2016 Giant ToughRoad SLR2
Likes For HCB:
#103
Depending on your riding, there are 3 solid upgrade paths.
Option 1: Upgrade shifter to a 9-speed RapidFire II shifter (this allows your thumb to shift both up & down) Cost ~$30.
Option 2: Convert to a 1x9/10/11 system. For commuting, 1x10 or 1x11 seems about ideal, and you get to drop a bunch of weight & clutter. Cost ~$20-$150
Option 3: Convert to a 2x10 or 3x10-speed (new cassette, rear derailluer, shifter). Front ~$150, Rear ~$150.
#105
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
Another reason is that the downpull front derailleur cable also prevents me from installing a kickstand in the area near where the aforementioned eyelet in the chainstay bridge is located.
#107
Liked 310 Times
It must be a very, very nice bike to ride now, because even completely stock it is pretty awesome.
#109
Bikes: Giant Toughroad SLR2
Was it a straight swap when you replaced the rotors, or is an adaptor/spacers required?
#111
Quoted: 5 Post(s)
Well the Toughroad comes with 160mm for front & rear. Most mountain bikes come with bigger rotors in the front than back. Usually 180mm front, 160mm back. You need the adaptor if you are replacing the 160mm with a larger rotor.
#113
There's nothing you need to change on the bike. The brakes are excellent, the drivetrain is reliable and shifts smoothly. Even the stock tires aren't bad. They're reasonably supple, roll smoothly and have a good tread pattern for road or light trail usage. The only reason to swap components is ergonomics or weight.
#117
Bikes: Cannondale CAAD12 Ultegra Disc (2017), Cannondale Synapse 105 Carbon (rim brakes, 2017), Cannondale Quick CX 1 (2016), Specialized Hardrock Sport hardtail (2009), Specialized Crosstrail Sport Disc (2014), Cannondale Quick CX 3
As I see it, there are 3 'primary' reasons to go tubeless:
1. You are far less prone to flat tires! No tubes to puncture - and typically if something does happen to puncture or slice the tire casing, the liquid used to setup and seat the tire quickly seals it. Tubeless setup's can be prone to 'burping' but that is typically only with *significant* impacts on already low psi setups.
2. You can run much lower PSI with tubeless setups. If your 'gravel grinding' or riding mixed terrain, lower PSI can offer much better traction, grip and/or comfort.
3. It's lighter. No tubes=less weight
there are other pros (and cons) - but those are my personal top 3...
#118
Quoted: 2975 Post(s)
Liked 1,180 Times
But you don't have to buy a tubeless wheel-set to go tubeless. You can just tape the rims. That and I believe the Giant SX-2 rims on that bike are already tubeless ready.
#119
Sorry for my English. I plan to purchase ToughRoad SLR 1. I have a problem with the selection frame size. I 179cm height and I do not know if the size M or L?
What you have frame size and how much growth you? Please help
Regards Przemo
Regards Przemo
#120
Probably L. I'm 6'0" and fit on a L, the M was definitely too cramped. If you have long legs you might be happier on the M.
#121
Thanks for your help gsa103 my choice is the size of M. And it was a good choice because he feels on it very well.
Such information for having a similar problem as me. I 179cm or approximately 5'87" M and is very well suited.
#124
I would imagine for any serious racing drop-bars would probably be better, unless it's highly technical riding.
#125
Bikes: FX Sport 4 Carbon, Nishiki Hybrid (1x9 mod), Raleigh Sport Comfort
Quoted: 47 Post(s)
Liked 189 Times
You may be confused with another model - the Anyroad shares the same blue/yellow paint, yet nothing else.
All of the components (Tiagra) are road-based, yet it has slightly wider tires (32mm) than pure-road usage.
Gorgeous bike tho
Gorgeous bike tho
