Mirror with Bar End Shifters
Old 03-11-21, 08:49 PM
smokeycanuck
smokeycanuck's Avatar
Bikes: Trek Verve, Surly Wednesday
Quoted: 18 Post(s)
Liked 4 Times in 3 Posts
Hello
Just picked up a Surly LHT and realized mirrors are an issue without having the drop bar ends available i.e. bar end shifters.
Has anybody found a good mirror option without having to lose the shifters?
Thanks
smokeycanuck is offline
Old 03-11-21, 09:19 PM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
Garmin radar. Helmet mirror lasted about 3 weeks.
Cyclist0108 is offline
Likes For Cyclist0108:
Old 03-11-21, 09:25 PM
SalsaShark
SalsaShark's Avatar
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times in 166 Posts
I moved the shifter for the FD to the downtube on my 520 and installed a barend mirror on the left. Kept the RD shifter on the barend. I actually kinda prefer it this way now.
SalsaShark is offline
Likes For SalsaShark:
Old 03-11-21, 11:22 PM
MarcusT
MarcusT's Avatar
Quoted: 766 Post(s)
Liked 617 Times in 344 Posts
I have not tried these on a drop bar, but do not see why they would not work. Attach to the last part of the bar at the shifters.
MarcusT is offline
Likes For MarcusT:
Old 03-12-21, 03:44 AM
flangehead
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 572 Times in 332 Posts
Helmet mirror.
flangehead is offline
Likes For flangehead:
Old 03-12-21, 05:24 AM
jpescatore
Bikes: Trek Domane SL6 Disc, Jamis Renegade
Quoted: 365 Post(s)
Liked 305 Times in 217 Posts
There are several clamp-on bar mount mirrors out there you can find.
I've tried helmet and glasses mounted mirrors, either broke them quickly or didn't like the view and went to and really like bar end mirrors. My first one was some kind of clamp on because I had bar extenders on the flat bars on my old hybrid bike - worked fine, but the one MarcusT showed looks superior.
jpescatore is offline
Old 03-12-21, 05:38 AM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times in 266 Posts
I do bar ends but use the Zefal mirror just below my brifter. Been using this for about 8 years. Well this is the second one. Got the radar last a couple years ago. The radar tells me to look.
biker128pedal is offline
Likes For biker128pedal:
Old 03-12-21, 07:31 AM
smokeycanuck
Quoted: 18 Post(s)
I picked up that little Zefal mirror yesterday from my LBS and will give it a try this weekend. Cheers.
Thanks MarcusT and biker128pedal.
Old 03-12-21, 08:47 AM
debade
Bikes: Trek Domane, Trek 2120, Trek 520, Schwinn Voyager step through
Quoted: 170 Post(s)
Liked 109 Times in 79 Posts
I use a helmet mirror. DW uses a handlebar mounted one. It might be the Zefel. We both use the Garmin radar. For me, it is worth the investment.
debade is offline
Likes For debade:
Old 03-13-21, 01:16 PM
Pratt
Quoted: 415 Post(s)
Liked 498 Times in 295 Posts
I mounted a mirror on a block of wood, and epoxied that onto the end of a piece of flexible steel tubing, like an old gooseneck lamp might have, about 15" long. It actually doesn't look as clunky as it sounds. The tubing is clamped to the bar near the stem. it is nicely adjustable and has proved durable through lots of lumpy dirt roads, and a few falls. No geese were harmed in its manufacture. I got a piece of microphone mounting flex and cut the ends off. I got it from a musical instrument supply company called Sweetwater. They were very nice to deal with. BTW, the steel is very hard and just laughed at my hacksaw, but succumbed to an angle grinder. In use, it is easy to adjust, but has enough friction to hold the adjustment, at least until the next fall.
Pratt is offline
Likes For Pratt:
Old 03-14-21, 09:04 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
I am surprised that does not get in your way when you’re in the drops.
Kapusta is offline
Old 03-15-21, 05:39 PM
biker128pedal
Quoted: 270 Post(s)
I mostly ride in the hood but they the drops work. The Trek bars have a slightly straight flat section and my left hand just touches the mirror mount. Other bars may not be as roomy.
Old 03-16-21, 02:20 AM
phughes
phughes's Avatar
Quoted: 1034 Post(s)
Liked 1,290 Times in 743 Posts
Search for this and you will find a lot of threads with a lot of good options.
Here is what I did. I bought Mirrcycle Road Mirror and mounted it to my bars using a reflector clamp.
phughes is offline
Likes For phughes:
Old 03-29-21, 02:24 PM
BikeLite
Quoted: 381 Post(s)
Liked 145 Times in 93 Posts
phughes, thanks for the idea on using a reflector clamp to mount a mirrycle mirror. I did the same today, just inboard of my left bar end (didn't want to drill them out) on a flat bar mountain bike : ).
BikeLite is offline
Likes For BikeLite:
Old 03-29-21, 05:53 PM
Freerojo
Bikes: 1997 Specialized Hardrock GX, 2008 Specialized Roubaix Triple 105, 1996 Cannondale RT2000 tandem
Quoted: 48 Post(s)
Liked 19 Times in 14 Posts
https://www.mirrycle.com/product/ori...rrycle-mirror/
If you have the older style brake levers this is a way better option
Freerojo is offline
Old 03-29-21, 08:13 PM
phughes
phughes's Avatar
Glad it worked for you.
phughes is offline
