Go Back  Bike Forums > Bike Forums > Triathlon
MTB handlebar stem on Vintage road bike
Triathlon Swim / Bike / Run your thing? Drop in our new triathlon forum for the latest in training & gear. From beginner to expert, and sprint to ironman.
Old 01-01-17, 11:54 AM
Spookytooth22
Not sure about posting here but maybe someone can link me to a thread that will help. Anyway, raced triathlons back in the day (30 years ago), had a 1987 Centurion Ironman which I installed Scott DH aero bars on. In order to get in what then was a proper aero position we put mtb handlebar stems on. After I quit riding the bike I donated the bike to charity (regrettable now). Fast forward to today, I recently purchased the same bike on Ebay, searched high and low for the Scott DH bars (which I finally found) and now am in the process of making this into the bike I had. My question is, does anyone recall the mtb stems used back then (trying to make the bike as original vintage as possible) and if not, could a regular modern stem be installed and work safely?
Spookytooth22 is offline
Old 01-01-17, 06:02 PM
Leisesturm
Quoted: 2475 Post(s)
Liked 722 Times in 513 Posts
So I've looked at that bike on Google, and I've looked at the Scott bars on Google, and in none of the dozens of pictures of various set ups with Scott bars do I see a stem in use that I would call an MTB stem. What exactly are you in search of? MTB stems "usually" have a 25.4mm bar clamp diameter, and are also 25.4mm in diam at the insertion into the headset. They also usually angle upward from the headset at around 30*. Road stems of the same era had a 26mm (usually) clamp diam. and were 22.2mm in diam at the insertion into the headset. They usually had zero rise to the horizontal portion and often had an appreciable amount of negative angle to the horizontal portion. Any stem with the proper diameters to fit your headset and the handlebars will work. Modern stems are mostly "threadless" and not compatible with the "quill" stem your Centurion needs but quill stems are still made and can be obtained new, but any bike co-op will have a large carton box full of legacy quill stems in all kinds of shapes and styles. FWIW.
Leisesturm is offline
Old 01-01-17, 09:22 PM
Spookytooth22
Thank you for reply and you supplied some helpful info. I thought we were being cutting edge back in the day by using the MTB stems (my girlfriend at the time was a pro triathlete so we were pretty privy as to the latest and greatest). As you mentioned, your search through Google held no examples. I did come across a few, though not specific Scott DH bars, they are still aero bars. Anyway, I will use the info you provided and see what I can come up with. Thank you again.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 03-24-18, 08:46 AM
Road Fan
Road Fan's Avatar
Quoted: 1851 Post(s)
Liked 654 Times in 498 Posts
Ok, so those up-angled stems are used to raise the aero bars so the pads are near the saddle height.
Road Fan is offline
Old 03-24-18, 10:40 AM
texaspandj
texaspandj's Avatar
Quoted: 1605 Post(s)
Liked 582 Times in 379 Posts
The walking thread.
Correct, however not everyone needed them. I didn't back then and still don't. Here's my rig for 2018.
File Type: jpeg
texaspandj is offline
Journeyman
Bicycle Mechanics
4
10-09-19 11:49 AM
VeryNot
Classic & Vintage
13
07-24-14 06:45 AM
ghostm42
Bicycle Mechanics
9
03-16-11 05:38 PM
mazdaspeed
Classic & Vintage
10
09-19-10 11:53 AM
abstractform20
Road Cycling
5
03-03-10 11:49 PM
