Campagnolo compatibility questions
Hi all,
I just bought a lovely Italian steel frame (from the 90s, or early 2000s) and I am set on using Campagnolo Veloce 10 speed. I am aware it is not the latest and greatest but it is priced sensibly and it is Italian (keep the theme). I have already bough a 13/29 cassette and I am eying a 52/42 crankset. This crankset is the oldest bit of my groupset (it uses square taper bottom bracket). I am also in the process of getting a Veloce rear derailleur with a medium size cage.
Is the crankset compatible with the cassette? Will there be an issue in using an older crankset ? Will a recent Veloce chain work with the older crankset?
Do you foresee any other issues with my build?
Your feedback is appreciated.
Bad example
Quoted: 887 Post(s)
Liked 391 Times
I'm using late 70s Nuovo Record and Super Record cranks with standard chainrings on a couple or three bikes with ten speed Campagnolo brifters and chains. They all get along fine.
1981 Stevenson
2006 Rodriguez using the cranks from a 1979 Holdsworth
1981 Stevenson
Quoted: 1873 Post(s)
Liked 1,748 Times
Campagnolo used square taper cranks until the year before they switched to 11 speed. Your cranks will be fine
Quoted: 1111 Post(s)
Liked 1,050 Times
If its a 10sp crankset there's no trouble, 9sp will work fine with the way campy ergolevers work. 8sp you might start to have issues since the 10sp chain might want to start catching in between the chainrings and starts getting a little tight on the wider rings but it'll still work moderately well. I think if I was dealing with a 90s road bike and wanted to watch budget I'd still keep an eye out for a 10sp centaur/daytona group. They were just a bit nicer and a good bit lighter but really affordable. I think you can still get a new set of centaur for 450ish.
Quoted: 574 Post(s)
Liked 615 Times
I doubt you are going to race so you will be fine with the additional grams in a square taper so sounds like you are on track. As Russ Roth said I would avoid 8 speed crankset with 10 speed chain as there is no reason to do so and it can be a problem. I suspect you will love the ride and maybe in the future (thousands of mile) if it is a lovely frame you can look at Athena of Record groupsets, they are special.
Quoted: 518 Post(s)
Liked 660 Times
Hi all,
Thank you all very much for your replies.
I have just bought the crankset.
Now off to find a compatible bottom bracket. I have an eye on a "Campagnolo Centaur Tapered Bottom Bracket" (forum policy prevents me from posting link).
Quoted: 1630 Post(s)
Liked 2,250 Times
@nunofrais - Make sure you get the right length spindle.
