Best chain breaker/pin insertion tool?
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
Looking for a new chain break tool as I will be working on several older bikes and replacing more than a couple of chains.
Ease of use is better than light weight
Quoted: 2604 Post(s)
Liked 1,928 Times
I bought a Park CT-3 a while back and haven't regretted the cost.
I see they have a 3.2 and a 3.3 now. Buy the cheaper one if you're working on older bikes.
Likes For pdlamb:
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Seven speed and up:
https://www.ebay.com/p/11027060504?i...SABEgIs0PD_BwE
Veteran, Pacifist
Liked 4,832 Times
All of my Park Tools have been excellent.
Yeah, working on 5/6/7 speed and Campy10.
Should I have 2 tools?
edit - duh, forget question about 2 chain tools, as new chains will likely be spec'd as 8sp and work fine on 5/6/7. and probably only 1 Campy10 chain will need replacement.
Veteran, Pacifist
Liked 4,832 Times
Seven speed and up:
Don't think this one is for me.
Never bought a Campagnolo wine cork puller, either.
Likes For Wildwood:
Park CT 3 and variants (3.3 e.g.) and the mini version, CT 5 all do the job. They also use the same pin and replacements are readily available.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
I'm partial to pliers-type chain tools (e.g. Park CT-2, Gian Robert, VAR #303), but the modern profusion of different width chains with riveted links limits their application now.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Parktool 3.2 is our choice
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Not really sure, we don't run into 12 speed bikes at our charity shop which is why we were we to purchase the 3.2 models at a discount as long as some are still available.
Bikes: '01 Klein Quantum, '91 GT Zaskar, '70s Di Lorenzo, '74 Gitane Champion du Monde, '50s Steyr Klunker, Cannondale Singlespeed
Quoted: 18 Post(s)
Liked 21 Times
Here's my personal favorite: Shimano Pro Set HG. Good for up to 10spds, and rather pretty
Quoted: 25 Post(s)
I have had good experience with a Made in Taiwan tool model YC-324SC, costs less than $20.
According to specs it splits 3/16" chains but I succeeded to split a 1/4" too.
I have had bad experience with a $25 IceToolz, also so called heavy duty but a 1/8" internal width with 3/16" - sized plates didn't even fit in it.
If frequently used, it's handy to be able to fix both bottom and pin ranges. First time is turn, take it out to see if pin far enough, back in, continu, and so on. With a limiter screw it can be stored and next time the pin can be turned out in one time. The Taiwan model has both.
Likes For Novalite:
Quoted: 472 Post(s)
Liked 1,028 Times
I get to use different Park tools at the LBS. Park CT-3 is my favorite. Tough enough, works well and replaceable pins. CT-3.2 and 3.3 are less useful due to the sliding shelf. The CT-3 has a fixed "loosening shelf" that really is handy. Out of production though so watch for used. I donno what Park was thinking.
I never use the CT-4.3 for anything, due the design of the "business end" - you cannot see the far side of the link (concealed within the casting) so you cannot see how far you've pushed the pin, either out or back in. OK for those single use pins but, at the shop, we see very few of those. I don't have those at home. Too specialized a tool.
BTW whatever you get/have, take it apart, clean and relube once in a while. Works consistently if you do. Some folks tend to forget about maintaining their tools.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
Likes For SurferRosa:
Quoted: 980 Post(s)
Liked 582 Times
I still use my 50-year-old Cyclo chain-breaker.
Old fart
Liked 3,400 Times
Likes For JohnDThompson:
Cyclo. The best. It's what Eddy Merckx used.
this one has a slightly bent pin which means extra skill and a high frustration index is required for successful usage.
the trick is to develop a sensitive tactile feel as to when the chain pin is going to roll across the garage floor.
if i am sucesful in the usage of the primitive and beat down cyclo chain tool, then i reward myself with heroic portions of blackberry pie and blueberry milkshakes.
OT: does anybody make a light weight chain breaker for saddle bag storage? I thought i remember an alloy version from the 70's.
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times
For chains, I use the Park 3.2 Chain Tool, and the Park 1.2 Master Link Pliers tool. They're tough and work well. Not the least-expensive units out there, but they work.
https://www.parktool.com/product/chain-tool-ct-3-2
https://www.parktool.com/product/mas...category=Chain
