Shimano XTR 9-Speed Shifters with Shimano 105 Road triple front derailleur
Will Shimano XTR 9-Speed MTB shifters work with my Shimano 105 Road triple front derailleur?
Btw, I'm assuming the shifters are friction mode for the front derailleur-- is this true?
Quoted: 423 Post(s)
Liked 994 Times
These will be indexed front and rear. The front may not work well, mixing mtb shifter and road derailleur. If the derailleur is appropriate for your chainring setup, you may want to source a flat bar road front shifter such as the R3500. Or if you do want friction front shifting, use a grip or thumb shifter. Rear should be fine as-is.
Clark W. Griswold
Quoted: 4492 Post(s)
Liked 4,169 Times
For 9 speed and below generally everything was compatible (minus a few oddballs like some of the 74xx DA stuff) so you should be fine. It is all indexed. To get friction you would need thumb, downtube or barcon shifters but it should work decently well enough.
Mad bike riding scientist
Quoted: 6276 Post(s)
Liked 4,302 Times
Stuart Black
Stuart Black
aged to perfection
Quoted: 860 Post(s)
Liked 1,297 Times
agreed mostly with the above. Questions like "will X work with Y" where X and Y come from different manufacturers, and maybe even generations of components, are very difficult to answer with the degree of certainty that the OP expects.
not to mention the definition of "work". Will it jockey the chain back and forth ? Maybe. Will it shift with precision and flawless reliability ? Hard to say.
Given what a used MTB front derailleur costs, that would be the route I'd suggest, but it's hard to advise the OP further because we don't know if he's runninng double or triple chainrings, etc.
/markp
/markp
Quoted: 409 Post(s)
Liked 432 Times
For reasons that nobody has ever been able to explain, Shimano MTB and road front derailleurs have different cable-pull-to-derailleur-movement (actuation) ratios. This didn't matter back before Shimano decided that indexed front shifting was a thing that was needed.
But they did, and it does.
Your 9-speed XTR, or any 9-speed Shimano MTB shifters, will not index any Shimano front derailleur over any crankset ever made. (I imagine that one could machine chainring bolt spacers that could make it work, but nobody's ever bothered to try.)
Use a Shimano MTB front derailleur. 9-speed Deore LX or above will shift better than you do, and last forever. The XTR, as sweet as it was, is just bling... which isn't a bad reason to buy one.
--Shannon
--Shannon
Quoted: 1956 Post(s)
Liked 2,200 Times
If you can find an XTR FD-M900/901 it will work with your 9 speed shifters and run between 26-48 chainrings. You might be able to push it to a 50t outer ring.
A lot of MTB FD’s won’t cover a road outer ring.
John
John
--Shannon
--Shannon
Below is a comparison of FDs from about the same time, road RX-100 triple for downtube non-index and XT MTB. Based on the appearance of the cable attachment arm and the cage pivot, they appear that they would actuate similarly.
Below is another FD for a road double, pre-brifter (many FD had the same design at the time, late 80s-early 90s). This used a pivot that moved at a diagonal angle to the frame, which needed more cable pull. All of these type was replaced with standard pivot styles (shorter pull) when brifters were introduced, (eg FD-A550 to FD-A551).
These are some observations that I've discovered while playing with various shifters and FDs.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12957 Post(s)
Liked 7,878 Times
I reckon you could get a front trigger shifter from a flatbar road group. Tiagra for instance.
