Inner tubes are quite bulky
Old 08-18-18, 06:17 AM
taz777
taz777's Avatar
Bikes: 5
Liked 25 Times in 19 Posts
I'm finding that I cannot fit even one inner tube into any of my tool bottles.
The spare inner tubes I have for my gravel bike are Schwalbe 700 x 28-45c tubes, so they are quite bulky. The tyres are 700x38.
This now presents me with a bit of a problem in how to carry a spare inner tube securely. I'm trying to avoid using a saddle (I have a Topeak medium saddle bag that is not being used).
Does anyone have a similar issue and has resolved it?
I may end up having to use my Topeak saddle bag if I cannot find another solution.
taz777 is offline
Old 08-18-18, 06:35 AM
Facanh
Quoted: 121 Post(s)
Liked 3 Times in 3 Posts
Half frame bag.
I made one with my friend and we designed it so I can use both water bottles. I'll probably never go back to saddle bag, it's so nice to use.
But if you really just want to carry your inner tube, strap it somewhere to the frame or to the saddle.
Facanh is offline
Old 08-18-18, 08:01 AM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times in 228 Posts
Bottom of the triangle works as in Facanh's photo, but least put it in some kind of bag to keep mud off of it, and whatever else might get kicked up by the front wheel.
wphamilton is offline
Old 08-18-18, 10:21 AM
taz777
taz777's Avatar
Bikes: 5
Thanks guys. A frame strap looks like a good solution.
taz777 is offline
Old 08-18-18, 11:49 AM
taz777
taz777's Avatar
Bikes: 5
After a bit of research, there appear to be two popular frame mount straps:
1. The Mutherload frame mount strap: Mutherload - Frame Mount
2. Louri frame strap: https://www.cyclorise.com/store/c4/louri-bike
The Louri one comes in a neat saddle-mount variant too.
taz777 is offline
Old 08-18-18, 12:18 PM
Facanh
Quoted: 121 Post(s)
I tend to overthink things but personally I would get something with a "belt style buckle" like the Voile straps.
https://www.voile.com/aluminum-buckle-straps.html
Facanh is offline
Old 08-18-18, 12:32 PM
wesmamyke
Quoted: 196 Post(s)
Liked 86 Times in 76 Posts
I have one or two super light inner tubes, they fold up a bit smaller. That's what I managed to jam into the bottom of one of those stash bottles.
wesmamyke is offline
Old 08-18-18, 02:09 PM
taz777
taz777's Avatar
Bikes: 5
I've got two different tool bottles and I cannot get a single tube into either of them! Because of the tube size, they're not so easy to come by but I will see if there is a lighter/thinner version that packs into a smaller bundle. I bought the only ones I could find in the UK of the size I required. That's if I don't go down the strap route.
Alternatively, could I get away with a tube meant for a narrower tyre? It would be overstretched to an extent I guess but I've read that it would still be okay, albeit much thinner when pumped up.
taz777 is offline
Old 08-18-18, 03:00 PM
Facanh
Quoted: 121 Post(s)
I'm not sure what sites you checked but this is a very very common size. When I worked at a bike shop I grabbed this size range the most for puncture repairs.
Schwalbe has the SV-18 which is a lighter inner tube that works up to a 622-42.
Can't you just use a regular bottle? I just checked my spare "Continental Trekking" inner tube that goes up to a 622-47 and it easily fits in a 600ml bottle with tons of room.
Facanh is offline
Old 08-18-18, 03:27 PM
taz777
taz777's Avatar
Bikes: 5
I omitted an important point, my apologies. I need a valve length of 60mm+ so that reduces my tube choice somewhat.
I already have the correct spare tubes (Schwalbe). I'll try repackaging them by folding them in a different way so that overall folded length is longer but width is thinner.
taz777 is offline
Old 08-18-18, 04:59 PM
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 257 Post(s)
Liked 90 Times in 74 Posts
Tubolito S-Tubo:-
Tubolito - Not your normal tube - super lightweight innertubes for your bike
tangerineowl is offline
Old 08-18-18, 11:55 PM
Facanh
Quoted: 121 Post(s)
Oh yeah that's not so common...
Try to actually suck on the valve to get all the air out. It's a bit gross but it works.
Facanh is offline
Old 08-19-18, 01:30 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Perhaps, but it's not that hard to get just about all the air out. I do that by rolling up tubes starting at the far end of the loop from the valve and roll tightly, burping the valve every now and then to let more air out. Sort of like getting the last bit of toothpaste out of the tube. That way, you don't have to keep working around the valve the whole time.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 08-19-18, 09:25 AM
pennpaul
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times in 46 Posts
I omitted an important point, my apologies. I need a valve length of 60mm+ so that reduces my tube choice somewhat...
I just bought a Topeak valve extender that screws on to the existing Presta valve.
BTW, why don't you want to use a saddlebag?
pennpaul is offline
Old 08-19-18, 10:11 AM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
Just carry a 700x25-28, I use them for up to 40c regularly. Or a latex tube that is smaller and lighter.
redlude97 is offline
Old 08-19-18, 10:13 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10954 Post(s)
Liked 7,482 Times in 4,184 Posts
I'll be the guy who responds with the least helpful and most direct response.
use a wedge bag. There is no downside to a wedge bag as it sits out of the way and keeps whatever you are carrying dry and clean.
some cry about the look of a wedge bag. Ok, I guess, but you can't even see it while riding so its basically a vanity complaint because they dont want others to see the bag.
mstateglfr is offline
Old 08-19-18, 10:48 AM
79pmooney
79pmooney's Avatar
Quoted: 4802 Post(s)
Liked 3,922 Times in 2,551 Posts
There are two ancient solutions. Wear the innertube like they did their spare sewups 90 years ago, (See any old racing photo. There is a series of Tour de France photos that are still in print). Or slip the innertube in a sock (I'd do that anyway for the downtube strap) and strap it to your seat rails with the traditional toestrap. (Again, like many including me used to do with our sewups.)
Ben
79pmooney is offline
Old 08-19-18, 11:01 AM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
I agree with this, even maybe "latex" although that would be a bit extreme for me personally.
I'm not joking, it's logical. We carry small, lightweight multi-tools that wouldn't hold up to normal use, and we don't mind paying for it, because we don't use them much and they're always on the bike taking up space. Why not the same reasoning for the tubes? Get the lightest, smallest that will work. It's just in the bag anyway almost 100% of the time.
Old 08-19-18, 11:12 AM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
I use a Silca tool/tube wrap, and strap it to my front rack.
https://silca.cc/products/seat-roll-premio
Marcus_Ti is offline
Old 08-19-18, 11:35 AM
taz777
taz777's Avatar
Bikes: 5
Now this could work! I'll try to find an ultra-light 'get-me-home' smaller tube size and keep the proper bulky tubes at home. I think I can pack everything I need in one bottle bag this way.
taz777 is offline
Old 08-19-18, 01:01 PM
Facanh
Quoted: 121 Post(s)
I start with all that but even after I can still suck some air out.
Facanh is offline
Old 08-19-18, 01:27 PM
taz777
taz777's Avatar
Bikes: 5
I've found Conti tubes that are 700 x 25-32.
Any ideas on whether I could get away with these on my 38c tyres? I looked at using valve extenders but those tubes I found already have 60mm Presta valves so would work without valve extenders. I just want to be reasonably confident that they work okay with 38c tyres.
taz777 is offline
Old 08-19-18, 01:50 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
I also do not care for saddlebags, or at least bags under the saddle. Lower weight feels better. So I opt for the Wolftooth B-RAD with an Arundel Tubi strapped to it. That bag holds... a lot.
Also, if you can source them locally, Cannondale makes a 700x25-32, and their tubes come shrink-wrapped, so about as compact as you can get.
DrIsotope is offline
Old 08-19-18, 01:51 PM
CliffordK
CliffordK's Avatar
Quoted: 18371 Post(s)
Liked 4,507 Times in 3,350 Posts
About what I was thinking.
You might be able to even go with a 700x18/25 tube. It is nice to have the same spare tubes for all bikes.
Then swap later if one wishes.
One note, it is my belief that large tube sizes tend to have slow leaks, but small tube sizes open up the holes and tend to have fast leaks.
CliffordK is offline
Old 08-20-18, 05:50 AM
taz777
taz777's Avatar
Bikes: 5
Thanks for the all the advice in this thread.
This morning I revisited this issue with a fresh mind and some determination to cram all the bits that I need into one of my tool bottles. After a bit of reorganisation of the contents, and fitting the pump onto the bike farm, things just about fitted.
In that Vittoria tool bottle, I've packed the spare tube that I bought recently (60mm valve), nitrile gloves, a Lezyne patch kit, a CO2 cartridge with sleeve (I found my PDW inflator and used the sleeve off of that), Silca tyre levers, a missing link, two wet wipes and a Lezyne Control Drive CO2 inflator.
Having a bit of an OCD for neatness and aesthetics (a very subjective thing, I realise), I'm happy that all the bits went into the tool bottle. It's a little bit weighty mainly because of the Crank Brothers F15 multitool and the inner tube, weighing in at 554 grams (=19.5 ounces or 1.22 pounds)
Finally, here's how it looks on the bike.
taz777 is offline
