Cycling glasses with some modern helmets: over straps or under straps?
Hello
I'm used to wearing my Oakley RadarPath glasses over the helmet straps, which is traditionally considered the right way to do it. That's how I used to wear them with my previous helmet - Specialized S3 (size M).
Now I got myself a Specialized Prevail II MIPS (size L, since M felt a bit too tight even at max setting) and I see that the front strap attachment points stand notably further away from the sides of my head with this helmet. For this reason the gaps between the front straps and my head on both sides are pretty wide (~1.5 cm). When I attempt to put my cycling glasses over the straps, I end up having to force the glasses' temples to squeeze the front straps towards my head. I can feel how the straps fight the glasses, especially when I put some tension into the strap by lowering my jaw.
Is this how it is supposed to be? Or am I supposed to wear my glasses under the straps with this helmet?
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Over straps.... you have to look PRO.
Likes For Bmach:
+1 Under straps, I don't care either. I was never one to follow the "Rules" anyway.
Likes For drlogik:
Expired Member
Quoted: 3661 Post(s)
Liked 5,408 Times
Design failure on the part of Specialized. Can you return it?
Likes For shelbyfv:
Quoted: 6958 Post(s)
Liked 10,959 Times
Likes For Koyote:
Quoted: 822 Post(s)
Liked 1,960 Times
I see a lot of cyclists not wearing helmets lately but they do wear sunglasses.
Likes For CAT7RDR:
Quoted: 313 Post(s)
Liked 680 Times
Over, under, it doesn't matter. As you've found out, it sometimes comes down to the design of the helmet.
Likes For tempocyclist:
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Socks are traditionally worn inside one’s shoes, cycling shorts are traditionally worn with the chamois on the inside, and helmet straps are routed under the bows of a real cyclist’s eyewear. But, it’s 2021, and some goons insist on wearing socks with sandals, some men own cats, and, somehow, the whole Harry Potter craze really happened. All because of disc brakes.
Likes For AdkMtnMonster:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Under the straps. Otherwise, I need to remove my glasses in order to take off the helmet.
Likes For JohnDThompson:
Quoted: 2604 Post(s)
Liked 1,926 Times
As a practical matter, I've had to get a helmet off my head as quickly as possible because a stinging insect flew into the vent (more than once); and I'm blind without glasses. Don't want to get stung, want to be able to see to continue riding safely ... I'll keep wearing my helmet over my glasses.
As for the pro look, well, nobody looking at me has made that mistake.
Likes For pdlamb:
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
Straps over glasses can cause an annoying whistle / wind noise; also it may keep you from securing the straps sufficiently tight making the helmet useless in a crash.
YMMV
YMMV
Quoted: 2281 Post(s)
Liked 1,710 Times
I wear glasses, so I wear them under the straps. I don't want to take a tumble and risk my glasses flying off to parts unknown, leaving me essentially blind. That's also why I wear a strap on my glasses while riding, so if they do come off they will hopefully just dangle around my neck.
Likes For Milton Keynes:
Quoted: 347 Post(s)
Liked 418 Times
Over straps. And it’s got nothing to do with looking pro. I think it’s the better way. Adjust the straps so the helmet fits and is positioned properly then put your glasses on so you’re wearing the helmet as intended by its design without extra slack or being stretched around the glasses arms, or having a gap with your head in places. Why take the chance that you’ve inadvertently compromised the ability of it to stay in place durning a crash.
Sunshine
Quoted: 10954 Post(s)
Liked 7,483 Times
That anchor design is made by the devil and you need to say...
Likes For kahn:
High Plains Luddite
I cut the straps off my helmet. It's more comfortable that way, doesn't interfere with my prescription sunglasses, and I don't get sweat caked in the chin strap.
Plus, I like to tip my helmet to the side at a jaunty angle like a WWII fighter pilot.
Likes For Squeeze:
Quoted: 383 Post(s)
Liked 690 Times
One more rule I had never heard of. Mine fit, with some weaving under the straps as I put them on after the helmet. So thankful that the weather has warmed and the covid mask does not cause fogging. The mask is now generally around my neck in case I make a stop that might require a mask.
Quoted: 1104 Post(s)
Liked 1,824 Times
Personally, I wear my glasses over the helmet straps. That allows the straps to be properly adjusted and doesn't create a pinch point on the temples (with the arms of the glasses) if I hit the deck with my head and the straps tighten up because of helmet movement. This is why many pros wear them over the helmet straps. That doesn't make me or them right, it's just a reason.
Quoted: 6191 Post(s)
Liked 4,807 Times
I sometimes have them under, sometimes over. Maybe it depends on whether I had the helmet on and buckled up first. As well as whether my sweat vac is pulled over the tips of my ears to help with sun
Don't know, don't really care.
Bikes: Trek Mtn Bike
Quoted: 281 Post(s)
Liked 2,637 Times
Yes. I wear them under and/or over the straps. Sometimes both at once.
Agree with Koyote. They work better over the eyes.
Quoted: 1027 Post(s)
Liked 325 Times
I wear under too. My sunglasses are prescription, so I basically don't take them off. If the straps were underneath, my glasses would likely be flying off my head, and possibly getting scratched, on every ride at the coffee stop.
Quoted: 440 Post(s)
Liked 264 Times
I would love to see a scientific study that proves wearing glasses under the straps of a helmet means that the helmet straps are not properly adjusted ant will prevent the helmet from protecting you.
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I wear them over but I can discern no difference from a safety standpoint. On some helmets, I sense slight flapping if I wear them under so I just wear them over now, on all.
