Campy bottom bracket...
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
Not too familiar with the venerable Italian company, so I'm wondering what I've got here. Also, is there a secret trick is to removing it from the frame?
I assume a small pin spanner, which of course I don't have, but my fussing with an awl and an allen wrench yielded no results.
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 267 Post(s)
Liked 334 Times
That's a one key release and all you need is an allen wrench. Loosen it in the normal direction and the crank will come off the spindle.
Edited to add: The part with the small holes is threaded into the crankarm and holds the bolt in place. There is no need to mess with it unless the bolt is broken.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
C-Record had the visible 4-arm spider with the 5th behind the crank arm.
"41" = 1988
"It's very nice." -Borat
"41" = 1988
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Yes, a 7mm Allen key will remove the crank. The pins are for the retaining ring for the self-extractor system. No need to mess with them unless you need to replace the self-extractor. Unlike Shimano's similar "One Key Release" self-extractor system, Campagnolo's self-extractors were installed with a left-hand thread. That means if the self-extractor mechanism becomes damaged or missing, you will need a left-hand thread crank tool to remove the arm. Yes, they did make them, and yes, you will pay dearly for one if you damage the self-extractor mechanism. So, use the proper 7mm key.
Bikes: Numerous
Quoted: 1676 Post(s)
Liked 3,089 Times
2nd generation C Record crank. It will require a 111 mm BB spindle, if it needs to be replaced. I am the Virginia representative of the Campy Hoarders Association, so once the crank is removed, it should be sent to me for inspection, quarantine, and test fitting. Please note I have quite a backlog, because after all, I am a hoarder.
Quoted: 3464 Post(s)
Liked 2,828 Times
Note this one has the scratches that come from over shifting. Why I did not like this crank when it was introduced, the chain drops all the way to the pedal axle. Dismount to reset.
wave goodbye to the pack, time to chase.
Styling wise it did set a trend.
i did end up with one, date code 1984
I had two of these crank sets. I hated the self-extractors. So, I bought the pin tool and the left-hand threaded crank puller. I removed the self-extractors and used this type crank bolt.
Quoted: 209 Post(s)
Liked 175 Times
Got the crankset off...just had to add a cheater on the end of my 7mm allen key.
Thanks for the ID and removal advice!
Likes For 67tony:
