Best budget 26" tire?
Quoted: 1088 Post(s)
Liked 1,205 Times
I recently picked up an early 90's Univega Alpina Comp, and I was hoping to reuse the tires on it to keep to a tight budget. However, I discovered that while the rear tire is fine, the front is shredded. It's currently running Bontrager Connection Trail 26x2.
I'd like to continue to have a matched set, but I'm not sure I want to buy a new Bontrager Connection Trail.
I'm new to mountain biking, and I am planning to initiate myself on a nearby trail that is described as not too difficult: https://www.mtbproject.com/trail/411...ial-bike-trail
Any recommendations that won't break the bank and would offer good traction and ride? I'm honestly starting from zero here, so any insights are welcome.
Quoted: 802 Post(s)
Liked 2,976 Times
26'r tires
cheaper to by 2 here; https://www.nashbar.com/forte-dartmo...026-20/p927916
good selection here w/free US shipping;https://www.worldwidecyclery.com/collections/tires-tubes/products/continental-mountain-king-tire-26-x-2-3-clincher-folding-black-shieldwall
Liked 1,205 Times
Kenda makes a variety of decent tires your size from about $20 -$30. They came stock on my 2018 Giant Sedona. I had planned on replacing them with better tires, But they proved to be a very well ballanced tire. Good traction on and off road, good ride, speed and durability
Likes For xroadcharlie:
https://blueskycycling.com/products/...y-1-get-1-free
$18 for the pair can't beat the price.
Kenda Brian Lopes El Moco DTC 26x2.1 folding
Quoted: 136 Post(s)
Liked 57 Times
Whatever brand you get, I see you're in NorCal. I'd look for a tighter-patterned, small block tread like a Kenda Small Block 8, or a Slant 6. Or in Maxxis brand, a Crossmark, or a Ikon. Bontrager would be a XR2 or XR3. Wirebead is fine, unless you see a kevlar/folding one for real cheap. FYI, that El Moco is an aggressive mud tire and it will not roll easily. You'll be on hardpack, mostly dry, maybe with some forest loam hence smaller, tight center knobs for easy rolling yet good side knobs for cornering.
Quoted: 427 Post(s)
Liked 699 Times
If you are riding hardpack, bikeme's suggestion is on point. If riding hardpack, a tire with tighter spacing would be better. I ride hardpack and am using Hutchinson Python's-which are not inexpensive, but the Nashbar tires mentioned earlier look decent. I also have tires for looser soil/mud conditions, Kenda Nevegals, and while they are good for loose stuff, not as good as the Pythons for hardpack. Might even try those Nashbar tires when my Pythons wear out, if hardpack is still the main type of trail I'm riding.
Likes For freeranger:
Likes For grubetown:
Liked 1,205 Times
I'm looking now at a used pair of Bontrager LT3's that will likely fit the bill. I really appreciate everyone's advice, especially the notes about likely encountering hardpack, which I think does reflect the terrain near me.
There is also a used pair of Specialized Fast Trak LK near me. Would these two be comparable, do you think, or is one clearly better?
Quoted: 427 Post(s)
Liked 699 Times
I've not ridden on either of the tires you mentioned, but chances are that any tire with characteristics geared toward hardpack trails will be fine. You say you are new, so unless you went with a really lousy tire (and the ones discussed so far are fine), you'll be ok with them.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Not only is the tread totally appropriate, but those are folding bead tires (as opposed to wire bead) and therefore lighter.
For that price it would be a no-brainer if you are trying to keep this dirt cheap.
If you want tires for actual mountain biking, get mtb tires with real treads. Don’t waste you time with hybrid tires.
Tires like the Small Block Eight (SB8) and Fast Track are OK for the rear (though personally I like something with more tread), but I think they are not good for the front.
On the othet hand, if you use the same bike for a lot of paved roads, this will likely wear out fast.
Liked 1,205 Times
If your focus is going to be trail riding (vs some trail and a bunch of pavement), would jump on that ASAP. These would be my preference by a wide margin over anything else suggested or mentioned in this thread so far. I live on the East Coast now, but lived and MTBed in Nor Cal for several years, and this would be my choice there as well.
Advanced Slacker
Liked 2,537 Times
Why as a beginner you would sacrifice grip and control for the sake of speed makes little sense to me.
If you really want to try an SB8, I would suggest do so for the rear. I know you said you would like a matching set, but there is zero reason to do that, and good reasons not to.
Liked 1,205 Times
Keep in mind when you read reviews that they are based on expectations being met. People buying SB8s are lookibg for a minimal tread, super fast tire. Expectations for grip are minimal.
I guess the upshot is that I have a cheap pair of tires and a spare with different tread, and because I have the tools and tinkering impulse and a trail nearby, I can experiment.
Advanced Slacker
Liked 2,537 Times
I appreciate the feedback — what are your thoughts on the Connection Trail, of which I still have one functional tire? Is that something you’d consider more appropriate for a front tire?
Honestly, if the choice is the connection trail or SB8s, I would go with the latter But really, I think this is a comparison of lousy vs terrible. But if your budget is so low that you are balking a a set of tires selling for $9 a piece (which is practically free considering it is a legit MTB tire) you are really scraping the bottom of the barrel, and can’t be too choosy.
For some context, top of the line mtb tires (standard, not fat tires) run $50-75 per tire. These will have folding beads, fancy casing construction that is lighter tough and flexible (faster rolling and smoother), and multiple tread compounds (such as the DTC which is harder down the middle and softer on the sides)
New “budget” mtb tires (wire bead, single compound, standard casings) will run more like $30-40. These are no frills tires, but legit options for a budget MTB. In many cases, these are the same tread design as the more expensive tires, and look the same at first glance.
Get down to $20 and these are the hybrid tires that are heavy, harsh, and not really intended for primarily off road use.
Of course there are occasionally blow out deals on any of these.
If you budget is under $9 per tire.... just make sure they hold air.
Liked 1,205 Times
I ended up with a used set of Kenda Small Block 8's that were $20 for the pair. The bike for which I bought them is a current project and a full tear-down/rebuild, so it will be a little while before I have a chance to try them out. They're just to get me started on a nearby hard pack trail, so my bar is not that high for now.
Likes For noobinsf:
Quoted: 136 Post(s)
Liked 57 Times
Likes For 2cam16:
Likes For Rajflyboy:
Quoted: 1608 Post(s)
Liked 2,588 Times
The Redwood loop is a fairly wide fire road, not too technical. You'll do fine on less aggressive tires. Got a picture of your project?
Liked 1,205 Times
