Lightweight summer cargo type pants for cycling?
Quoted: 6882 Post(s)
Liked 10,873 Times
Quoted: 18320 Post(s)
Liked 15,299 Times
so here is the deal.
1) I have two bad knees but still like to ride. It is the only time I get to move around fast and bicycling is a light impact exercise on my old knees.
2) I live in an apartment building which not only uses key fobs on every door but for some reason decided the key fob should be 4 feet from the door so you have to fob, rush to the door while holding your bike, pull the door open, then keep the door open while you ferry your bicycle through because the doors have pistons.
3) the apartment I live in has two small elevators. One is down frequently and the jackasses that live in my building (12 floors) like to hold the elevator on their floor for reasons. It could be anything from a person deciding to keep the elevator on their floor while they unload groceries to workers keeping the elevator on their floor while they are replacing carpeting. The apartment also likes to reserve the elevator for people moving in which at times has left us with no working elevators even though it is against the disabilities act in my state.
4) I have a car but prefer to bike when shopping with in a 5 mile radius. I also work with in 5 miles so I bike to work and shop on the way home. I often use two panniers on my bike (hence why I use a gravel bike) either stuffed with work related gear or groceries. This is when I usually run into issues with the doors because the bike becomes cumbersome especially when carrying 50 pounds of bike and gear up 7 flights of stairs.
5) what, is this all you have to offer to this topic?
I'm just looking for suggestions on decent summer bicycle pants that are tear resistant from the metal teeth on bicycle pedals.
“and don't want my knees to lower legs exposed because those teeth slice through my skin and snag clothing too easily.”
Quoted: 2965 Post(s)
Liked 1,167 Times
1.) Learn to carry your bike differently.
2.) Find some pedals without pins that aren't so sharp.
3.) Use your car and carry your groceries like the rest of us.
Companies don't make pants with the thought of what materials to use to keep pins on bicycle pedals from ripping them.
Quoted: 1107 Post(s)
Liked 1,197 Times
If you don't mind the cost, check out Prana pants. They're very comfortable and, while they don't look it, are stretchy. I use them for hiking and general use (they look pretty good), but they're also very popular with serious rock climbers because of the way they work and toughness.
Likes For Camilo:
None of what you explained has anything to do with metal teeth on the bike pedals. You have three options here:
I have found a few options from suggestions here but hoping to find some that have air vents on the upper legs and near the waist.
I love how you think tear resistant pants don't exist or how you think you have any right to tell me how to live my life and shop for groceries.
Likes For Illgot:
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
I already have a pair of heavy waterproof pants that I wear in the winter that don't tear or snag. Companies do make tear resistant clothing but most of it is too heavy for summer use.
Likes For J.Higgins:
Liked 15,299 Times
Likes For indyfabz:
Liked 1,167 Times
https://www.orvis.com/chino-pants-fo...SAAEgJMPPD_BwE
https://workwearcommand.com/ripstop-pants/
https://www.opticsplanet.com/shop/tear-resistant-pants
I thought the “cover the pedals with socks” was a great suggestion . A bit classier suggestion might be a couple of those promotional can cozies that are made of fabric covered foam-like material. You could store them in the cargo pockets of your pants! Problem solved . (No special pants required!)
While it does seem like some of the replies have been a bit “mean spirited”, I do understand where they might be coming from. You’re experiencing an issue (problem) and appear to be focused on a single solution (pants made of tough fabric) and seemingly unwilling to consider alternative solutions. My wife calls it “pit-bulling” .
I have to say that if I had a bike with pedals that were somehow able to snag fibers out of denim pant legs, I’d be looking for different pedals!
RE: the issue of hauling 50 lbs (bike, gear and groceries) up several flights of stairs, might it not be reasonable to make two trips? Lock your bike outside of the building and take the gear and groceries up to your flat. Unload then go back down for the bike. Again, problem solved.
Dealing with the issues that day to day life throws at us, more so now than ever, requires flexibility of thought as well as action. Just sayin’.
Likes For sovende:
Liked 1,167 Times
Liked 1,197 Times
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
I bought a pair of these when they were MUSA pants. I still have them 10 years later.
https://www.rivbike.com/products/musa-pants
That said, tearing up the legs is why I have never used pedals with pins. I would have to really, really, really, need them to inflict myself with both long pants and potential shredded legs. One look at pinned pedals and I could see great discomfort and very painful long healing due to past leg baseball sliding and biking road rash scars.
I used SPD for a while and now have reverted to back to toe clips and straps with MKS Sylvan Touring Next, a nice wide pedal for my wider feet and use flat bike shoes or sneakers for short test rides or chores.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 364 Post(s)
Liked 456 Times
I have a pair of these MUSA pants also and a set of the older MUSA shorts. I like the long pants, but find the leg holes on the shorts to be a bit wider than I like. I have since changed to a pair of BassPro shop lightweight fishing pants that are a nylon blend and dry very fast, yet have a stretch aspect. On those, all the pockets have zippers.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
I had these pants. Riggs by Western.
Pretty tear resistant. But maybe a little to baggy and might still get caught.
But I think they were carpenter cut, not cargo.
Not especially lightweight. Had just enough synthetic material to be itchy to me.
