3mm - really?
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
3mm - really?
I decided to take the Botty Team for some exercise today. It's a gorgeous bike and quite responsive, but it's seemed a little "squirrely" since I built it. Most of the bits were take-offs from the Merckx Professional (aka rust bucket) I had a few years back. I just put them on the Botty without much thought, other than getting the fit to match that of my De Rosa (a sublime rider!) On today's outing I happened to glance at the stem and noticed there were more witness lines to one side of the stem than the other. IOW, the bars were slightly off-center. Odd, I thought. I wondered aloud if this slight mis-alignment could contribute to the odd handling I had noticed from the start. A few minutes later I stopped and repositioned the bars, about 3mm or so, to pretty much center them in the stem collar.
Lo and behold it worked! I thought at first it was confirmation bias, but I deliberately rode slowly and experimented with hand positions. At low speeds I could now reach for the water bottle without weaving. It is still very sensitive to steering input, but nothing like before, and I actually enjoyed riding it. I also noted the bike is more stable when my upper body is lower.
I've never before had a bike where seemingly inconsequential differences mattered. Has anyone else encountered this, or am I just nuts? I made no changes to the bar/stem after removing it from the Merckx, and I do not recall it being an issue with the Merckx's handling.
Speaking of Merckx; if this is a real phenomenon, no wonder he was obsessed with his bike setup!
Quoted: 1372 Post(s)
Liked 1,748 Times
I am not too sure about the OP's result and interpretation but I do know one thing - small adjustments can and do make a difference. In my case, knowing next to nothing or darn little about fitting myself to a bike, it takes me many rides to dial the fit in. Perhaps I am just fooling myself, but do spend a lot of time trying to get it just right. And, when you stop to think about it, the number of adjustments to seat post height, saddle tilt, saddle fore aft, stem reach, stem height and so on, no wonder a little tweak here coupled with a little tweak there, and first thing you know, a better feel.
That's the way I see it, these days. I do, however, often wonder what things would be like if I could afford a professional fitting. The question is - to what. One bike is a 58, one a 56 and one a 54.
Likes For due ruote:
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
Not exactly. I moved one side 3mm closer to the stem.
Quoted: 3464 Post(s)
Liked 2,827 Times
I was buying in until the comment on while reaching for a water bottle things were improved. Hmmm
if one had both hands on the bars and the control points were not equidistant- ok
with one side control? Should not be an issue.
Maybe one arm earlier to ride one handed than the other, but that I think is a Hand dominance issue.
beyond that humans by and large are not symmetrical. My left leg is 3 mm shorter than my right, my right foot is 1/2 a shoe size smaller. I could go on- Not sure on arms or shoulders.
When it comes to saddle tilt, tiny adjustments make a HUGE difference. This is why the Campagnolo seat post was my first Campy acquisition. It was also why micro-adjust seat posts are everywhere now.
Also, I find I am sensitive to small changes in brake lever location (higher or lower on the bars' curve).
Handle bars 3 mm (1/8") off center? It would never leave my garage that way. I couldn't handle that much error. <--- channeling Adrian Monk here.
Likes For Bad Lag:
Quoted: 786 Post(s)
Liked 517 Times
Do you ride different crank lengths each side? mine are a mm or so off, and I've wondered if I should try something like that.
Quoted: 500 Post(s)
Liked 466 Times
Likes For Dfrost:
Liked 2,827 Times
even with isolated power meters. I do lead off with my right leg- the leg I would hop with in a game of hopscotch, and was left hand dominant from the start.
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Glad you are enjoying the Bottecchia. That was a wonderful riding bike for me.
Quoted: 2337 Post(s)
Liked 2,810 Times
Quoted: 1854 Post(s)
Liked 661 Times
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,586 Times
Picasso would have liked you.
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
Likes For RiddleOfSteel:
Quoted: 1627 Post(s)
Liked 630 Times
Totes. Both his eyes are on the same side of his head, too.
Likes For Lascauxcaveman:
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Sensitivity to tilt, definitely. Two-bolt posts, not so much, anymore. I like the ones with one large bolt, that actually adjust tiny clicks, going by the indents, but are hard to move the right amount. I usually move them too far, and have to start over a few times. 🙄😉 But once you get it right, it stays there pretty good, at least.
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
What do the experts think?
Liked 1,748 Times
it would be interesting to see the measurments of saddle to handle bar distance, saddle to pedal, etc..... I would guess that these all end up fairly similar. a number of custom builders, who work remotely use these as an important part of fitting, not just body measurements
Thanks to the natural process of aging, we all tend to get shorter. Usually loosing more height through our upper body than the lower. With that in mind, I went from a 56 cm seat tube to a 54 and still found comfort and decent fit. But something strange has happened...
I now prefer the comfort level offered by a 58 cm frame, providing it has a shorter top tube, as is the case on this Torpado. The bike is perfect for an old codger like me. In fact, though it will take some doing, the Torpado just might push the Legnano out of the "my favorite bike" status. I should go check the measurements and compare to my present favorite ride, a 1968 Legnano Grand Premio.
Liked 4,381 Times
-Kurt
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
Skip the comparison; makes my eyes water. Just one and the other would do. If you have an angle finder to find out the headtube angle, even better (and if you don't have a level, just use the angle finder on the top tube to determine whether the bike is level or not).
-Kurt
-Kurt
I did a similar analysis on a Paramount OS frame years ago. There was a difference in trail, IIRC, compared to my other bikes. The Campy semi-aero wheels are not helping - they do not like wind.
I just need to put in more miles and adapt to the responsiveness.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
It looks like your Merckx Professional turned into a De Rosa?
As you noted, the Bottecchia was already a lively rider/steerer. As time goes on, and the longer we are away from a bike like that, re-riding a bike like that will shock us a bit. My former Guerciotti Super Record was one such frame/bike with its very steep head tube angle and very low trail. It was a very squirrely bike. Somehow when I came back to it a little later, it wasn't nearly as active. I have that '89 Battaglin SLX with a 74.5° HT angle and 47mm of trail. With a higher (than would be traditional) bar/brake lever position, it's definitely a lively steerer, but a lot of fun. Light wheels help.
I think you'll get used to it again, and that the Bottecchia's character and distinction from other bikes will endear itself to you.
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
Your point about getting acquainted/re-acquainted is well-taken: the De Rosa itself seemed a little squirrely after not riding it for several months. I'm sure most of the issue is related to infrequent riding. The Botty is a keeper. I just need more time with my thoroughbred.
Likes For horatio:
