105 9 Speed to Ultegra 6700 advice
Bikes: 2008 Trek 2.1
Hey all,
I have a 2008 trek 2.1 with a 9-speed 105 RD. The RD needs to be repalced (cage is toast...long story).
I'm thinking of upgrading to an ultegra 6700 but can't seem to get a straight answer on whether or not it will work. I've read a lot of threads of folks saying it should work, but haven't seen a report back from anyone who actually did the replacement.
Basically, i want to keep my 9 speed cassette and use the ultegra 6700. Is this a good idea or should i just replace with a 105?
Thanks!
Thanks!
If you were to go to Ultegra 6700 you'd need to change the shifters, cassette, and probably the chain too. 6700 is a 10 speed setup.
that's what I thought but a lot of what i've been reading has been folks saying: you just need to adjust the max travel and it should be fine since the index ratio is the same on 9 & 10 speeds
Should Be More Popular
Quoted: 22614 Post(s)
Liked 8,935 Times
Flying Under the Radar
Bikes: 10' SuperiorLite SL Club | 06' Giant FCR3 | 2010 GT Avalanche 3.0 Disc
Are you talking about replacing just the rear derailleur? I think the 6700 rear derailleur should work fine with the 9-speed setup. But you should be able to score a 5500 or 6500-series for relatively cheap.
Here's one on e-bay.
I use a 6700 with a tiagra 9 sp set-up. I am in the process of converting the whole bike to 10sp ultegra, but in the short term, it works just fine.
occasional cyclist
I had a spoke break on my rear wheel of my 9 speed bike. It ended up catching between the chain and the tension pulley -twisted the RD around backwarks and irreparably bent the inner link on the parallelogram of the 7700 rear derailleur. Re-laced the wheel with new spokes where the chain gouged 'em, realigned the derailler hanger, and replaced the derailleur with a 7800 series 10 speed on an otherwise 9 speed setup. It is shifting as cleanly as before.
I'm sure an Ultegra 6700 10 speed RD will function just fine on a 9 speed 105 5500 setup. I'm not attracted to the aesthetic of 6700's flat black cages, but they are admittedly functional, durable, and lightweight.
I think the ratio of cable pull from the drailleur to derailleur movement remains the same (1.71?) between Shimano 8, 9 and 10 speeds (with the exception of Dura Ace 8 speed). SRAM uses a different ratio (1.39?) so you can't mix and match SRAM and Shimano shifters and derailleurs and get workable results.
Bikes: Kestrel RT900SL, 1975 Viner, Specialized StumpJumper
Yes, the 6700 will work fine. That's what limit screws are for. Hell, right now I have a 9 speed bike with Tiagra brifters and Suntour Cyclone derailluers from 1979. Smooth as butter.
Thanks All!
just pulled the trigger on this one:
https://www.nashbar.com/bikes/Product...2_534942_-1___
$65 with shipping is a steal
