How does drop handlebar making long distance biking better than flat handlebar?
Hello!
I'm not experienced biker, so please elaborate to guide me. (literally, I did not intend any satire at all in my entire writing.)
I merely accustomed in handling with flat bar types, and less in drop handlebar)
I've heard that drop handlebars makes cyclist less tired through various grips by providing different arrangement of grips, hood, drop, and top.
but I just literally don't know how it helps. I just imagine that chainging position somehow makes body less rigid.
is it actually more effective than upright flat bar (or rised flat bar) position?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
The main assumption is that more possible hand positions reduces fatigue. If you spend 90% of your time in one position on the drop bars, this becomes less compelling. You should ride whatever you find to be the most comfortable. There are many other options, like trekking (butterfly) bars, Jones bars, etc.
Quoted: 1944 Post(s)
Liked 2,164 Times
There are more hand positions, but you are more aero with a drop bar. It is easy to overlook until you ride into a 15/20mph headwind.
John
John
Likes For Litespud:
Quoted: 2604 Post(s)
Liked 1,933 Times
But in the older sense, flat or mountain bars lock(ed) you into a single hand position. Compare that to four (at least) hand positions on drop bars. When your wrists and elbows get fatigued, it can lead to overuse injury if you've got to turn around and ride that far again to get home and can't change your hand position on the traditional flat bars. Drop bars? Move between the top, the ramp, the brifters or brake levers, and, of course, the drops.
And while it's technically possible to get your upper body low with flat bars, it's kind of like getting into a downhill racing tuck with your butt off the saddle and your nose on the stem -- not recommended for the faint of heart, strong in mind, or somebody without a lot of experience. But reach down and grab the drops, and you've just cut your wind drag enough to go a lot further before you're worn out. Safely.
Likes For pdlamb:
Occam's Rotor
Liked 2,331 Times
There's always the fork crown:
Likes For Cyclist0108:
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Tangentially, your body position also changes when moving your hands around. Change is good over long days in the saddle from your neck position to shifting around your family jewels.
Besides changing up your static position, vibration resonance (road chatter) shifts around hopefully to a better spot. Varying road surfaces may make this a moving target.
Likes For Toadmeister:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Hello!
I made the switch from flatbars to drop on my distance riding a couple years ago even though I found that the addition of bar ends did give me a lot of variety on the flatbars. The biggest difference to me is that the basic riding on the hoods position, which is basically not practical for extended time on a flatbar, is a much more comfortable position on my wrists. YMMV, however, I know a lot of people who can't stand dropbars at all, so the best thing is to try it out yourself. If nothing else, try renting a bike for a day.
Trekking figure 8 bend bars offer many hand position without the big expense of buying then changing all the shift & brake levers over..
Here is my example..
2 things on that,^, trekking bars are 22,2mm (1" Center) so Magura Hydro brakes , & Rohloff Grip shifter fit perfectly..
Quoted: 3352 Post(s)
Liked 1,056 Times
If you are touring, it would seem that the point is to see things. Bent clear over with the hands on the drops limit the view.
That is why so many cross country riders are going to some form of recumbent. You sit upright and have a 180 degree view.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Drop bars do offer a diverse set of riding positions. There are a number of other bar types that also provide a range of body and hand positions.
I’m gaining an appreciation for the “touring” bar, which is just one example of another versatile bar. A good example is the Nitto Albatross. I use the Sunlite Elson Roadster, which is a cheap steel copy of the same shape. A bar like that offers a range of positions from back and upright on the grips, various positions along the grip section as you slide your hands forward all the way to about 7” farther forward on the forward bends and even more aero positions toward the center.
A trekking bar or a Jones H-bar would give a similar range of forward to back positions, but with different grip angles in several places.
All of these bars let you adjust your body and hands to meet the different needs of climbing, cruising, standing, braking and so on, but they each do that in a particular way.
Otto
Quoted: 1364 Post(s)
Liked 1,677 Times
Up until I was 40 I could ride a straight bar without any issues. After 40 I developed hand issues and changing hand position during a ride is much more important. And now, nearing 60 changing body position is becoming important. In fact, just reaching down to work the downtube shifters on my old roadbike leaves me less stiff after a ride than my newer bike with brifters.
I just converted my old MTB to drops last fall and it now has bar-end shifters, which still gets me moving my body around. Before that I had clip-on aero bars on my flat bar MTB which let me stretch out forward and also straight upright by using the elbow pads as grips.
I keep forgetting about grabbing the fork crown, but since I mostly commute, that may not be a good option in traffic.
Quoted: 2482 Post(s)
Liked 2,955 Times
Odd how these discussions can go on for so many posts without a single mention of clip-on aero bars. I really don't get it. I got my first clip-ons 20 years ago, after an nerve relocation operation to (almost) correct an ulnar nerve problem. Now I have them on all of my bikes, including my strictly-road-use mountain bike.
In my experience, the combination of flat bar plus clip-on aero bar is the ultimate in efficiency and comfort, with bullhorns or drops plus clip-ons being nearly as good. Any other single bar configuration, however convoluted in design, would be at best a compromise for me.
Bikes: 2008 Dawes Haymaker 20XX Leader LD515 TotoCycling Road Bike
Quoted: 27 Post(s)
Liked 32 Times
Another option:
Gives four different hand positions: grips, grips/barends, barends (low), barends (high). First two allow access to brakes and shifters (release only for the second one); third is pretty close to position on the hoods of drop bars; fourth allows for bent elbows to go lower.
Quoted: 381 Post(s)
Liked 145 Times
On drops the most common hand position is riding the hoods. The hoods hand position if done right has less chance of compressing nerves causing numbness.
On flatbars you can have multiple hand positions too. You can also add barends or barinners for more hand positions.
Quoted: 668 Post(s)
Liked 529 Times
To answer the OP a single hand position pressures the same spots on the hand leading to numbness and fatigue. Drops have 4 different hand positions, thus easier to give different areas of the hand a rest.
Having said that opinions differ which is better for long distance riding. Some like flats and some like drops. Keep in mind not everyone likes laying out to ride so drops and aero bars are of limited use to them
IMO the problem with trekking and aero bars is added weight. Trekking bars can be wider making it more difficult to carry the bike up stairs or into hotel rooms. Aero bars take up valuable front end space limiting handle bar accessories or a gear bag options. Can't say I've ever seen a bike tourer with aero bars, but I'm sure there are some.
