What year was the best Expert Ironman made?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
I have an 87 and an 89. I seem to go against the grain in preferring
The 89s Suntour components.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Mine is 88. Obviously the best. I got it as a frame set and outfitted it with Suntour.
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Clearly the 86 is the superior model.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Never been a fan of 105, so its either the Master version with tricolor 600, or the Suntour versions.
Quoted: 1946 Post(s)
Liked 2,004 Times
For the Expert, it must be 87. Because-- Miami Vice.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
I suppose we could ask Dave Scott...
Quoted: 4722 Post(s)
Liked 3,036 Times
From a component perspective I'd go with the 1988, due to the 7 speed version of Shimano New 105. But for a frame, I prefer 1988 with the blue and white marble finish. So, mix 'n match.
Quoted: 567 Post(s)
Liked 562 Times
For frames, definitely not 1989: https://www.bikeforums.net/20942389-post6646.html
To me it depends...
relaxed frames: 1985-1986 (if your a SIS fan then 1986)
tight geometry: 1989
Craziest attention grabbing color scheme: 1987 Expert in Magenta/Yellow
Best groupset: 1988/1989 Master (600 Ultegra 7 speed)
1989 Experts are a interesting one. I have a Black one. and the Accushift is either a love or hate relationship with it. It is a different indexing than SIS, but i like it.
Quoted: 677 Post(s)
Liked 459 Times
To me it depends...
Now all I hear is the click of the shifter and I think it shifts better than my 87 that has 105s
Could be your 105 shifters are worn some?
Quoted: 4559 Post(s)
Liked 2,802 Times
Yeah, Accushift on the '89 Expert could be klunky with the original Suntour chain and freewheel. I tried to make it work with Suntour Alpha 13-24 and 13-26 freewheels, but no-go. KMC chains made it a little better -- the original Suntour chain was awful.
After a lot of experimenting and cussing I found a great combo: SunRace chromed freewheels, either the 13-25 MFR30 or 13-28 MFM30; and KMC Z72 chains. The SunRace freewheel teeth are better shaped for crisp shifting and the chromed finish helps it run quieter. Stays cleaner too.
KMC has changed the model names of their lineup so I don't know what the current model is, but I bought a few new Z72 chains when they were available so I'm set for a couple of years.
Now shifting is snick-snick instead of kerchunk.
The Suntour 13-24 and 13-26 Alpha freewheels are in the parts bin waiting for an as-yet unnamed old school bike setup with proper friction shifters. I do like the appearance of those old school freewheels. But not the function with indexed shifting.
The only remaining issue was the friction-only front shifter and derailleur setup. It was kinda finicky. I got some ghost shifting when standing to stomp the pedals in the big ring, which was infuriating when it would suddenly downshift during a climb. It took a lot of minor adjustments to resolve that and I can't say whether there was any single solution. The front derailleur is very picky about alignment and height above the big ring. The inside of the FD cage is shaped to help nudge the chain efficiently, but demands a lot of careful alignment tweaks to minimize chain rub.
Part of the problem may have been some new cables and housings I got a couple of years ago. They were cheap, no-name, and the cables stretched quite a bit and cable housings compressed too much, before both finally settled in and stabilized. I'm still using them but next time I won't cheap out on cables and housings. I'll stick with Jagwire or Shimano. Even Shimano's cheapest cable housings that come with their RevoShift grip shifters, or the cheap SunRace SLM10 thumbies, are better than the no-name cables and housings I bought a couple of years ago.
I've had to accept very minor chain rub in the small chainring/biggest cog and big chainring/smallest cog in exchange for minimizing chain drops -- which always occurred at the worst possible times: on climbs in traffic.
It was so infuriating for awhile back in 2017 I replaced the Suntour front derailleur and shifter with Shimano. But I was determined to make the GPX group work so I kept tweaking things until it suited me. But that wasn't an Accushift issue since the left/front was friction only. Part of the problem appears to be that Suntour used plastic washers. Makes it difficult to finesse friction shifting. With brass and/or steel washers and various lubes you can finesse friction shifting a bit better.
I've replaced chainrings and freewheels many times to find the right combo of gear steps that suit me, while minimizing the need to be in the smallest or largest freewheel cogs. I'm mostly in the middle 5 cogs, which is more efficient anyway, and reduces any chance of chain drops at bad times. On the few occasions when I need the biggest or largest cogs in combination with a front derailleur shift I nudge the lever verrrrrry carefully. Usually works, even with Biopace 52/42 chainrings instead of the original Suntour or replacement Vuelta round rings I used from 2017-2019.
Likes For canklecat:
'87 'Miami Vice'
My fastest one is my Purple Haze 88 with all Dura-Ace 10 speed including the down tube shifters. My most versatile is my 89 Expert with a 52/38/30 triple crank a 10 speed Ultegra 11-28 cassette and the same shifters. I rode RAGBRAI on it and climbed every hill. My Miami Vice has yet to be rode ( by me) so I don't know how I like it. I think the 89 handles the best. Maybe because its a 54 cm and fits better than the 56 cm 88. The 89 rides hands free for miles but still handles like my Corvette. The ride quality on both is very smooth.
If the choice is Only between the '87 and '89 Experts, then the '87. The original first generation 105 group is hard to beat in reliability, durability and adaptability. Plus, Miami Vice.
But if we're talking overall Ironman it's the pre Expert/Master '86 Classic.
Likes For texaspandj:
Quoted: 378 Post(s)
Liked 1,409 Times
Hmmm.....
OP asked about Experts....
'87 was really the iconic year, with Wolbers and 'Vice scheme, New 105. It set a bar in value at that price point, with performance on par with Italians costing 3-4-5 times as much, and better components. (1987 Buyers Guide).
'88 has, IMO, the squiggles graphics and clean straight fades, so for styling, hard to beat if you like 80's. The move to Araya CTL-370's was significant.
'89 had the funky smoked fade and the straightforward black aggressive model that many feel was tweaked to be fast and twitchy. It also had the funky thunky GPX.
If I were to race in OEM trim, '89.
The most significant at the time, '87.
To look at, a yellow fade '88.
I've had a couple, and that's where I am right now.
Check back in a few minutes.
2008 - Candle apple red with gold accents. Sharply adorned with cutting edge ARC Reactor Mark III technology. Nothing was faster or more agile. To this day, nothing can touch it. Made my Cannondale Criterium feel like a tractor.
Don't even bother with the 2010 or 2013 models. The original is always the best. Newer models always pale in comparison. They lack the soul that was present when getting to know the original.
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 433 Post(s)
Liked 3,443 Times
I almost bit.
Nice try.
Crafty.
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
Likes For SpeedofLite:
Liked 2,802 Times
The one I'm riding is the best.
I have only one.
For now.
I have only one.
For now.
Death fork? Naaaah!!
Of the two I've owned, I preferred the '89 to the '88. And that's with not liking GPX that much.
Top
Top
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
Quoted: 378 Post(s)
Liked 1,409 Times
