Pucker Up
Pucker Up
In most cases, the Pucker Factor happens on rocks or steep inclines (at least for me). Here's a few tricky spots on our local trail. Most of these you are coming in hot down a hill or around a corner. On the front end of our trail we have well over dozen and a half of these tight spots.
Likes For CodyDog:
Destroyer of Worlds
I'd more than likely be dead if I tried something like that. Looks fun though.
Quoted: 257 Post(s)
Liked 70 Times
Tree gates like those are important to keep the atv/atcs out. Doe keep them pinkies inside the grips.
Practice the "sawing" technique to the get through gates which are narrower than your bars. Some of my bikes are running 810mm bars so, the technique is not much of an option.
Can you elaborate a little on the "sawing" technique?
Thanks
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Roll up to the tight squeeze, alternate putting your left and right side of the bars through as you roll forward. Really skilled can wheelie through, twisting the bars as you ride through the gap. The later is above my pay grade however.
Advanced Slacker
Liked 2,537 Times
Advanced Slacker
Liked 2,537 Times
Some folks "pucker" in high speed chunk. Some don't.
Some folks "pucker" on trails with exposure. Some don't.
Some folks "pucker" on really steep rollers. Some don't.
Some folks "pucker" on gap jumps. Some don't.
Some folks "pucker" on steep, tight radius switchbacks. Some don't.
Some folks "pucker" because they perceive those trees to be too close together to ride at speed. Some don't.
It's not hard to understand this basic fact if you've ridden for a bit.
And one thing I know from riding “a bit” is that threading a tree gate with an inch or less on either side at significant speed is something that nobody who has done it will take lightly.
But this is the internet, so people can pretend otherwise.
Advanced Slacker
Liked 2,537 Times
Are they pretending just because you find those trees to be scary? I don't think so.
Even some folks that have "ridden for a bit" obviously have a different skill set than other folks out there. Denying that there's a skills difference among the riding population and that folks who don't share your fears are "pretending otherwise" is quite a defense mechanism. It doesn't change the facts though.
And I am saying that from riding with many, many people over the years and seeing how people react to gates that narrow.
Years of experience has indeed shown me some people of all skill levels. It has also taught me to know BS when I hear it.
Advanced Slacker
Liked 2,537 Times
W
No, only the first one.... and the fact that you don't differentiate between the first and the other two (which are MUCH wider) makes me wonder how closely you looked at those pics before dismissing them.
To be be honest, I do think there are a some folks out there that have ridden that sort of stuff enough to get comfortable with it at higher speed. But anyone who has that much experience would know better then to dismiss them so out of hand.
I think those who really think taking a gate with an inch on either side at speed is no big deal have not actually done it.
I can see why to someone who has not done it may look at the first pic and simply see a non-tech, flat piece of trail with a couple trees. And sure, riding slow through it would not be that big of a deal. Experience tells me what that is actually like when passing through it at higher speeds, and also what happens when you clip.
So, yeah, I think a lot of people really don't pucker when looking at that first pic... because they don't know any better what it is like to actually hit it at speed.
Quoted: 257 Post(s)
Liked 70 Times
@CodyDog, back to programming
as Leebo said, side to side as you pass the obstacle
If you ride the same trails you'll know which you can get through. When I ran 740-760s I rarely clipped bark, but at 780+ it's no longer a sure thing.
I've hit some gates at races and got thrown to the back of the pack in a few seconds. So, yeah you may crash, but that just part of the fun...
Quoted: 257 Post(s)
Liked 70 Times
We got those too, keep your hands firm on the bar but unweight the front a bit. If you have too much weight up front and clip a tree you'll find it harder to recover.
Quoted: 800 Post(s)
Liked 512 Times
That first photo. Wow. That is a tight squeeze/fit. We have a couple of those on the trails I ride in my area. I keep my speed low but constant I just keep looking forward, hoping for the best. Definitely good for working on those bike skills.
Ya'll have your bars/brakes set up properly? Whatever reach you need for your levers. Position the brake levers so the when your hand rests on the grips, and the levers are comfortable, your pinkie knuckle is inboard from the end of the bar. 3/4 in or so is good. That way when you do clip a bar, its the bar, not your pinkie that takes the hit.
Quoted: 2975 Post(s)
Liked 1,181 Times
I've ridden for a bit. Have trees like that on my trails. Just slow it down and use "sawing" technique as noted above.
I rode extreme Mountain Biking for 10 years before I laid off for 10 years, now I'm back. With that being said, coming into a tight tree gate hot is and will be a "pucker" for me. Slow, no problem. Will just agree to disagree.
Likes For CodyDog:
Advanced Slacker
Liked 2,537 Times
Or maybe he meant those pics don’t look scary if you ignore the accompanying text. Sort of like a picture of a brick is not scary if you skip the text that explains that it is being thrown at you.
Liked 1,181 Times
Well you said this was a local trail. This assumes you ride it frequently. This also then assumes you know these features are coming up. So if you know these features are coming up on certain sections of the trail...what is there to pucker about? You already know those trees are there so you slow down before you get there. POOF!!! No pucker factor.
