Car Free for 10 Years !!!
20+mph Commuter
Bikes: Surly LHT, Surly Lowside, a folding bike, and a beater.
Quoted: 1430 Post(s)
Liked 330 Times
Congrats man! I remember my 10th anniversary. Almost purchased a car at 9 years but wanted to hold out for 10. Then I changed my mind. Still don't own one, although I do rent them now and again. Nice going. I know it's not always easy.
GadgetJim57
When loaded, how far can you travel before needing a recharge? Do you know how long that will take from a standard 110AC source? Is it possible/practical to pedal that load (how heavy is it?) if your batteries run down for any distance or in hilly terrain without knocking yourself out?
I tried pedal assist many times. Works great, but I will not be pedaling much. I can pedal easily fully loaded around 10mph, but not very far (bad knees).
I should get around 120 miles on a full charge. I don't know how long will take to charge .... I'm guessing around 8 hours ?
GadgetJim57
I don't know what size, what type of batteries you have... but... 120 miles per charge seems a bit, well may be a huge... bit of hopefulness without pedaling… I they are "regular lead acid batteries" I give you a range of 33 miles, if they are Lithium Ion I give them a range of 66 miles without pedalling... NOW, if you pedalled... Who knows, it would depend on how much energy you put in... You could very well make that 120 miles range... as for charging time most batteries take anywhere from 3 to 6 Hrs each to charge... 4 batteries = 12 to 24 Hrs to charge... JMO, maybe some more info would change some of those numbers but that is what I see as the average scenario for you.
GadgetJim57
My four LiFePo4 batteries (20 amps each) will provide 3,840 Watts (20 amps x 48 volts). I am pulling around 30amps per mile. Divide 3,840 Watts by 30 amps = 128 miles. However, I have increased the Watts to 3000 and Amps to 60, so most likely will get less range. I'm hoping on at least 80-100 miles on a full charge. When I go on a long trip, I will find out for certain ...
WOW, those are good batteries... and, yes you should/could, get the 120Miles or so range with them, more if you pedal even just a little bit. as for the charging time 10Hrs+ seems about right depending on discharge level. IMO The question left now, is where & how you gonna get access to a power outlet while touring,?
EDIT; Having done 3 short tours 800KM each on an E-Assist bike myself, I had to rely on solar panels for power as a wall socket was nowhere to be found around here...
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,528 Times
Ha, Ha, My Question was a legit one, your answer, while being a smartass one is not a legit answer... Maybe he is thinking solar, maybe where he wants to tour every camping park has a plug in option, maybe a combination... I was just curious as to his solution to a major downside to touring with an E-Bike... as... Plugging into a McDonalds or such for 10Hrs in NOT a good option as I see it.
GadgetJim57
BTW …. I will carry a 100' extension cord !!! I have call dozens of campsites, and several places told me that I will need a very long extension cord.
GadgetJim57
One campground I contacted told me that I could leave my ebike inside the restaurant when they are closed, charging all night. Not sure I want to take that risk though. I would have to walk around a 1/4-mile to the campsite.
Good question …. I have planned out my itinerary carefully …. I will be staying mostly at campsites that have electricity to allow at least 8 hours for charging. Also, I will be staying with Warm Showers hosts along the way. The two longest legs I have are around 70 miles each … Some days I will be traveling only 50 miles or less. I have tested the pedal assist and it is awesome ! I can pedal sometimes around 17mph, but only for short distances. I can pedal 12-14mph for a little longer, but not too far. So I will get a few extra miles from pedal assist. I also have regenerative breaking which charges when engaged. That will come in handy for traveling down hill, adding a little extra charge.
as for the 100' extension cord I would rather carry a 120 watt foldable solar panel to use whenever opportunity presents... JMO as to what worked for me...
Bikes: 2013 Haro FL Comp 29er MTB.
Quoted: 1470 Post(s)
Liked 45 Times
Whenever I think I have found the E-bike I want something shows up to make me wonder.
https://www.treehugger.com/bikes/ele...ge-charge.html
Liked 45 Times
well the small one is listed as an assist. 112 miles and 750 Watts. With a top speed of 26 Mph it might qualify in my state. I keep looking and keep being drawn to some of the European machines. As long as it can be limited to 750 Watts I could get passed as a e-bike in my state. But the big boys are tempting even if I would have to get it registered.
Liked 45 Times
Yes, I suppose you can make any of them Legal, by restricting the power output to 750 watts and speed to 28MPH or whatever your state law says is legal... But I do find myself thinking that if you actually want to pedal, meaning you want to ride a bicycle, anything over 350 watts with a throttle is making that bicycle into a motorbike... You will find yourself pedaling less and less but still thinking you are still getting as much exercise as before... Whenever I start to think that, I shut off the assist and ride my ride without using the assist and it straightens out my thinking real quick.
Any assistance is more assistance than i get now. How much assistance another person gets is still assistance. It, for me, at this stage is hard for me to judge how much exercise the E assist bikes are that I have tried when it comes to a 9 mile 3 or 4 percent climb into the trees. On my road bike I am soaked on those rides with a HR in the 160s. Same ride on a E assist and my HR is about 140 and I am as dry as when I hit the MUP heading for the beach.
I simply have no reference between 350 Watts and 750 Watts compared to the Watts my legs put out today. A boost of 350 Watts is like having a cat 3 racer pushing me up a hill. Lots of class 1 pedal assists seem to come with 350 to 500 on the sites I visit. 750 seems to be max for class 1.
I just cannot see the difference.
for exercise I can ride my fixie or MTB. I have spent the last 8 years leading a cycling club and trying to get PRs and KOMs. I have spent that time trying to keep my heart rate in zone 4 for up to two hours with 30 to 60 mile rides.
Liked 45 Times
The difference is that a 350 watt would NOT climb a hill without you pedaling/putting in most of the effort on any hill greater than lets say 3%... Where as, a 750 watt would climb most hills without you putting in any effort to lets say7%+... Thus you are now assisting the 750 watt motor, not like with the 350 watt motor that is assisting you... JMO and I know sometimes I do see things differently than most.
I can accept at least your opinion because you have a e-bike and I don't. Still the amount of assist being too much is somewhat subjective. Any assist is too much for a club racer. 200 watts with a one hour run time is mechanical doping to the pro riders and they are still putting out 300 to 400 watts on their own. I am getting to that stage where the legs just aren't what they used to be and the hills hurt a lot more than they used to. There used to be some thrill beating the 30 and 40 year olds up a 5500 foot climb now it takes and hour recovery time before I am ready to head for home. 350 watts sounds nice but it also seems like a compromise from what I would be allowed in a class 1 e-bike. I will not be surprised if sooner or later they let people ride 1000 watt bikes if they are governed to 26-28. So like getting a computer with as much memory as I can afford so I can keep it longer it "seems" reasonable to get as many watts as allowed so I won't outgrow the machine and I discover I need "more" assist on those days when I almost need an extra 350 watts just to get out and ride. Just how it looks to one from the outside of the e-bike world.
EDIT; and the too much assistance part is pertaining to the LEGAL, definition of a bicycle bit of the LAW... IMO after 500 + watts and a throttle, you are NOT riding an assisted bicycle, you are riding an electric motorcycle... again, JMO
Prefers Cicero
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,528 Times
Or with an inexpensive motorcycle to tour with the load you plan to take with you on two wheels with the medical problems that you have pointed out severely limit your ability to provide pedal power. You certainly would not have the range and charging limitations you will experience with your current setup. Probably would be cheaper too.
Congratulations on the 10 years without a bike milestone! There's a website (nothing to do with me), Mr Money Moustache which espouses a no car life as a way to save money and retire early. Your cash saving numbers sound impressive. That Yuba bike looks like a Harley Hog. Sorry to hear about the health problems, it is great to see you finding ways around it. Even if you did no pedalling, you'd still have a lighter carbon footprint and more fun in the open air than in a car.
Good luck.
Good luck.
