward rather than backward or straight down, it is a bit safer.
The advice to use closed-cam levers is good advice. DT Swiss also makes a quick release that essentially emulates what a thru-axle does, and it has a screw-in mechanism rather than a clamp. It is arguably the best.
In any case, it is a good idea also to get steel rather than titanium.
Quoted: 581 Post(s)
Liked 921 Times
My experience has been that as long as the tightness of the QR is tightened properly and checked occasionally (every couple of rides) then it won't be a problem.
But, as mentioned above, most new bikes don't have the same QR system with a 5mm skewer as were common BITD
Not arguing with anyone, but when I was looking at the specs on a lot of common bikes (Rockhopper, Sirrus, most of the Trek models), they're mostly listed as quick-release. Am I misreading the specs? I'm not a bike expert by any stretch of the imagination.
Quoted: 1461 Post(s)
Liked 1,486 Times
You can have "quick release" levers on thru axles that allow you to remove the axle without a tool. Maybe that is what you are seeing?
I don't think Trek or Specialized make any disc bikes with actual quick release skewers anymore.
Edit: Looks like I'm wrong about this. I see some Sirrus models on the lower end of the price range with what appear to be 9mm quick release skewers. No idea why they would sell these.
All of those bikes have thru-axles.
Quoted: 6196 Post(s)
Liked 4,811 Times
The Rockhopper is their lowest end and most basic trail bike, as they classify it. The Stumpjumper is their next level up and it has Thru-axles. Don't know why the difference. But it is what it is.
Moving from QR's to a thru-axle wasn't the big deal for me that I thought it was going to be. So I really could care less what the bike has. If the manufacturer feels it's good enough, then I'll assume it's good enough for the intended use. If you are somehow using it in a manner it wasn't meant for, then you might have some worry.
Welcome to BF
Welcome to BF
The potential danger is if the front quick release skewer lever opens all the way, wider than 180 degrees, and gets caught in the disc brake rotor.
After reports of three skewers somehow getting caught in the brake rotor, Trek recalled more than a million skewers and replaced them with skewers whose levers only open 90 degrees.
If you keep your quick release skewer closed tight, there is no danger. Also, if you install the front skewer so that the lever is on the driveside of the bike, away from the rotor, there is doubly no danger.
Liked 1,486 Times
On a more practical level, disc brake setups are very sensitive to any minor misalignment, and TA's largely solve this problem. I had a MTB with disc/QR's many years ago and had to often faff around with aligning the calipers to avoid rubbing rotors. I don't have those problems with disc/TA.
Honestly I can't think of any reason to avoid TA's nor do I understand why manufactuers would even continue to make QR frames. I assume QR/Disc hubs are not that common anymore, yet you correctly note that a fair number of them are still being sold. Future wheel upgrades on those bikes will be limited.
Likes For msu2001la:
Thru axles keep the wheel in alignment better and this is important with disc brakes where the tolerances are much tighter than with rim brakes. The Boost hubs and axles are much stronger and so used with e-bikes and mountain bikes where the support for the fork is important. The thru axle also allows for a lighter fork to be used as the thru axle connection is a much stronger one and better at dealing with lateral stress on the wheels.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
As others have pointed out, it's only common on low level new bikes. If I had to guess, I'd say they are using up frames that are contracted for or otherwise in the pipeline. I wouldn't be concerned about using your existing bike but there's no reason to buy another one w/o thru axles. You'll also get what has become the new standard spacing.
Likes For shelbyfv:
Liked 3,443 Times
Some people have had problems with the back wheel moving with respect to QR dropouts under heavy load. (I have not.)
Liked 3,443 Times
And this is why I'm confused. If there's a genuine safety issue here, why is the QR/disc combo still so common? I'm hoping my next bike purchase will be my last, and I'd like to have something that I can rely on for quite some time, as well as now being a little concerned about the safety of my Rockhopper.
Quoted: 7652 Post(s)
Liked 3,479 Times
As far as I know, QRs are less popular on disc bikes because they wheel has to be centered carefully, whereas with through-axles the wheel always goes back in exactly the same orientation.
My Fuji Sportiv has QRs and discs, and I have to play with the wheel a little every time I take it off or the brakes will drag a little. On top of that a through-axle is stronger (though less convenient.) Now I guess some through axles have built-in handles so no extra tool is needed.
As for the QR handle hitting the disc ... if your QR is that loose the wheel could fall out anyway. Most riders I have met are smart enough to use a QR properly. I suppose if one could forget to tighten a QR, s/he could likewise forget to tighten a through-axle. In any case ... Darwin.
Likes For Maelochs:
Liked 1,486 Times
I personally wouldn't buy a QR disc brake bike, not due to safety concerns, but for the other reasons stated (alignment issues and potential future compatibility issues).
I never had issues with alignment using QR levers. As long as I was the one setting up the brakes and wheels, it was easy for me to repeat wheel removal without alignment problems. It was when someone else set things up that it all went south.
Three complaints with thru axles, 1. it is a PIA to use most of the time on the rear wheel, 2. thru axle loosens when riding, 3. stripped threads on the frame or the axle, which happens frequently enough due to user error. Outside of that they are ok.
Likes For redlude97:
Quoted: 4227 Post(s)
Liked 2,488 Times
Likes For wolfchild:
Liked 2,488 Times
Liked 2,488 Times
Liked 2,488 Times
