Carbon or alloy
Old 02-05-20, 01:29 AM
cheesesandwich
Quoted: 16 Post(s)
Liked 12 Times in 8 Posts
Carbon or alloy
Hi guys, first post. I've got a dilemma:
Which should I go for?
1) 55mm carbon rims + Pillar spokes + Novatec hubs
2) Aforce AL33 + DT Competition spokes + DT350 hubs
The carbon wheel company is from Europe although they don't hide the fact the rims are MIC or Taiwan made with strict QC. While the AL33 is a 33mm deep alu wheel similar to the design of Zipp303 with similar aero test result.
I'm actually quite wary of far east carbon wheels when big brands have had issues with theirs but can't deny the aero advantage, while the AL33 has better components overall. I've been riding HED Ardennes+ LT for years and now looking for an alternative for speed. I can't decide on either, they will come out at about the same price. Your help please.
cheesesandwich is offline
Old 02-05-20, 01:43 AM
aplcr0331
Hear myself getting fat
aplcr0331's Avatar
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times in 134 Posts
Which one looks better?
Or are you losing P/1 Crits by mere seconds?
Go with whichever set makes you stop, turn around and walk back by your bike room and look at your bike again. Dreaming of your next ride up Mt. Kickapoo.
Seriously, get the set that makes you excited about the next days ride.
I will leave “aero” and “yaw angles” for the next posters to talk about.
aplcr0331 is offline
Old 02-05-20, 03:15 AM
bpcyclist
Quoted: 451 Post(s)
Liked 364 Times in 227 Posts
What kind of riding do you do? Rim or disc?
bpcyclist is offline
Old 02-05-20, 06:23 AM
cheesesandwich
Quoted: 16 Post(s)
I don't race at all...lol. Just a weekend warrior but I do like to push myself and go fast. On a rim brake.
Old 02-05-20, 06:43 AM
tgenec86
Rouleur
tgenec86's Avatar
Bikes: Felt FC (SRAM Red), Nashbar Carbon (SRAM Red), Felt BR2 (SRAM Red), Salsa El Mariachi 29'er - solid steel, Peugeot PX-10 1972
Quoted: 73 Post(s)
Liked 166 Times in 63 Posts
Was just at my LBS a few days ago and we got into a discussion about Novatec. Jason had a customer come in with a two year old wheelset with Novatec hubs and he tried for three weeks to find a replacement freehub body (with atrocious customer service to boot), and when he finally did find the part was informed it was no longer made and once stock was gone the hub would be non-repairable so the customer should consider buying two. In short, he didn't say they were low quality, but for a hub to be obsolete after two years? Not encouraging.
Something else to think about is carbon rim braking. The off brand Asian models may look like high zoot brands, but often do not have the same level of technology or the same materials on the brake track. Braking performance on standard carbon is simply not as good as an engineered name brand rim with a textured or different lay-up material on the brake track. The better wheels also dissipate heat better reducing the risk of the rim blowing out on long descents while braking heavily. The wheels you are looking at "might" be designed that way, or they might not. Twenty miles from home, skidding to a stop isn't the time I would want to find out. You also absolutely must use carbon specific pads if you want the rims to last and they are pricey and are not as durable. I have multiple carbon wheelsets and love them, but they are also race specific and for regular training I use aluminum rims. A high quality pair of aluminum rim brake wheels is just as good as a carbon wheelset IMO. They're just not "sexy" to the local club racers which isn't a reason to not use them.
tgenec86 is offline
Old 02-05-20, 07:20 AM
chadtrent
chadtrent's Avatar
Bikes: 2020 Canyon Endurace CF SL
Quoted: 56 Post(s)
Liked 109 Times in 47 Posts
If you are on a rim brake bike I would stay away from carbon wheels. I know there are people who say with the right pads they brake just fine or whatever. That has not been my experience. Especially in the wet. If the rims are carbon with an aluminum brake track then they will probably be okay.
There may be a slight aero advantage to deeper carbon wheels. But unless you are riding as fast and hard as you can all the time I doubt you will see any difference. I am just as fast on my Mavic Aksium aluminum shallow wheels as I am on my Knight 50mm carbon wheels. Which is why I rarely ride the carbon wheels.
chadtrent is offline
Old 02-05-20, 07:25 AM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
Between those exact two...I'd take the AForce/DT build. Novatec hubs are pretty bottom of the cartridge-bearing barrel, the only thing you can really say about them is that they're cartridge bearing....I'm not even sure you can find any documentation about them online.
Marcus_Ti is offline
Likes For Marcus_Ti:
Old 02-05-20, 08:46 AM
cheesesandwich
Quoted: 16 Post(s)
Thanks. I'm leaning more towards the AL33. The carbon wheels can be upgraded to DT swiss but those cheap carbon material still worries me and so far no positive comments. Is a 24h front lacing abit too much? I can only get that although prefer 20h.
Old 02-05-20, 08:59 AM
chadtrent
chadtrent's Avatar
Quoted: 56 Post(s)
You won't notice any difference between the 20 and 24 spoke wheels aside from seeing more spokes. The weight is nothing to worry about. Plus you will get a wheel that is a little stronger and stiffer.
Old 02-05-20, 03:19 PM
Slightspeed
Slightspeed's Avatar
Quoted: 741 Post(s)
Liked 818 Times in 421 Posts
My Culprt came with Token carbon 55s. They were great riding wheels, except on windy days, then they got pretty scarry. As a race wheel they are probably fine, but if you are out in the open getting passed by big rigs, or in windy areas, be careful. I went to a set of 41mm Reynolds Assault carbons, and the bike is much easier in the wind, and I can't tell any performance difference. I also have a Roubaix with aluminum Reynolds Stratus Elites with about a 1 inch aero profile, and that is my windy day bike. Not familiar with the brands you mentioned, but just to say that rim height does matter out in the real world. Also I wasn't comfortable with rim brakes on carbon rims, so the disc brakes work fine for me on these.
Culprit with 55mm Token carbon rims.
Same bike with Reynolds 41mm carbon Assaults.
Aluminum Reynolds Stratus Elites on my Roubaix.
Slightspeed is offline
Old 02-05-20, 03:35 PM
cheesesandwich
Quoted: 16 Post(s)
I've got another option. There's an American Classic 420 Aero 3 tubeless wheelset from my local buy/sell market. Seldom used and pictures look as good as new. Nice price at US300 and I do like the deeper rim but few concerns though. Although internal is 19mm which I like, the external rim is just 22mm meaning brake thickness is just 3mm. Thats quite thin compare to other rims. Eventually will wear and cause safety issue? It is also more traditional profile unlike the AL33 toroidal shape, might be a struggle in crosswind. 18/24h spokes same as my current HED, for my new wheels I thought of having stronger build.
I can't get much info about them as reviews are too little although positive. No idea the year and no more in sale, I guess stopped production. Worth getting? I can't post URL yet to show the profile. Guess you have to look it up on their website.
Old 02-05-20, 03:46 PM
TKJava
Bikes: Canyon Endurace, Kestrel RT1000 Ultegra
Quoted: 56 Post(s)
Liked 14 Times in 11 Posts
I'm not familiar with the wheels your looking at but you say that the carbon set are more "aero", I have to assume that the rim is a deeper section than a typical wheel rim? If this is the case and your a weekend rider who does not race but enjoys the tech on a bike challenges themselves etc I sort of get wanting "aero" wheels. I had a set of wheels that were defective and the company sent me an upgrade. I now have a set of deep dish wheels, they are an aluminum wheel with carbon fairings on them, the Oval concepts 700 series with a 50mm rim. I like the wheels because they were an upgrade to what came with my bike a little lighter a bit better bearings etc.
What I don't like is the way the "aero" rims handle in cross winds. The first time I got hit with a nice breeze coming from the side it moved my bike laterally in an instant. Riding in a charity event the course came around the back of an airport with zero trees and or cover and the wind was intense you had to keep steering diagonally into the breeze to be kept from being blown off the road. Maybe it's me because there are so many folks out there on the deep dish rims but I don't get it. When riding straight at about 20 mph with little to no wind they are great otherwise I prefer my regular rims completely.
P.S. Did I mention that the aero rims look cool?
TKJava is offline
Old 02-05-20, 04:04 PM
cheesesandwich
Quoted: 16 Post(s)
It doesn't have to be super deep but better than HED's 24mm profile. Not saying they are bad. They are very solid pair of wheels and I love them. Just looking for aero alternative
BTW, why does this site get logged out so fast? I have to login again before I could send a new post.
Old 02-10-20, 09:24 AM
"Fred"
Got Hills, I do!
"Fred"'s Avatar
Bikes: Trek Domane SLR 9.9 - Trek Supercaliber 9.9.
Liked 9 Times in 8 Posts
Get the carbon but upgrade the hubs. The layup will be fine on cheap carbon rims.
"Fred" is offline
Old 02-10-20, 09:36 AM
Wilfred Laurier
Seńor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 292 Times in 215 Posts
I rode a couple years on Novatec hubs. They creaked and popped and skipped and were generally not good. I may have been around 270lbs at the time, so YMMV.
Wilfred Laurier is offline
Old 02-10-20, 09:51 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
#1 sounds like Chinese carbon, nothing wrong with that but just know what you are buying.
jadocs is offline
Old 02-10-20, 10:18 AM
cheesesandwich
Quoted: 16 Post(s)
Here's how it's been going. I decided on the AL33 rim at first, ordered locally but they only have the ceramic wall left for 28h. Not worth the extra cost and looks weird with front machined wall, IMO. Took me some time to decide but went with the carbon rims because I realized I don't have to buy the whole wheels. WIll send to a local wheel builder to be built with the DT350 and spokes. How long do these China carbon rims last? 2-3 years? I guess would be enough before I go back to alloy rims. A bit of a hassle is I have to swap brake pads too if I want to switch to the Ardennes.
Old 02-12-20, 05:32 PM
Johnk3
Bikes: Simoncini, Wilier (2), Cinelli Supercorsa, Cicli Barco XCr
Quoted: 85 Post(s)
Liked 84 Times in 42 Posts
The deep carbon rims may cause you some concern on windy days. Aero is great going directly into the wind, but they are really annoying, and sometimes dangerous, with side wind gusts.
Rim brakes don't work well on carbon and require special brake pads. Carbon can be fragile. A pothole that would not faze a well made alloy rim may crack or fracture carbon, leaving it dangerous to use. Frankly I wouldn't ride a cheap Chinese carbon rim out my driveway. Not all carbon is created equal. By the way, good carbon rims weigh about the same as good alloy rims, they just don't need as many spokes. But, that is also their weakness. Carbon has a lifespan; ally does not. I have a set of 40 year old alloy rims that have gone many thousands of miles and as true and strong as ever.
Carbon rims are noisy. I can hear them coming from behind me even without my hearing aids.
Try the White Industries T11 hubs. They are smooth, quiet and come in lots of colors.
For a good compromise of aero and strong and long lasting alloy, look at H Plus Son rims, they have a lot of deep options and they make a high quality product as good as HED.
Last edited by Johnk3; 02-12-20 at 05:36 PM. Reason: Need to add additional information
Johnk3 is offline
Likes For Johnk3:
Old 02-13-20, 12:53 PM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
Quoted: 1465 Post(s)
Liked 1,542 Times in 806 Posts
Go for better hubs: DT240s
DT240 >> DT350 >> Novatek
Phil_gretz is offline
Old 02-13-20, 01:04 PM
Rajflyboy
Rajflyboy's Avatar
Bikes: Orbea
Quoted: 917 Post(s)
Liked 205 Times in 170 Posts
Alloy
Rajflyboy is offline
Old 02-14-20, 11:05 PM
Toespeas
Quoted: 164 Post(s)
Liked 44 Times in 41 Posts
dude week end warriors , if you want to spend on carbon go for it , but i would just get some mavic kys or similar alloy wheels , over 19mm wide !
Toespeas is offline
Old 02-15-20, 12:26 AM
Princess_Allez
Quoted: 173 Post(s)
Liked 57 Times in 40 Posts
Wouldn't the brake track wear out?
Princess_Allez is offline
Old 02-15-20, 10:43 AM
Johnk3
Quoted: 85 Post(s)
I imagine that may eventually happen, but I have replaced the brake pads several times. The wheels are fine, the tires need a breath of fresh air...about 110 psi.
Johnk3 is offline
Old 02-15-20, 12:51 PM
cheesesandwich
Quoted: 16 Post(s)
I have looked at the Hplus rims too. But the aero ones are narrow. Wide rims still appeals to me. The carbon rims I chose the 25mm instead of 28mm because I don't have to adjust the brakes when changing wheels. Although they are only 18mm internally, something I have to compromise.
Old 02-15-20, 03:08 PM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1098 Post(s)
Liked 559 Times in 446 Posts
Deep profile carbon rims have a very poor cost to benefit ratio. They are pretty much a waste of money for recreational riders. I don't consider them due to occasional strong cross winds and most weigh more than the moderately priced Campy zondas that I use on two bikes. They weigh 1550 grams and with 16/21 spokes, the should have decent aerodynamics. They have Campy's best hubs, without wasting money on ceramic bearings.
I once thought of moving up to the Shamal or fulcrum zero. They're 100 grams lighter, but the have the same number of fat aluminum spokes, that don't seem like they would be as aerodynamic. They cost twice as much as zondas. I have owned Fulcrum Zero wheels in the past and they worked just fine.
I've read reports of Chinese carbon wheels needing frequent truing. You won't have that problem with campy or fulcrum wheels.
check out pro bike kit for good prices.
DaveSSS is offline
