Bicycle Fork Stem Extender
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
Has anyone ever used a fork stem extender to raise the handlebars? I have installed an adjustable stem and have it raised the max, looks to be about 55-60 deg. I feel this is going to be enough for my back issues but other handlebars would be another option. Just saw the extenders on the internet and was wondering if anyone has had a good/bad experience with them.
Thanks in advance, Frank.
Quoted: 18397 Post(s)
Liked 15,485 Times
I am going to assume you mean a steerer tube extender.
We Do that occasionally , Aka, 'Stem raisers'
..You do have to replace all the cables to reach that new height..
There are those made for both quill stems and threadless set ups..
I used one for about 6 months after a back injury. It was just fine, however the height does alter the center of gravity and the bike does not handle like it did before the riser. All cables going to the handle bar will need replacing for sure. As long as you are not aggressively headed into corners, you will be fine. Slow speed handling is a bit odd, too, but not dangerous.
Quoted: 249 Post(s)
Liked 306 Times
Thank you all.
Frank.
Frank.
No room-issue for me... the OEM cables still worked fine... I don't think it it's anything to worry about so long as you have an aluminum steerer tube and, if your rig has a tapered head tube, all the better.
I had them on several of my bikes and they have done just what they ere intended to do, raise the handlebars. No issues at all.
Frank,
I did not notice any difference in handling.
Pennylane Splitter
Bikes: Yes
Quoted: 1782 Post(s)
Liked 1,435 Times
I had one on a bicycle for a while, no problem with it. I had non-aero brake levers on the bike so no need to replace the cables. I eventually replaced the drop handlebars with some riser flat bars, which eliminated the need for the extender.
Bikes: '81 Puch '13 Cafe Noir
Quoted: 23 Post(s)
No problem at all. Works well for me on my '13 Cafe' Noir. I did have to replace my cables and left a little slack should I want to readjust.
Quoted: 5222 Post(s)
Liked 3,576 Times
Liked 3,576 Times
Quoted: 340 Post(s)
Liked 275 Times
Put a stem extender on my new minivello. Only 2 inches. .Didn't affect cables, but I still want more height. Bars still 2-3" lower than on my folder.
On a Schwinn mountain bike with flat bars that I rescued from garbage can last winter, I recently put on both a stem extender and 4" riser bars, I like it. As I was replacing the combo shifter/brake levers anyway, the old cables probably would not have worked.
Liked 3,576 Times
not much slack in those cables. I was able to get bay by just loosening the front brake cable & re-tightening afterward but the other cables had enough slack. depends on how much you raise the bars & how slack you have to play with at the derailers & calipers. other than those extensions are really easy to attach. I've done it on two bikes. a bike shop can do it for you if you get started & feel uncomfortable finishing
here's one of them (which had many other changes)
stock photo (before)
after
here's my other (current)
after
after
after
Quoted: 249 Post(s)
Liked 306 Times
after
after
after
after
Frank.
I've had a riser on two bikes with no handling problems. Neither required new cables until I started using a bar bag on one bike. That bike needed new brake cables.
Bought a Used Bike with a factory 'cut too short' threadless steerer.. on a Trekking bike ..
Went with a BBB BHP 21. it allowed me to add a 2nd stem , as well to mount my Bar Bag Onto.
it is a quill, shim spacers, with a keyway tab,
and a clever bolt that not only pulls the wedge up, but is internally threaded for the headset preload cap bolt..
It, visually disappears when installed..
Liked 3,576 Times
I see you are running drop bars with the extension. Has that made it better for your back? Also, what brands have you used? I had surgery in 2001 and have not been on a bike since then. Went with the flat bar style for the more upright position. Would love to get back on a drop bar bike again like I rode back in the day. Thanks for you photos and responses all.
Frank.
Frank.
Quoted: 249 Post(s)
Liked 306 Times
Thanks again all. Can you tell me what brand of extension you have used and liked?
Frank.
Frank.
Liked 3,576 Times
Quoted: 249 Post(s)
Liked 306 Times
looking at one of my photos, I think this is the one I used XLC Alloy Stem Raiser, 28.6 x 117mm, Black
Frank.
solo79
Bicycle Mechanics
8
06-14-15 08:00 PM
Remedemic
Bicycle Mechanics
2
07-04-11 07:54 PM
Dylansbob
Bicycle Mechanics
6
09-20-10 12:34 PM
