Is it ok to spot weld a plate to a frame?
Is it ok to spot weld a plate to a frame. It will not be structural.
Just a duplicate of the original with spacer.
Thanks
Shawn
Thanks
Shawn
Randomhead
Liked 3,699 Times
It should be okay given that the original was welded. I'm assuming it's steel, if it's aluminum all bets are off.
Are we looking at the new plate in that picture? Does it matter that it's much thinner?
Yeah steel frame. There is a spacer between the two plates.
Just wanted to add a bit of support against twist and make it look better. :-)
Thanks
Thanks
Quoted: 2338 Post(s)
Liked 2,827 Times
is the plate stainless...kinda looks like it? will that make a welding difference? Not my area of hands on, but i seem to recall that welding stainless is a bit more involved?
Not stainless, cover from electrical box. I tested on old handle bars, but stay is thinner less resistance.. Need to find a test part.
Thanks
Shawn
Thanks
Shawn
Quoted: 4209 Post(s)
Liked 3,875 Times
If the plate is zinc plated (galvanized) take care as to not breath during the welding. Andy
AndrewRStewart
AndrewRStewart
