Hollowtech II Question
Quoted: 455 Post(s)
Liked 112 Times
The bolts that hold the non- drive crank on are they anything special? One of mine is starting to get a bit rounded and I want to replace it.
Thanks!
Thanks!
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I know Shimano sells replacement pinch bolts for the NDS Crank. When I replaced mine for the same reason, I looked at the bolt head and noted that it was neither a socket nor a button head. The bolt heads are sloped from the base to the socket. I'd find an official replacement at a well stocked LBS, though they're more expensive than I'd like.
The dropped
Liked 1,014 Times
If I had to guess why they're designed this way, it's likely because they're recessed, and the head shape prevents them from binding in the recess or from rounding out the smaller socket used on button head bolts. IIRC, they specify ~80 inlb. torque for those bolts, which is way above what a button head is expected to tolerate at that size.
bike whisperer
Quoted: 1526 Post(s)
Liked 718 Times
Almost any standard bolt you get to replace one of these will have a head that's too large. IMO it'd be a good move to go torx, to prevent a recurrence.
To make the bolt fit, stick it in a drill and come at it with a grinder.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Only caveat being...Torx are more common than Allen-head in having out-of-spec/tolerance drivers/fasteners. As always. Use good drivers with good purchase, or risk rounding out heads, no matter what.
Likes For Marcus_Ti:
Quoted: 455 Post(s)
Liked 112 Times
Spoke with QBP today and found out which one. They are ordered!
bike whisperer
Liked 718 Times
I think the idea with those tapered heads on the standard bolts is for them to round out before the thread gets stripped; they're pretty weak.
In the case of stripped splines on the spindle clamp, when you want to over-torque by a fair whack, you really have to baby those bolts.
Quoted: 350 Post(s)
Liked 122 Times
Sugino cranks with 24mm spindles, which are of a similar design to Shimano, use standard DIN 912 M5 or M6 (newer models) pinch bolts, so for Sugino you can simply buy a bag of 50 pieces of bolts for $3 to replace them. You've already ordered replacement bolts for Shimano, but you could also measure the diameter of the head of the original bolts on your Shimano cranks, and compare them with the DIN 912 specifications. It's usually the Dk measurement. For M5 this is 8.5mm diameter. For M6 this is 10mm diameter. This is usually the nominal size with some small variation in tolerance.
https://www.schrauben-lexikon.de/norm/DIN_912.asp
Sugino wants 16Nm on those M6 bolts, but the socket head wears out on my cranks, so I replace the bolts if the sockets get loose.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
I think that they may differ depending upon road or mtb crank. My DA and Ultegra Hollowtech cranks use tapered socket head screws (left). The XT M780 crank replacement bolt I found uses a standard socket head cap screw. (right)
