Weird Question: Whats the best way you've found to get tubes?
Quoted: 5 Post(s)
This comes from a pretty beginner cyclist and tinkerer with old bikes. LBS in my neighborhood charge $9 a tube, which I feel like is highway robbery although that might be a little unfair on my end as they have to make money to maintain a brick and mortar presence. So in addition to cost effectiveness (I have been getting flats like crazy, which is the fault of my own inexperience, but it will continue to happen), it's an ethical question.
How do you more experienced tube buyers purchase your wares?
Quoted: 2952 Post(s)
Liked 3,106 Times
I would stock up when my LBS held their annual sale. They would sell them at half price as a loss leader.
Randomhead
Liked 3,694 Times
$9 a tube is cheap right now. The shop may actually be cutting margins because they don't want the price to be too high. The shop I work at sometimes is doing that. There are other tubes out there, some of them aren't very good.
If you are getting lots of punctures you either have a problem with the installation of your tyres and tubes, or you’ve got the wrong tyres for the roads you ride on.
With modern tyre technology (even ignoring tubeless systems) punctures should be a rarity, although in certain places this means using tyres that might not be as fast or nice-feeling as you’d want.
What tyres do you have, what pressures do you run, and where do you ride?
Likes For ElCani:
Walmart charges 5 bucks a tube and they're pretty much indistinguishable from tubes you would buy from a bike shop. If they stock your size, that's the way to go imo.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
I buy them at the LBS and don't think about the cost too much. While I'm there I browse around for other stuff I might need, and talk to the staff just to be friendly and maybe they'll remember me next time I come in needing a quick chain replacement or something.
Quoted: 3015 Post(s)
Liked 3,793 Times
$9 is highway robbery?
I'll get far more satisfaction from spending $9 at the LBS than I will get from spending $9 at the McDonalds, gas station, Comcast, electric company, Home Depot, Walgreens, Verizon, State Farm, TurboTax and just about every other bill that comes across my desk. Life is too short to quibble over a few lousy dollars.
Quoted: 590 Post(s)
Liked 445 Times
I just bought these for $4.50 each (when you get the 6-pack) Amazon link
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Quoted: 429 Post(s)
Liked 475 Times
Sounds to me like the inevitability of flats for the OP can actually be avoided by some skills training (mounting/inflation process) and equipment changes (rim tape, proper size tube, etc).
We all have a problematic wheel from time to time, which incurs flats we can't explain and certainly kill the buzz with time spent on the side of the road. But a careful work can usually find the culprit. Sometimes it's the tire that needs to be tossed or relegated to the beater bike.
Stock up when they're cheap, but most people won't need more than a couple tubes and a patch kit for hundreds if not thousands of miles. Right?
Likes For billytwosheds:
Quoted: 767 Post(s)
Liked 1,898 Times
I have to agree that $9 is not a big deal for a tube. I usually get them online, but also grab a couple if I happen to swing by a bike shop where they may even be more than that.
Klaatu..Verata..Necktie?
Quoted: 10421 Post(s)
Liked 11,882 Times
Wait for sales online, and stock up. Also, invest in patches.
Likes For genejockey:
Quoted: 2337 Post(s)
Liked 2,821 Times
these threads get met. people think $5 coffee is normal but a bike tire that is $9 is hi way robbery?
Anyway I have tried a lot of tubes, types, over the years.
As always you get what you pay for so a large degree
I have settled on Continental race lite butyl tubes. for me they are a good match in terms of weight, performance/feel, reasonable puncture resistance and having a removable core so I can use sealant.
Retail tends to be $10t to $11 but you can find them for in the $5 to $6 dollar range on sale, in uk bike on line bike shops or amazon bundled a a 4 pack buy
other wise as note above walmart, amazon
also Velox rim tape is only way to go IMHO and only Rema TipTop patches
Likes For squirtdad:
Quoted: 809 Post(s)
Liked 1,022 Times
Bike shops will throw away a perfectly good tube that has one little hole in it. Wait until the bike shop closes. Then go into their dumpster sort though their tubes to find you size. One thing to look out for is that the staff at bike shops like to eat at the shop, so their meals will end up in the garbage as well. You might score some good food while your at it.
When you get home patch the tube and your good to go.
Or you could patch your own tubes without digging through the trash. They can be patched multiple times. There is no limit as long as when you patch the tube, you did it correctly and it still holds air.
By the way, since you are getting so many flats, and you shouldn't, when you take the tire off the rim, do some investigating. Find the hole in the tube. Is it a single puncture hole? Is the thing that punctured the tube still stuck in the tire? Bike mechanics will check the inside of the tire with their fingers to see if there is anything sharp still stuck in the tire before mounting a new tube. Being a bike mechanic comes with risks. That is one of them.
Do you have a "snake bite", two holes on the side of the tube? This indicates that there may not be enough air in the tire or that you hit a pot hole or bump. The tube is being pinched between the road and the rim. Are the tubes possibly leaking from the valve? Sometimes the valve doesn't seal well or the valve core may be loose. Are you using latex tubes? Probably not. These are specially tubes intended for the serious go fast cyclist. Latex tubes loose air and need to be pumped up each day.
Likes For Velo Mule:
Bikes: Numerous
Quoted: 1676 Post(s)
Liked 3,089 Times
I recently read a thread elsewhere about how tubes and other parts are so expensive now. I also balk at paying that much for a tube but OTOH, my last batch of cheap tubes from one of the British websites (or maybe Amazon, can't remember ) failed at the valve stem pretty quickly. Lesson learned, I pay for quality and patch frequently.
Likes For HTupolev:
Quoted: 1607 Post(s)
Liked 2,216 Times
Most of my flats in the last two - three years have been near the valve stem near or at the junction between the valve reinforcement and the tube. Some times at the mold line. Since i don't have rim tape of any kind the rim is smooth and the spoke holes are covered, its the quality of the tube. The last one, last week, is a Continental tube. The bike was hanging after a ride. I was standing next to it looking at my ride stats when it blew. Ragged, ripped hole.
My experience is that there is a seriously bad quality control activity regardless of the name on the box.
My tubulars are more reliable!
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
These guys are a great source: https://www.nosvacuumtubes.net
If you can get an Amperex 6922, PQ, white label, US, pinched waist (shield, gold pins), at any price, go for it.
Likes For Cyclist0108:
When do your flats tend to happen? Direct contact between rim and tube is generally non-ideal because of braking heat.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
$9 robbery for tubes? Some people have differing ideas of what robbery is.
So I was going to ask if you knew where to score some Gold Lion KT88s... and then I see someone's making them (or making coke bottle KT88s and putting the Genalex Gold Lion name on them)
It's been a long time since my ol' buddy's had some primo tubes loaded up...
https://images.lilypix.com/albums/use...gybackback.jpg
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I have learned to patch more than I used to.
I HATE paying lbs prices for consumables. Cables are another thing that just boggles my mind when shops charge $4, $5, $7 for a single cable.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
I search eBay's cycling category for "tube presta 32" (without the quotes).
The "32" is the stem height that my bikes require. They all hate really long stems. It's not me, it's the bikes.
Likes For SurferRosa:
Quoted: 930 Post(s)
Liked 1,291 Times
As noted by a couple of folks above, what type of flats are you getting? pinch flats? goatshead thorns? spoke punctures due to bad rim tape? road debris? pinched during tire mounting? You need to diagnose the problem and then figure out the solution. We can help you with that.
Also, I gotta ask, how many times do you patch a tube before buying a replacement? Unless you're slashing big holes in your tires/tubes, you should be able to patch at least 10 punctures per tube and patches/cement cost next to nothing. Properly patched tubes (no instant patches!) are just as strong as unpatched tubes. I have several tubes with 5 to 10 patches on them and seldom buy new tubes. The spare tubes I carry in my saddle bag usually have a few patches on them. If you're one of those wasteful people who throw away tubes with a single puncture then you need to take some lessons in proper use of a patch kit.
Likes For davester:
There seems to be a lot of variability in both cold-vulcanized and glueless patches. Some glueless patches suck, but I've never had any trouble with Park GP-2. Rema seems to be the safe-bet option for cold-vulcanizing patches.
Quoted: 874 Post(s)
Liked 2,287 Times
Like SurferRosa says a 32 stem height is the most important to me. I go to my LBS to buy anything I can , but , alas , they don’t sell the short stem tubes. I am forced to buy on the bay.
Likes For Kabuki12:
