My handlebar. It's flipped
Quoted: 82 Post(s)
Hi! First post here. And my favorite bike:
All started when I flipped the handlebar on another bike and test rided. (3 years ago.) That bike was single-speed coaster brake so it was the easiest thing to do. After the ride I bought 3 such bars to have a spare. Cheapest btw.
Since then I am trying to find better bar as it is strange that flipped bar can work better than production models. Have not yet succeeded. What do you think about all that? How was it even possible to happen??
PS. 53 at the moment. 5 bikes. Single-speed and fixed gear.
Quoted: 1364 Post(s)
Liked 1,677 Times
People are put together differently. If it works for you go for it!
Quoted: 82 Post(s)
We are. Sure.
Nobody gets at the first sight what is flipped here btw. The bars were of that type - "traditional Dutch style parallel handlebars, of chromed steel":
And were supposed to be used that way:
(Pics taken from Dutch style parallel handlebars including stem
and Raleigh DL-1 Fan Blog: John Lennon on a rod brake Raleigh
Nothing new.
The proper ones are better known as bullhorn or cowhorn bars. If you look closely at time trial bikes, you will see the most modern iteration of them.
The main difference betwen the way your bars look and bullhorns is that they would be flipped left to right, which might actually make them even more comfortable for you.
Quoted: 82 Post(s)
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
That sounds like an improvement, particularly if you tilt the bars to maintain a good neutral wrist orientation. Your solution is not a lot different from the straight extensions I adde to my straight mountain bike bars.
Quoted: 82 Post(s)
Great! Now I know how to describe them. Traditional Dutch style parallel handlebars turned around backwards.
OK. Longer part on "mine" is very short on bullhorn. It makes a big difference. While riding I handle the bar "like" a steering wheel and I like that. And there are many other hand positions as well. Brake position is exellent.
Quoted: 82 Post(s)
Longer part is good when road level changes. The hands go where the body balance is best.
While riding I forget about the handlebar. With fixed gear and this saddle it is like flying. A bike for pure fun. And that is a mystery to me - nobody is doing like that. There are must be a reason.
Quoted: 82 Post(s)
The modified drop bars as Big Aura has used certainly are shorter in the horns, and that's because you can't do much else after cutting off the drops, but the ones I have might be a half-inch shorter than yours.
By the way, I've been riding with bullhorns for a decade or more. I've used aero brake levers and bar-end levers, and set one up with a combination of aero brake levers and bar-end shifters.
Soldered? Really? Why?
And the feeling you get riding the bike likely has more to do with the geometry of the frame, head tube and forks than anything else. The Shogun 400 fixed gear with bullbars I have is very much like that.
Whoa, I just noticed your brake is on the rear? If your bike is fixed and you're only using one brake, it's best on the front to give you two braking wheels.
Quoted: 82 Post(s)
Really
For strength? There is a big leverage. They often do such bars solded.
Want to add: the seat plays a lot. In both meanings. With that 3 springs it floats. Like it.
feros ferio
Liked 1,324 Times
You are right - there is a great neutral wrist orientation position. But what I like about the bars is that they can not be tilted. They are soldered. Soldered real steel.
Quoted: 4559 Post(s)
Liked 2,802 Times
Whatever works, works. I flipped and reversed the upright bars on my comfort hybrid while trying to find the sweet spot between comfort and efficiency. Once I found it I swapped for a flat straight bar 2" above saddle height. Took a year of gradual adjustments but it's perfect now. For now.
Quoted: 82 Post(s)
Quoted: 82 Post(s)
Beicwyr Hapus
This used to be quite a standard way of manufacturing stem/bars on Dutch style bikes, not sure if it still is.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
If more than 100+ years of bicycle development doesn't yield a comfortable position for you, change it.
Riding fixed, most put the rim brake on the front for braking control on both wheels.
Steel bars would seem to make the front end heavier than it need be, by a lot.
Quoted: 82 Post(s)
(It was cold that day).
And... As jodphoto said:
"I just don't feel the need to be aerodynamic any more."
Veteran, Pacifist
Liked 4,832 Times
an aero position doesn't make you any more fit, but it does allow you to go farther, easier. At 53 yo, you shouldn't totally give up on aero, unless you have specific body issues. JMHO
edit: what are the other bikes in the collection?
