Third bottle cage
Third bottle cage
My longer rides are getting to the point that 2 water bottles isn't cutting it. My tamland has factory attachments for the third bottle cage. My question is, will a standard aluminum cage hold a bottle securely under the tube, or do i need to look into something a little more expensive?
I am potato.
Quoted: 1782 Post(s)
Liked 1,620 Times
If all else fails, an innertube pulled between the cage and the down tube (tied off at the right length, of course) with a hole cut for the mouth piece would secure it nicely. The idea being to prevent the bottle from leaving the top of the cage.
Topeak has a cage that holds a 1.5 litre bottle. I think it's a bit big, but it might be worth checking out if you are determined to carry all your fluids with you on your rides.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,200 Times
2015-05-03 11.38.54 by Stuart Black, on Flickr
This one did 800 miles
My bike 12 by Stuart Black, on Flickr
And this one did 1000
Beresford SD 4 by Stuart Black, on Flickr
Just make sure that the bottle fits tight in the cage.
Stuart Black
Stuart Black
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
Also a fan of three liters or more - it's weight, but getting off a trail trail on the edge of town, going into town, into and out of a store just to pay inflated prices wastes riding time.
Also with three bottles, buying a gallon jug is cheaper than buying smaller bottles and gives you a full refill, a drink, and a hand/face wash.
aka Phil Jungels
I carry two on the frame, and up to two more in a tail trunk if I need them.
Quoted: 2432 Post(s)
Liked 638 Times
I personally do not trust aluminum cages, I only buy stainless steel now. I've had multiple ones snap at the welds on my chipseal roads. If you get alu, get one that isn't welded.
This one isn't welded and would probably be okay.
I've used fiber filled nylon cages ... for my under the down tube bottle I got a Profile ..
Touring, it was an MSR , with petrol for the stove .. under the downtube..
In a word, yes. The lower bottle on this bike traveled 1500 miles for 5 weeks with water in it every day without issues. It's made many others in the same place.
Quoted: 539 Post(s)
Liked 44 Times
For a position where if the bottle came out it would drop right in front of the path of my rear wheel, I'd definitely spend the extra $10-$15 on a more secure cage.
Specialized cages have worked well for me on my mountain bike in holding onto the battle regardless of bumps etc ($25) -
https://www.specialized.com/us/en/ze...=220070-132481
https://www.specialized.com/us/en/ze...=219954-133280
https://www.specialized.com/us/en/ri...=219499-131055
I think some of the posters are responding as if you asked "is it safe to use it" rather than your actual question of "is it safe to use a cheap aluminum cage".
I'd definitely spend the extra $10-$15 on a more secure cage, for sure. They're a lot more secure for a little more money.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
Wolf tooth makes the parts.. https://www.wolftoothcomponents.com/
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
I've fixed a few tubular stainless steel cages that failed at the end of the weld by slipping a steel finishing nail into the tubular cage and silver brazing it together.
Liked 638 Times
If I were to put one on the bottom of the DT like the OP, I would use a stainless Nitto Touring cage. It has a closed loop so the weight of a bottle won't make the outer portion hang down.
Bikes: A hauler, a commuter, and a steamroller.
Quoted: 15 Post(s)
I've done some seriously bumpy gravel centuries with an under-downtube bottle cage (and 26oz bottle) mounted. My cage was steel, though:
https://www.universalcycles.com/shop...351&category=2
Bottle never even budged until I wanted it to.
Quoted: 4788 Post(s)
Liked 3,914 Times
Under the DT mounts are a really good place to use quality stainless steel cages. For one, the bottle is hanging from the welds instead of sitting on them. Big difference. The good thing is there are not-very expensive, cery high quality SS cages out there; the King cages. King (not to be confused with Chris King of headset fame) makes only bottle cages. Put a King cage on and forget about it.
Edit: the advice above on using a toestrap in addition is a good one, I often do.
Ben
Ben
Liked 4,200 Times
As for fenders keeping it cleaner, unless you are running fenders with one of those drag the ground flaps, the fenders end before offering much protection to the bottle. In other words, it gets dirty anyway.
Stuart Black
Stuart Black
Liked 4,200 Times
Ben
Ben
Those bottles had more than 450 miles on them when I took that picture (they weren't new when I started the tour) including about 200 miles of dirt roads in Ontario and part of the Erie Canal. You can see how clean they are. Bottles in aluminum cages would be dark black under similar conditions.
Stuart Black
Stuart Black
Clark W. Griswold
Quoted: 4330 Post(s)
Liked 3,954 Times
+1 on the Wolf Tooth B-Rad system. However my favored bottle cages are the Bird Cages from Portland Design Works, they look really neat but the more important thing is they hold onto bottles really well. On my touring bike I have a mount underneath the down tube and I have never lost a bottle with the Bird or Owl cages. However I will note that I do not drink from that bottle just refill my top bottles when I stop because I cannot reach it safely while riding.
I would make sure to use something like the Camelbak Podium Dirt bottles to keep dirt out in case you did want to drink from it and just in general to keep the contents from getting dirty in anyway. Plus Camelbak has some of the best bottles on the market.
