Tried a regular braking system on road bike was a disaster
So my bike coach is going to modify the road bike for one handed braking.
My cerebral palsy got in the way of using brakes normally I wound up taking a very nasty fall.
I'm nervous about one handed braking for me it will be the right hand that is used to brake. After several attempts to ride the bike two handed it became obvious that setting up for one handed braking is the only solution for a road bike. I feel like a failure, does anyone have experience with one handed braking. It seems kinda dangerous to me.
Sorry - no experience here with one-handed braking.
But, keep on trying and hopefully you'll find something that works for you!!
Perhaps a coaster brake of some sort?
Or, maybe a 3-wheeled recumbent (2 wheels in front) would work better? This would take the balance issue out of the equation - perhaps there is a foot-actuated brake for recumbents.. ? I've seen some pretty racy 3 wheeled recumbents online.
Best of luck!
Best of luck!
Quoted: 659 Post(s)
Liked 7 Times
I don't have any physical limitation, but hardly ever use my rear brake. Only use it on steep and long downhills if worried that the front rim&brake might overheat and on sand or other loose surfaces where the front wheel would lock easily. Of course it's also good to have a second brake in the event of an equipment failure (such as a cable snapping) that disables the primary brake.
I'd be inclined to move the front brake cable to the right lever so it's operated by your better hand. And then have a second lever (bar-end shift lever is sometimes used for this on tandems) also operated by the right hand connected to the rear brake for use on long descents or if there's a mechanical issue with the main lever.
a double cable brake lever was common on Tandems, front person had 3 brakes 1 lever had the rim brakes,
the other worked a drag brake, that kept the 2 people from getting too fast on long down hills ..
the trick would be the adjustments having the rear come on first, and then followed by the front
would entail the cable adjusters being set up to facilitate that..
Brifters are not so good at being set up that way But QBP does offer a cable splitter 1 cable pulls 2,
but then there remains the fitting of inline cable adjusters to make the progressive brake application functional.
Quoted: 18353 Post(s)
Liked 4,502 Times
It depends on your right hand strength and coordination. If it is essentially "normal", then the one handed brakes may well be a good option. Either cable splitting, or using a "tandem" lever.
Are you using drop bars or flat bars?
I'm with @jlaw that a coaster brake may well be a good option. However, it can't be used with a derailleur, so you'd be using a coaster brake with an internal gear hub. For example, the Shimano Nexus has an 8-speed internal gear coaster brake hub.
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
Can you not use something like this :
https://www.amazon.com/Sunlite-Alloy...er+for+bicycle
I built a gas bike once, and used this lever for both V-brakes - You have a clutch lever on the left, with a gas bike.
It seemed to work fine - You can adjust it to balance front and rear
